Improvised surge protection
  • evilkitty
    • Nov 2017
    • 299
    Last Friday my raspberry pi zero took some damage from what i believe to have been caused by lighting
    The damage appears to have been minimal considering
    I lost a DS18B20 sensor, an led, and 2 GPIO pins
    the system did not even power cycle
    i would just plug a surge protector up to it, but i do not have space for a proper outlet
    are there some parts i can just use to add surge protection o should i just mod a surge protector in the attic on to the primary circuit that power my pi
    this box gets its power from the attic from the same box as the transformer for the doorbell, so i could slap a surge protector up there
    but i think i can crap a few small parts in there, any sugestions
    • 31277
    Re: Improvised surge protection
    you cant stop the emp from lightning, it will destroy mov's and spark-gaps that are fast enough to respond.
    • kaboom
      "Oh, Grouchy!"
      • Jan 2011
      • 2507
      Other than power, what is the RPi connected to?
      "pokemon go... to hell!"
      EOL it...
      All style and no substance.
      guilty,guilty,guilty,guilty!
      guilty of being cheap-made!
      • redwire
        • Dec 2010
        • 3912
        I think it's best to know where the surge came in- between which two points the surge occured. Then you can plan where to put a surge arrestor.
        I don't know all the stuff you have connected. Two relays but more I/O?
        Mains -> 5V PSU -> RPi -> HVAC
        With things turned off, take an ohmeter from RPi GND to earth ground, and Rpi GND to HVAC thermostat lines.
        To see if the RPi is isolated from the Air Con. It should be, the relays are supposed to isolate but a solder bridge or tiny gap can make incoming (mains) HVAC spikes jump to the RPi and kill it.
        I'd guess the lightning surge came in between the air con and the RPi power supply (usually ungrounded 5V PSU).
        The DS1820 might have been part of the loop the surge took.
        Most lightning damage I've seen is between Ethernet (DSL/Cable modem) line and other gear, but WiFi is used on the RPi Zero.
        • kaboom
          "Oh, Grouchy!"
          • Jan 2011
          • 2507
          When it involves comms, either POTS or CATV and other equipment with a three wire cord, and there's no bonding jumper (NEC 820.100, 250.94 and related), these independent common points (NOT grounds in this sense) pick up unequal voltages during nearby strikes or line faults.
          You've essentially got one "rod" in the ground for the elec service, and another for the telco cable shield and arrester (and CATV shield, if present).
          These lines will be at different potential without the bonding jumper.
          In that case, guess where current from that difference of potential (caused by step event) is going to equalize thru?
          But with the jumper, this current is essentially bypassed around the computer, TV, etc, and, as a bonus, everything rises and falls together.
          EOL it...
            • 31277
            emp is absorbed into coils and converted into current.
            that's why the most common victim is the network controller - it has the transformer in it's i/o
            if you want to put spark-gap's across the transformers windings then go ahead, but i suspect the energy will just blow the tracks off the board when the spark-gap triggers.
            • evilkitty
              • Nov 2017
              • 299
              Mains AC-> MFM-05-5 -> Rpi
              this is my control board
              https://i.imgur.com/YBiU6mV.jpg (sensor is in the lower left)
              This board receives +5 to control the relays, the pi uses a pair of massive overkill darlington TIP120 transistors that control the relays, each relay poll has a snubber
              the board receives +3.3 to power the led and the sensor
              *the led control pin survived the senor, led, and sensor GPIO pin (GPIO 4) were not so lucky
              i also lost GPIO 5 which was a OPEN circuit (momentary toggle switch)
              the relays have a flywheel diode and a indicator led to show if the col has power (on the right side of the relay in the picture)
              I am assuming the LED protected the LEDs control pin
              *The networking is done via wifi
                • 31277
                wifi is irrelevent, you still have the ethernet on the pcb even if you arent using it.
                think of a cloud of energy looking for a place to go.
                long wires or coils act like an antenna and absorb some of the energy - then you have to deal with it.
                mov's and spark-gaps work by going short circuit if the voltage across them is above a set level.
                the problem is they have an energy rating in amps or juels - go over that and boom.
                • evilkitty
                  • Nov 2017
                  • 299
                  As far as i know the Raspberry pi 0 v1.0 does not even have a Ethernet controller much less a jack
                    So did you have anything connected to the HDMI and the USB ports when the fault occurs?
                    • evilkitty
                      • Nov 2017
                      • 299
                      No HDMI, infant that circuit was powered off
                      Code:
                      /usr/bin/tvservice -o
                      as for the USB port, that has my wifi adapter (using a Pi 0 v1.0; so no bluetooth or wifi onboard)
                      Code:
                      Bus 001 Device 002: ID 7392:7811 Edimax Technology Co., Ltd EW-7811Un 802.11n Wireless Adapter [Realtek RTL8188CUS]
                      • redwire
                        • Dec 2010
                        • 3912
                        For the LED and DS18B20 GPIO to fail, the spike must have arced from the relays over to the RPi side.
