Hot Air Station - Air Pump Failing
    • 31255
    Re: Hot Air Station - Air Pump Failing
    flow is probably higher - it's a blower right behind the element - not like trying to push the air down a cramped hose first.
    • caphair
      • Nov 2011
      • 1249
      #82
      Just an update. The replacement pot failed yesterday. Didn’t last nearly as long as the original.
      Symptoms were no air flow until fully on (same as original failure)
      However out of circuit it measured smoothly in ohms range.
      Is it normal for a pot to measure good but in circuit fail with current running though it?
        • 31255
        no, but you dont normally have much current flowing through pots - that's when you use a wirewound/reostat type.
        how much current is yours being subjected to?
        • caphair
          • Nov 2011
          • 1249
          #84
          Not sure to be honest
          • Agent24
            I see dead caps
            • Oct 2007
            • 5080
            • New Zealand
            #85
            It's not common but yes, some bad components will test OK but fail under load. Try a new potentiometer. You might have just got unlucky.
            Can you get a brand name one from Digi-Key instead of some generic thing from Amazon?
            Also check, it's not perhaps some issue with the way it's mounted? Some pots may not isolate the wiper from the shaft, and if the body is mounted to a metal chassis that's also connected somewhere, like ground, you can get weird problems.
            The original pot didn't have a plastic body, did it?
            -David VanHorn
            • redwire
              • Dec 2010
              • 3912
              If this is the same mains AC dimmer circuit as in post #65, and the pot checks out, then the triac is suspect. It might have low sensitivity, needs high gate current to get it's lazy ass on.
              I had a similar problem, first the pot went intermittent due to low quality chinese build. The carbon had cracked and it was sparking. I replaced it, added a series resistor... and after a month the triac gate shorted. It is possible a dud triac burns out the potentiometer, if it does not have a series resistor to limit current.
              The potentiometer is typically a big 1W or 2W part for some reason.
              • caphair
                • Nov 2011
                • 1249
                #87
                I replaced the pot and it’s been working fine since but weird when testing with a meter that I didn’t spot any hiccups in it.
                  ZD desoldering station pump rebuild
                  by stj
                  just did one.
                  works great.
                  so here's the discoveries.
                  the pump "modules" have 4 parts, the main body, the outside bit, the inside bit - screwed to the main body, and the diaphram.
                  the failure is the inside bit, it has a rubber coating for some reason that becomes tacky and breaks down - contaminating the diaphram.
                  so you need to clean everything to get rid of all the tacky black stuff.
                  then reassemble it.
                  *BUT*
                  you must put the 2 screws into the assembly only finger-tight.
                  if you tighten it properly the valves dont work....
                  08-21-2024, 05:59 PM
                  HP Station de travail Z2 format tour G4 i7-8700 Specification for Upgrade or Repair
                  This specification for the HP Station de travail Z2 format tour G4 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Station de travail Z2 format tour G4 boardview and Station de travail Z2 format tour G4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                  09-12-2024, 02:20 PM
                  MSI Gaming GF66 11UG-820FR Katana Dragon Station Notebook GF Specification for Upgrade or Repair
                  This specification for the MSI Gaming GF66 11UG-820FR Katana Dragon Station Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GF66 11UG-820FR Katana Dragon Station boardview and GF66 11UG-820FR Katana Dragon Station schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
                  09-07-2024, 05:20 AM
                  HP EliteBook 840 G6 + UltraSlim Docking Station Notebook 800 Specification for Upgrade or Repair
                  This specification for the HP EliteBook 840 G6 + UltraSlim Docking Station Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G6 + UltraSlim Docking Station boardview and 840 G6 + UltraSlim Docking Station schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                  09-06-2024, 06:00 PM
                  09-06-2024, 12:30 PM
