Hot Air Station - Air Pump Failing
    • 31256
    Re: Hot Air Station - Air Pump Failing
    the cloud look is caused by the flux boiling off when it was soldered, look below it - some pins have hairline rings
    on the bright side, lead-free solder is much stronger so cracked joints are less common.
    • caphair
      • Nov 2011
      • 1249
      #62
      Oddly the air control seems weaker. I have full range again but just seems weaker than before even at max air. Is it possible for a new pot to cause this or?
        • 31256
        check it with a meter
        • caphair
          • Nov 2011
          • 1249
          #64
          Check the potentiometer? It has a smooth range.
          Could I adjust the trim pot to increase air?
          • redwire
            • 3912
            You could measure rms ACV at the air pump and see if it's going up to full mains voltage or not. Or use the 40W light bulb.
            The trimpot only sets the lowest pump speed, it would not affect full speed.
            If the pot goes to near zero ohms, and the triac is still not full on, I would change the cap from 0.1uF to 0.047uF (47nF) for 120VAC operation.
            The air pump speed control design is el-cheapo and missing a RC snubber, so I'm not sure how much voltage stress the triac sees, or how much current the main potentiometer sees.
            I drew this schematic of the YH 852D+ V2 pump controller, based on your pictures but I cannot see all the parts. It's a typical light dimmer circuit. Part values are all over the place depending on make (Kada, Yihua, Saike etc).
            • caphair
              • Nov 2011
              • 1249
              #66
              Seems to smoothly change voltage from 45vac (lowest air) up to 118vac highest setting. I tweaked the trim pot to get lowest air speed to 50vac as it seemed a little too non-existent at that setting.
              I thought maybe this hose was to blame so I squeezed it open but there was no change over all. Maybe it's the pump not putting out same air as when it was new?
                • 31256
                maybe there is a blockage - like where the wire joins the air and leaves the unit - that area used to kink a lot on mine.
                • caphair
                  • Nov 2011
                  • 1249
                  #68
                  You mean at the connector held in by 2 screws going out to the hot air wand?
                    • 31256
                    yes, where the pipe meets the base
                    • caphair
                      • Nov 2011
                      • 1249
                      #70
                      Do you mean there could be blockage inside the little box that the air and wires join together or that the hose would kink at that point?
                      Here's a pic with the hose removed. I just see wires inside that I'm guessing is normal.
                      How would I remove the hose at the front to check for blockage? Does it just twist off? I tried but it wouldn't budge
                      • caphair
                        • Nov 2011
                        • 1249
                        #71
                        I even tilted the reservoir? white tank to relief the kink of the hose coming off it but there was no noticeable difference
                          • Jul 2011
                          • 6070
                          Over time of use the volume of vacuum or air supply slowly decrease
                          I have not found a way to repair them
                          • capwizard
                            • Jun 2016
                            • 1991
                            You will need a vacuum pump.
                            https://okelectronic.wordpress.com/2013/04/
                            My suggestion is this one. (picture 1)
                              • 31256
                              for a blower??
                              lol
                              what may be interesting, but financially questionable:
                              convert it with a new handpiece with a fan in it.
                              only problem, the fan is 12 or 24v and the original pump isnt.
                              • caphair
                                • Nov 2011
                                • 1249
                                #75
                                Good to know. I'll just live with it for now I guess.
                                • caphair
                                  • Nov 2011
                                  • 1249
                                  #76
                                  for a blower??
                                  lol
                                  Don't the models with the fan in the wand have weaker airflow?
                                    • 31256
                                    weaker? as in pressure, or flow?
                                    either way, i dont see why it would matter - i use mine at about 20-25%.
                                    dont be a Rossmann, dont blow your smd across the desk!!
                                    new video out today - i call it - the flying sub-module!!
                                    https://www.youtube.com/watch?v=vBaaa-aajiM
                                    • caphair
                                      • Nov 2011
                                      • 1249
                                      #78
                                      Pressure mostly. I like to use higher air lower temp. Found out it’s safer for most things. Or maybe that’s just how I learned
                                        • 31256
                                        pressure - unknown.
                                        you would need some type of restrictor and flow meter to know that.
                                        • caphair
                                          • Nov 2011
                                          • 1249
                                          #80
                                          pressure - unknown.
                                          Flow then lol
                                            ZD desoldering station pump rebuild
                                            by stj
                                            just did one.
                                            works great.
                                            so here's the discoveries.
                                            the pump "modules" have 4 parts, the main body, the outside bit, the inside bit - screwed to the main body, and the diaphram.
                                            the failure is the inside bit, it has a rubber coating for some reason that becomes tacky and breaks down - contaminating the diaphram.
                                            so you need to clean everything to get rid of all the tacky black stuff.
                                            then reassemble it.
                                            *BUT*
                                            you must put the 2 screws into the assembly only finger-tight.
                                            if you tighten it properly the valves dont work....
                                            08-21-2024, 05:59 PM
                                            HP Station de travail Z2 format tour G4 i7-8700 Specification for Upgrade or Repair
                                            This specification for the HP Station de travail Z2 format tour G4 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Station de travail Z2 format tour G4 boardview and Station de travail Z2 format tour G4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                            09-12-2024, 02:20 PM
                                            MSI Gaming GF66 11UG-820FR Katana Dragon Station Notebook GF Specification for Upgrade or Repair
                                            This specification for the MSI Gaming GF66 11UG-820FR Katana Dragon Station Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GF66 11UG-820FR Katana Dragon Station boardview and GF66 11UG-820FR Katana Dragon Station schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
                                            09-07-2024, 05:20 AM
                                            HP EliteBook 840 G6 + UltraSlim Docking Station Notebook 800 Specification for Upgrade or Repair
                                            This specification for the HP EliteBook 840 G6 + UltraSlim Docking Station Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G6 + UltraSlim Docking Station boardview and 840 G6 + UltraSlim Docking Station schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                                            09-06-2024, 06:00 PM
                                            09-06-2024, 12:30 PM
