trying to figure out ic2 .
what is this ic ?
Tags: None
Re: what is this ic ?
An ARM microcontroller.Things I've fixed: anything from semis to crappy Chinese $2 radios, and now an IoT Dildo....
Follow the white rabbit. -
^ Its what they use in those VAG-COM adapters. They use stm32 microcontrollers though, so im assuming its a chinese clone. As for the IC, IIRC, its a LPC82 clone.Last edited by goontron; 09-12-2018, 06:37 PM.Things I've fixed: anything from semis to crappy Chinese $2 radios, and now an IoT Dildo....
Follow the white rabbit.Comment
good guess .. it works but i would have preferred a arm 162 or whatever . looks too small for my liking ..Comment
This is the zombie UN55NU6900F I wrote about in this original post.
It originally was completely dead with no standby voltage. After some poking around, I found the solder at RM819 (see pictures) failed. I removed it from the board, it tested fine, resoldered it, and now the TV works.
The expected standby voltage at the reference pin is specified to be 11.8V but it's reading 12.8V. Couple questions:
1. What could cause the standby voltage to be 1V higher than expected
2. Is this a problem
3. Could it have led to the failure at RM819, or was that... -
TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...-
Channel: Common Parts Library - Datasheets
10-07-2024, 06:07 AM -
by orgamishoHello, I have a device which uses 3 7segment displays (4 digits each) controlled by a single led driver (TM1629A) which is controller by a microcontroller (MS51FB9AE).
I want to capture the communication between the 2 ICs, so I can decode it and read it from PC with USB cable.
The problem is that this task is slightly over my skills and I have no experience is such tasks.
I would be grateful if somebody give a hint how can I read and decode the digital signals or share a source where I can educate myself on this matter.
I have no idea what protocol is... -
by otaku_nutHi all, I tried searching the site for answers but I'm a bit over my head understanding some of what might apply and what doesn't, so please be patient with me. I used Freakaftr8's fix to remove the left driver board to restore picture to a black screen with sound Vizio E701i-A3. After doing so, I now have a large red vertical stripe down the center of the screen. The fix did require getting another t-con board from online, I ordered it before I knew about the mosfit fix for the old t-con board. I have tried cleaning the cable connections to the t-con board. I swapped the cables going from...08-19-2025, 06:11 PM
by Revo2MaxxSo have a camera that came with CEEN firmware and when trying to add in USA Firmware the camera is now bricked.. I have looked at the SoC in the camera housing. It has a few and they were not related to the camera it self so I removed the camera module, wanted to see if it was setup like some of the other cameras that I have repaired in the past. This PCB don't have any clear USB or Reset pads, Connecting a USB to Serial I get very little data and shows that it is FW dead.. I can't stop UBoot I have even tried a script that has some expected key strokes and this also fails.. At first I thought...
- Loading...
