Surge protection
  • evilkitty
    • Nov 2017
    • 299
    Surge protection
    I had a power surge kill a piece of low cost hardware that due to the chip shortage they are well...
    My hardware is powered by a meanwell 5v 1A open board power adapter/supply, this has survived and works properly still, i assume all i need is one of those blue disk 2 pin things, what should i attach to my high power supply's input power to help prevent this from happening again
    it took damage twice from t-storms, the 1st was non-fatal (the second well... RIP SOC),
    the damage happened on the 3.3v, the 5v seems fine, does it seems more likely low voltage AC jumped/arked on my PCB to my data/3.3v wires based on the damage? if so i could insulate that area of the pcb with some plastidip
  • pavithra_uk
    • Nov 2010
    • 45
    Re: Surge protection
    For small power adapters or other equipment without ground connection, I use 1 varistor (470V usually) after fuse.
    L ---- FUSE ----+-- To adapter
    MOV
    N --------------+---To adapter
    if adapter have no ground connection, but it has wires long enough or connected with other ground, arcing can occur between AC input and DC low voltage rails. in this case, you must add 2 varistors and ground them.
    for power adapters like you mentioned, 3 varistors to protect LN, LE, NE and make PSU case grounded properly ensures good protection.
      • 31259
      when varisters fail they get very hot,
      you should put a thermal fuse in series and mount the thermal fuse against the mov.
      • redwire
        • 3912
        OP, you have to figure out where the lightning transient got in, and where it got out. Mains, telephone, CATV, earth-ground etc.
        I have no idea about the 3.3V power you mentioned, what's that got to do with the 5V Meanwell PSU that you didn't give us a model number for.
        I'm using TMOV 150VAC for 120VAC mains, and they clamp to 395Vpk with a 10kA lightning strike (20mm).
        For 240VAC mains, I believe suitable is 275VAC MOV clamps to 710Vpk.
        I put that across the Line-Neutral and an ordinary MOV across Neutral to Ground, I don't use the thermal MOV's there.
        Making a DIY thermally protected MOV by adding a thermal fuse and sock (or heatshrink) over top is fine - but not tested so it may not work as expected.
        If you have it in a metal box there's likely no real harm if it doesn't work, melts, arcs etc.
        I wanted to add gas-tubes but not sure what voltage to use or how they interact with a MOV.
          • 31259
          gas tubes latch on until the voltage drops below that needed to sustain the arc.
          great on an AC phone line,
          but i wouldnt put one on mains!!!
          • evilkitty
            • Nov 2017
            • 299
            I have access to a ground wire
            120V AC -> Meanwell 5v 1A -> Raspberry pi -> onboard 3.3v regulator
            everything lives inside a 22cu in box in the wall aside from this board: https://i.imgur.com/YBiU6mV.jpg (1st time i lost a led resistor and d18b20 at the bottom and a few gpio pins)
            https://raw.githubusercontent.com/GM...o_DSCI0030.JPG
            my power board is inside a gutted wallwort's case in the top of the box
            so for putting protection on the mains side i put this between line and ground? https://www.digikey.com/en/products/...RP150E/1154452
            • redwire
              • 3912
              Oh that's harder to figure out the path.
              A lightning zap coming in on the home's mains, seems to be nailing (jumping) between the Pi and the air-conditioner's thermostat circuits. The lightning surge is seeking earth ground.
              You can add MOV's to the Meanwell's mains input but that will not help if the surge is instead coming in to the air-conditioner and making the thermostat wiring have the spike on it, then it will still jump to the Pi.
              • evilkitty
                • Nov 2017
                • 299
                found the power supply, got it early jan 2018, the pi was a few years older that that (2016 at least)
                https://www.mouser.com/ProductDetail...09%2DMFM05%2D5
                what are the odds that everything before the SOC survived (including the 1.8/3.3v supply IC) if it came though the power adapter? is that even possible? note that that the USB wifi chip still works
                the SOC was shorted on 3.3v to ground, 3.3v was at 1.1v, the 3.3v was at max current output so the SOC did not get hot, gave it 3.3v with a higher current limit and tripped OCP/SCP on my power supply and saw the SOC get hot in the corner farthest (going towards the center) from the power input plug
                • Grunder
                  SANSUI PLASMA: Could mains surge damage Zsustain only?
                  by Grunder
                  Hi Guys,
                  I have a Sansui SV-EPD-42QOBP that has a damaged Z SUSTAIN board.
                  Is it possible for a mains surge to damage the Z SUSTAIN board only.
                  As a rule I dont do plasma tv repairs, but a customer needs a damage report for their insurance broker, so I took it on.
                  I do a lot of damage reports on lcds, these range from cracked panels, liquid damage and power surges. In most instances the surge damage is quite evident where you can see damage in the front end of the power supply.
                  (these surges appear after a power outage and the power comes...
                  06-26-2019, 07:27 AM
                • Supradin
                  TEAC AG 980 going protection mode
                  by Supradin
                  Hi everyone. I'm new on this things, this is my first amplifier after I start offering repair service almost for free, just for learning purpouse
                  So I have a amp that is going to protection mode. I saw that if I remove the ribbon cable which sends from main board B+,B- and signal for amplifiers card, is not going to protection mode.
                  So, from that ribbon cable y disconnect everything but b+ b-, and amp goes again to protection mode. So my guess was something is wrong in the amp board.
                  I disconnect all transistors and amp is ok.
                  After, I connect the...
                  Electronics forum for electronics experts to repair defective appliance.
                  05-01-2024, 08:34 AM
                • waspie
                  Aiwa GX-770 Amplifier Protection Circuit
                  by waspie
                  I am by no means an expert on this type of troubleshooting but I can follow direction real well.
                  I'm no stranger to using a meter and soldering iron so I'm looking for some help in fixing an old amplifier/system I got. This is part of a system "V-1200" by Aiwa where there are several components. My first problem seems to be the amplifier.
                  It seems to be in protection. When first turned on I hear the inital relay coming on but never the second relay which is connected to the protection IC. I don't see any obvious bad components on the board. If I ground the...
                  11-29-2022, 09:58 AM
                  BrightKing KD07 Metal Oxide Varistors (MOV) Datasheet
                  Metal Oxide Varistors (MOV) Data Sheet
                  Features
                  ● Wide operating voltage (V1mA) range from 18V to 820V
                  ● Fast responding to transient over-voltage
                  ● Large absorbing transient energy capability
                  ● Low clamping ratio and no follow-on current
                  ● Meets MSL level 1, per J-STD-020
                  ● Safety certification: UL: E327997 CSA: 246579 VDE: 40027827
                  Applications
                  ● Transistor, diode, IC, thyristor or triac semiconductor protection
                  ● Surge protection in consumer electronics
                  ● Surge protection in industrial...
                  10-07-2024, 05:58 AM
                • av4x
                  Fujitsu U7511 liquid damage, wont turn on anymore, does not respond to charger in any way.
                  by av4x
                  Good morning, everyone!
                  I've gotten my hands on a few laptops with various defects because I want to get more involved in repairing electronics.
                  First up is a Fujitsu Lifebook U7511.
                  It won't turn on anymore and doesn't respond in any way when you plug in a power adapter.
                  Model: Fujitsu Lifebook U7511
                  CPU: Intel Core i5-1135G7
                  GPU: Intel Iris Xe Graphics
                  RAM: 16GB DDR4 - 3,200 MHz
                  PCB manufacturer: ASKPCB?
                  PCB serial numbers: CP801602, CP7984241-Z4, E239218, CP809978-01
                  Damage: Liquid damage
                  The liquid probably...
                  11-01-2025, 03:09 AM
