An idiotic question about AC and shocks.
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Re: An idiotic question about AC and shocks.
    Heh, I just found my AR-3 causes random nuisance tripping of one of my GFCIs. I was wondering why the GFCI started tripping ... until I realized that Heathkit AR-3 was a new addition to that leg.
    I noticed that I can get some small sparks if I touch the antenna ground wire connector on the AR-3 to a ground. I suspect I should take a look at the isolation there, it may still be 'normal'...
      Just check the leakage current to see how high it is.
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8701
        Looks like it uses two 0.02uF capacitors to the chassis, so that should be less than 1mA RMS -- should be in the acceptable region of the GFCI... that is, if they don't resistively leak (good Y-caps?) or if there's something else on the line that's also leaking...