                        Either across the relay (coil-contact) or there is a close spacing on your protoboard between the two sides. One solder pad on the relay contacts, close to a solder pad on the RPi side would do it.
                        That would be a transient (potential difference) between the RPi 5V side and the air conditioner 24VAC controls.
                        It's hard to tell if it came in on earth-ground bouncing up at the air conditioner (ground strike) or it came in on mains (powerline strike) to the Meanwell 5V PSU.
                        Anyway, one problem is your RPi is floating, it's not earth-grounded, but the air conditioner is. I'm not sure if the 24VAC side is earth-grounded on the air con. Have to check with power off and ohmmeter.
                        You could add a MOV or GND wire between the two to prevent large potential differences between them.
                        MOV's+fuse across line-gnd and neutral-gnd I think would have helped. Not Line-Neutral. Anything else get damaged in the home?
                        Air conditioners are weird for lightning because they are usually outside on a concrete pad (sorta grounded) and connected to lots of tubing/sheet metal ductwork as an antenna.
                        • evilkitty
                          • Nov 2017
                          • 299
                          As far as i am aware this was the only damage
                          none of the components around the relay were damaged (did not test the flywheel)
                          I have been using this for around 2 years and never had a issue, well until a relay failed so i added snubbers recently
                          I did not notice any sings of a arc anywhere on the board
                          the power company recently changed the polls and made them taller so more likely targets for strikes
                          i have not looked at the power adapter thought i should have but i did not
                          • nobbnobb1
                            Upgrading Whole Home Surge Protector MOVs (Eaton CHSPT2SURGE)
                            by nobbnobb1
                            I have a whole home surge protector (Eaton CHSPT2SURGE). This is the lower end model as compared to the CHSPT2ULTRA. When I took it apart, I noticed it's basically the same PCB as the higher end model, just missing the extra MOVs for higher capacity. Coincidentally, I have a pack of brand new Bourns 20D241K MOVs laying around:
                            https://www.digikey.ca/en/products/d...0D241K/2799098
                            The only thing I noticed is that these Bourns MOVs are not thermally protected with a fuse. I'm wondering if it's safe to just simply install these extra MOVs for extra capacity,...
                            06-04-2025, 08:40 AM
                          • evilkitty
                            Surge protection
                            by evilkitty
                            I had a power surge kill a piece of low cost hardware that due to the chip shortage they are well...
                            My hardware is powered by a meanwell 5v 1A open board power adapter/supply, this has survived and works properly still, i assume all i need is one of those blue disk 2 pin things, what should i attach to my high power supply's input power to help prevent this from happening again
                            it took damage twice from t-storms, the 1st was non-fatal (the second well... RIP SOC),
                            the damage happened on the 3.3v, the 5v seems fine, does it seems more likely low voltage AC...
                            09-07-2022, 10:20 AM
                          • m4a2t0t
                            Thermal Cutoff/Fuse ID -Surge Protector
                            by m4a2t0t
                            According to This PDF Its rated 109c functioning and 103c holding but all I can find is 109c functioning and 83c (10A) / 88c (15A) holding or 128c functioning and 103c holding.
                            It is labeled D108 PPqH
                            Should I try and match the functioning temp or the holding temp?
                            The protector is 6 outlets rated at 15A. That PDF shows 25A @ 240v but say 5 LRA @ 120V. I can only find 10A and 15A versions.
                            Thanks for any help...
                            01-12-2022, 09:36 PM
                          • Supradin
                            TEAC AG 980 going protection mode
                            by Supradin
                            Hi everyone. I'm new on this things, this is my first amplifier after I start offering repair service almost for free, just for learning purpouse
                            So I have a amp that is going to protection mode. I saw that if I remove the ribbon cable which sends from main board B+,B- and signal for amplifiers card, is not going to protection mode.
                            So, from that ribbon cable y disconnect everything but b+ b-, and amp goes again to protection mode. So my guess was something is wrong in the amp board.
                            I disconnect all transistors and amp is ok.
                            After, I connect the...
                            Electronics forum for electronics experts to repair defective appliance.
                            05-01-2024, 08:34 AM
                          • waspie
                            Aiwa GX-770 Amplifier Protection Circuit
                            by waspie
                            I am by no means an expert on this type of troubleshooting but I can follow direction real well.
                            I'm no stranger to using a meter and soldering iron so I'm looking for some help in fixing an old amplifier/system I got. This is part of a system "V-1200" by Aiwa where there are several components. My first problem seems to be the amplifier.
                            It seems to be in protection. When first turned on I hear the inital relay coming on but never the second relay which is connected to the protection IC. I don't see any obvious bad components on the board. If I ground the...
                            11-29-2022, 09:58 AM
