Replacing failed photo resistor. How to determine value?
  • lookimback
    • Aug 2013
    • 1489
    I just replaced an outdoor motion activated light for my friend and decided to troubleshoot the old one. Within a few minutes I determined the LDR(photo resistor) was bad. It only changes about 5 ohms between light and dark, and after removing it, the light works again. I would like to fix it because I have a use for it, but the LDR has no markings. With the LDR removed, the resistance of the circuit is about 80k. Any ideas on how to figure out the value?
    ------------signature starts here------------
    Re: Replacing failed photo resistor. How to determine value?
    I would put a pot (may be 10K to start with) in its place and vary the resistance to simulate Dark and light so at you will know what the delta is, then you may be able to do some modification using photo Transistor.
    https://www.badcaps.net/forum/attach...0&d=1554877524 where is the connection to the sensor? I cannot clearly see the traces on that section where the sensor is.
    You should also take some Voltage measurement on the two pads where the sensor is connected to.
    • redwire
      • 3912
      Guessing the chip is BISS0001 which is a popular PIR motion detector IC.
      CdS cell input triggers at 0.9V/1.7V and you'd have to check your circuit what the resistor is to +V power, and if it is 3.3V or 5V the IC runs off.
      For 3.3V power if R is 1MEG then a 500kohm dark CDS (or higher). I think you have a 1MEG trimpot for R.
      Some people put in a photo-transistor and lower say ~100k resistor.
      You can do the voltage divider math once you know +V and R.
      Careful the electronics is running from hazardous live so there is a shock hazard.
      edit: the chinese cheapola CdS cells are GL55 series:
      GL5528 is 10-20k light, 1MEG dark
      GL5516 is 5-10k light, 500k dark
      • lookimback
        • Aug 2013
        • 1489
        Originally posted by budm
        Iwhere is the connection to the sensor? I cannot clearly see the traces on that section where the sensor is.
        New pictures below. Red circle is the LDR connections. Voltage is about 5.7v with the LDR removed.
        • lookimback
          • Aug 2013
          • 1489
          It's one of those chip under blob things, so I don't have any way of knowing. The trimmer on the board is for range. Where am I measuring R?
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8703
            I don't think you can really make a good guess from here how the blob is made and what its light/dark cutpoint is. Probably have to resort to guess and check, I'd probably start with the GL5528 and see how it works.
              • 31256
              try to remove the coating, it could be the problem.
              • lookimback
                • Aug 2013
                • 1489
                I've been playing around with different resistances and it seems that somewhere around 33k is the tripping point. Anything above that will make it turn on.
                • lookimback
                  • Aug 2013
                  • 1489
                  I tried cleaning it up, but no change.
                  • redwire
                    • 3912
                    You can test the CdS photo-resistor out of circuit. They are slow and it can take 10 seconds when they get dark for resistance to settle. Very small chance the capacitors in the circuit by C16 C17 are leaky or failed instead.
                    I think any replacement CdS would work- photo-resistors have a logarithmic ohms scale and around 100:1 change between light and dark. So there isn't big difference between them if you are only looking at on/off, light/dark sensing.
                    A GL5528 looks good, or a GL5516 if that's all you have in the junk box.
                    It would affect the exact trip point at dusk, the GL5516 would make it need to be darker out before the motion sense is enabled.
                    Another method I faintly recall is counting squiggles and size on the CdS cell to compare them, but that's grasping at straws.
                    GL55xx CdS datasheet
                    • lookimback
                      • Aug 2013
                      • 1489
                      I'm 100% certain it's the photo-resistor. I've tested it out of circuit and it barely changes between light and dark. Also, I've simulated it in circuit with a resistor and that makes the light work again. I just ordered 20 GL5528s for 82 cents from AliExpress. I guess it will be about a month before I have them.
                      • redwire
                        • 3912
                        You can use it with the CdS taken out, if you need a security light until the part comes in. The motion sensor IC will think it's dark out all the time and it will trigger during the day.
                        • lookimback
                          • Aug 2013
                          • 1489
                          I'm thinking about doing that. I still have to run the circuit to where I need it, and I may not get to that for a couple weeks anyway. Pretty cool that I'm fixing this for about 4 cents.
                          • jinu_j
                            by jinu_j
                            Hi
                            05-03-2025, 10:51 PM
                          • mikey5791
                            Need help to replace burned resistor in 350w atx psu
                            by mikey5791
                            Hi to all forum members,
                            Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
                            The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
                            Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
                            Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
                            12-26-2024, 04:55 AM
                          • ahmedtou
                            HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
                            by ahmedtou
                            help me please
                            I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
                            When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
                            I will share all the details with you, including the disc information.
                            Code:
                            HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
                            Current Profile: BD-R
                            Disc Information:
                            Status: Empty
                            State of Last Session: Empty
                            Erasable: No
                            Free Sectors: 12,219,392
                            Free Space: 25,025,314,816 bytes
                            Free Time: 2715:27:17 (MM:SS:FF)
                            Next
                            08-27-2025, 08:49 AM
                          • MidnightRoller
                            Can a resistor lose resistance after hot air?
                            by MidnightRoller
                            I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
                            I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
                            02-02-2022, 11:46 PM
                          • artvandalai
                            What resistor ohm will work better to repair this waterpik?
                            by artvandalai
                            The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
                            01-05-2025, 04:10 PM
