what is this ic ?
  • petehall347
    • Jan 2015
    • 4429
    • United Kingdom
    what is this ic ?
    trying to figure out ic2 .
  • goontron
    5000!
    • Dec 2011
    • 4108
    • US
    Re: what is this ic ?
    An ARM microcontroller.
    Follow the white rabbit.
    • petehall347
      • Jan 2015
      • 4429
      • United Kingdom
      which one though ? i expected a 162 .. and looks like a r n
      • goontron
        5000!
        • Dec 2011
        • 4108
        • US
        ^ Its what they use in those VAG-COM adapters. They use stm32 microcontrollers though, so im assuming its a chinese clone. As for the IC, IIRC, its a LPC82 clone.
        • petehall347
          • Jan 2015
          • 4429
          • United Kingdom
          good guess .. it works but i would have preferred a arm 162 or whatever . looks too small for my liking ..
          • R_J
            • 9579
            Here is another picture, looks like the HL008 is 32Kflash, 4k sram, QFN33, Xintang /core Tang MINI58ZDE and I did find this
              • 31139
              so what's the device?
              interesting that the usb goes to a 28pin thing - usb>serial bridge??
              tacky not to just use an mcu with usb on it.
              • redwire
                • 3912
                Looks like an ELM327 OBD2 reader. SOIC-8 CAN transciever MCP2561 and Microchip CAN controller MCP2515 in TSSOP-20.
                • tvguy12012012120
                  Samsung UN55NU6900F Standyby voltage is 1V higher than expected, is this a problem?
                  by tvguy12012012120
                  This is the zombie UN55NU6900F I wrote about in this original post.
                  It originally was completely dead with no standby voltage. After some poking around, I found the solder at RM819 (see pictures) failed. I removed it from the board, it tested fine, resoldered it, and now the TV works.
                  The expected standby voltage at the reference pin is specified to be 11.8V but it's reading 12.8V. Couple questions:
                  1. What could cause the standby voltage to be 1V higher than expected
                  2. Is this a problem
                  3. Could it have led to the failure at RM819, or was that...
                  02-12-2025, 11:22 AM
                  Surface Mount Fuses Fundamentals Datasheet
                  TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                  TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                  10-07-2024, 06:07 AM
                • orgamisho
                  Capture digital data between microcontroller and led driver
                  by orgamisho
                  Hello, I have a device which uses 3 7segment displays (4 digits each) controlled by a single led driver (TM1629A) which is controller by a microcontroller (MS51FB9AE).
                  I want to capture the communication between the 2 ICs, so I can decode it and read it from PC with USB cable.
                  The problem is that this task is slightly over my skills and I have no experience is such tasks.
                  I would be grateful if somebody give a hint how can I read and decode the digital signals or share a source where I can educate myself on this matter.
                  I have no idea what protocol is...
                  11-10-2024, 02:42 AM
                • otaku_nut
                  Vizio E701i-A3 fixed but now has red vertical line
                  by otaku_nut
                  Hi all, I tried searching the site for answers but I'm a bit over my head understanding some of what might apply and what doesn't, so please be patient with me. I used Freakaftr8's fix to remove the left driver board to restore picture to a black screen with sound Vizio E701i-A3. After doing so, I now have a large red vertical stripe down the center of the screen. The fix did require getting another t-con board from online, I ordered it before I knew about the mosfit fix for the old t-con board. I have tried cleaning the cable connections to the t-con board. I swapped the cables going from...
                  08-19-2025, 06:11 PM
                • Revo2Maxx
                  Dahua locked out Uboot from bad Firmware install.DH-SD8A840-HNF-PA
                  by Revo2Maxx
                  So have a camera that came with CEEN firmware and when trying to add in USA Firmware the camera is now bricked.. I have looked at the SoC in the camera housing. It has a few and they were not related to the camera it self so I removed the camera module, wanted to see if it was setup like some of the other cameras that I have repaired in the past. This PCB don't have any clear USB or Reset pads, Connecting a USB to Serial I get very little data and shows that it is FW dead.. I can't stop UBoot I have even tried a script that has some expected key strokes and this also fails.. At first I thought...
                  04-17-2025, 04:31 PM
