Need help to "convert" a washing machine
    • 30985
    Re: Need help to "convert" a washing machine
    noisy drum = spider-bearing, if it's not direct-drive.
    also if it's not direct-drive 5-8 years is about how long the brushes last on the motor.
    • PinGuy
      • Oct 2016
      • 74
      • Argentina
      Originally posted by R_J
      Why don't you contact whirlpool and ask them? It never hurts to send an email and ask.
      I did, and instead of replying my question they replied I need to contact Whirlpool Argentina. No way I want to enter into such loop.
      Still waiting to find a 60Hz-capable generator to go with the mainboard and front panel to see if it turns just on...
      • Curious.George
        • Nov 2011
        • 2305
        • Unknown
        Get a 60Hz UPS -- one that is capable of powering on in the absence of mains power (not all can do so) -- and use IT to power the unit. Just don't turn on the motor!
        • Soulzink
          Samsug washing machine. Power supply DC41-00189a board issue
          by Soulzink
          I am trying to fix a samsung washinmachine power supply main board.
          I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
          Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
          The power supply board reference is the following: DC41-00189a
          I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
          04-19-2025, 06:26 AM
        • Sus256
          HISENSE 65E7KQ PRO - no boot
          by Sus256
          Hi all!
          HISENSE 65E7KQ PRO
          RSAG7.820.13512 - chassis
          MT9618BAATAB - cpu
          RSAG7.820.12059 - power
          HD650Y3U77 - panel
          KLM8G1GETF - emmc
          Replaced emmc.
          Terminal log
          UART
          AC_ON
          E-B
          FDE enabled
          06-01-2025, 02:11 AM
        • mojos911
          ASko washing machine User interface Display
          by mojos911
          I got a Asko washing machine that has had the flat ribbin cable sustain damage from some corrosion. I have tried to repair it but the ribbon cant sustain the repair and keep breaking. I was trying to source a new LED display but I cant figure out how to try and source one. the information on the back of the display is 13669-LED-A-A173-161007-RoHs. Its also a negative display witha 17v supply for the LED back light and the connectors are 26 pin x 2. What do i have to provide to try and source one of these?...
          02-02-2025, 05:03 AM
        • mojos911
          Fisher and Paykel 10 kg top-load washing machine LED identification
          by mojos911
          I'm looking for a replacement for the red LEDs used in a Fisher & Paykel 10 kg top-load washing machine. Each LED is about 6 mm long, mounts flush to the PCB with side tabs, and measures around 1.7 V forward voltage in diode-test mode. The marking on the body is “3A56,” but I can't find any matches for that in part searches. I've attached photos to show the shape and mounting style.
          If anyone has sourced an equivalent or knows a suitable replacement, I'd really appreciate your input. Thanks in advance for the help!...
          01-17-2025, 06:54 PM
        • stomanata
          No spin on washing machine AEG L6FBA674
          by stomanata
          This washing machine has power module emc18aecn1 and programmer ewx14931 914913208.
          It stop after electric shock.
          When i choose only spin it show 12min remaining. After 1min it start drain pump, after
          second it start relay (measured 12v ot relay`s coil) that deliver 230V to power module.
          This is also ~1second and then pump and relay stop. After ~2min this repeat - pump,
          after it relay and both stop.
          There is no error.
          Can somebody help me to try to fix it?
          08-11-2024, 10:39 AM
