What do you think about this meter Feedback need
Tags: None
Re: What do you think about this meter Feedback need
https://www.youtube.com/watch?v=KujMeU4QAvY
thought it looked familiar! -
Thanks for sharing this link
From his review it is decent meter for what you are paying for
I have seen his reviews beforeComment
wow - look at this!
https://www.banggood.com/1000M-1000V...p-1182844.html
they are making retro-style test gear! i may have to have one!Comment
If you buy one and try and test can you please post the resultswow - look at this!
ThanksComment
i had a real one but my good friend is looking after it now .wow - look at this!
meggers arent for testing as much as for fixing picture tubes or so i was told .Comment
The real use for one it check insulation break down in motors and any device that needs to be checked like thatComment
yes indeed .. i believe a modern pat tester works plus more features too .
i could never find anyone to hold the probes whilst i turned the handle to make sure it was working .Comment
i have seen them now on ali with 2KV output,
but to do a legit pat test i think you need 5ma - have to check that.
in the end, you buy it for the retro/fear factor.
an electronic 1KV megger with 2Gohm range costs less!Comment
I have owned one of these DMMs for a few months now. It's a reasonable meter for the price, but some of the measurements take a little longer than expected to show the results. But it is pretty accurate.
I have just received this DMM (see link below) the other day, and it's much better.
Look at the spec for yourself. And the price is great also.
https://www.banggood.com/ANENG-AN870...?rmmds=myorderShare your knowledge with others,
And the gesture will be returned tenfold.Comment
This is type of meter that I am looking for thanks for the review
I have to many meter like this but maybe not a 19999 count it is on my wish listI have just received this DMM (see link below) the other day, and it's much better.
https://www.banggood.com/ANENG-AN870...?rmmds=myorderComment
Hioki has no electrical safety agency approvals, I would avoid them for that.
Typical of Japanese multimeters. They will claim EN61010 or Cat. III but no proof they were tested. Then you find a gas tube inside, not a MOV like Fluke and others, so I would not use that on mains stuff. Once a gas tube is lit, it's shorting your input.
Oscilloscope kit DSO138 is cheap and popular, I wonder if it outperforms this DMM's scope. OP might look at those too.Comment
Yes about a Fluke but I do not want to pay that much for that type of meter yes I am a tight ass but can not help itComment
by chth96I read EBOOK of Testing Electronic Component and found that
"In order to test the small blue resin coated ceramic disk capacitor which has 104 50v specification,it is possible to test this small ceramic capacitor by making use of analogue meter.
Set to times 10Kohm that has 12v output from the probe to check disorder of ceramic capacitor.
It is not uncommon that testing result of digital capacitance meter is okay,But It show shorted reading when you check it with analogue meter."
Is it really possible to test small ceramic disc capacitor with analogue...-
Channel: General Capacitor Questions & Issues
by sam_sam_samI have had with regular AA batteries that leak this meter is expensive new I already replaced the battery battery clips once and the same thing happened again and I am tried of so it is getting modified to accommodate lithium ion batteries that are the same size excluding the positive terminal and removing the battery clips I will have enough room for the BMS protection board
I going to put 3 lithium ion battery in parallel with the BMS protection board and a way to charge the battery externally and heat shrink the battery pack and use a JST connector so I easily remove the battery... -
by jorpecHi
I want to change the scale of an analog meter, to monitor the charge of an li-ion single cell, so the needle at the end would point 4.2 volts and the 0 on the meter would point 2.5 volts or so, i tried to add diodes or a zener in series with the meter but the changes of the ambient temperature also changes the voltage value on the meter
I wonder how i can accomplish this so the meter would be precise at any temperature ?
Thnaks -
by sam_sam_samAbout a month ago we had a transformer jumper wire that burned in two different places between two transformers caused over $200 thousand dollars worth of damage to VFD drives at least 10 of them and a memory card and quite a few power supply as well
Now we have most of the equipment that got damaged back up and running except a feeder that has issues and we are waiting for some parts for
Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the “E” stops and one switching power (24 volt) supply and a transformer... -
by sam_sam_samI seen this today I was wanting anyone that has used it and what they thought about it and if it worth the money buying it
- Loading...
