Ideas to modify a 12v air pump to pump high pressures
  • caphair
    • Nov 2011
    • 1249
    I have a 12v car air pump that you plug into the “cigarette lighter” socket (12v socket)
    It works fine for pressures up to 50 psi but anything over it starts pulling a lot of current and blows the fuse.
    First thing I tried was powering it off an old pc power supply at the 12v supply. This works well for pressures up to 80-90psi then it trips the power supply and turns it off.
    The pump says 250psi on it but clearly it's not able to output that much.
    My question is, could I add a capacitor across the motor leads to give it a boost that will let it pump out more air under pressure?
    I'm trying to use it to fill bicycle tires that require 115psi and was hoping to modify the pump to do that
  • R_J
    • Jun 2012
    • 9594
    Re: Ideas to modify a 12v air pump to pump high pressures
    How much current does it draw? what was the rating on the fuse it blew? you could connect it straight to the car battery and see if it will pump up to higher preasures, but I suspect the motor itself is on its way out.
    I checked on google for 12 volt 250 psi compressors and a lot of people say they are a pos and not getting anything close to that preasure.
    I found a (FBA_Kensun-AirComp-D1002) brand and it requires 10 amps.
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8701
      Also make sure the pump is mechanically in good shape, oiled, etc.
      My small shop compressor can't even get to 250PSI, though it gets to 115 fine.
        • 31214
        these things are a joke once you get the plastics off and actually see the tiny piston.
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8701
          The tiny piston really doesn't mean much, actually it's easier to get up to higher pressures with a tiny piston due to the physics involved - except it takes much longer to compress. The motor needs to turn faster if you want it to compress faster. However this means loss from friction is higher and you need to make sure it's well lubricated.
          • caphair
            • Nov 2011
            • 1249
            @R_J not sure how much current it uses. But the fuse that blew was a 10amp
            I used it last summer hooked to a old pc power supply and it worked fine up to the pressure I needed but would slow down and struggle.
            When I tried using it yesterday the max it would output was 80 psi
            Would placing a magnet on the motor help at all? Capacitor idea no good?
            • R_J
              • Jun 2012
              • 9594
              You could check the brushes and see if they are worn, a magnet won't help and neither will a cap. a cap across might help if it had a hard time starting, but if the source can't supply enough current to run the compressor motor it won't keep the cap charged either.
              It could also have worn bearings (if even uses bearings and not just bushings).
              • caphair
                • Nov 2011
                • 1249
                I'll check. I was thinking using a cap since it seems to have a hard time starting at higher pressures. Once it has momentum it'll keep going then slowly slow down and stops
                • R_J
                  • Jun 2012
                  • 9594
                  Hook it direct to your car battery, if it won't run from there a cap wont help
                  • goontron
                    5000!
                    • Dec 2011
                    • 4108
                    • US
                    Yeah, when that motor burns up, that 600+ CA ought to make for a nice show. I'll bet it makes it to 115PSI... Once.
                    Follow the white rabbit.
                    • caphair
                      • Nov 2011
                      • 1249
                      What type of grease should I use on the gears? Will try that first
                      • R_J
                        • Jun 2012
                        • 9594
                        and you think the motor is going to draw 600 amps just because the battery can supply it. I would think it would be obvious to not leave it conected if it is slowing down and going to stall.
                        • R_J
                          • Jun 2012
                          • 9594
                          I don't know, I'm sure whatever I suggest someone will come up with some reason its wrong
                          • eccerr0r
                            Solder Sloth
                            • Nov 2012
                            • 8701
                            Probably doesn't matter way too much on gears, but if they're clean, probably don't worry about greasing them. Worry about the bearings and possibly the compression chamber. Compression chamber lubrication will depend on what the seal is made of...
                            Speaking of compressors, I also have one of these mini compressors which work fine for car tires (though is extremely slow, hence I tend to use my shop compressor). Now how to test its upper end... I don't have a bike tire that I can pump to 115PSI, so I'll need a jig of some sort, perhaps if I can pump into my shop compressor's tank, which will take forever with the puny piston...
                            Last edited by eccerr0r; 02-22-2018, 05:32 PM. Reason: testing my own mini compressor...
                            • goontron
                              5000!
                              • Dec 2011
                              • 4108
                              • US
                              Well, when you have seen the needle on a 1200 Amp meter on a bank of 3 batteries parallel get pegged, caused by a 12v bilge pump burning up, all in the mater of 3 seconds or so, you tend to see these things as "record it when you do it, because it's going to be a show"
                              • Sparkey55
                                • Jan 2010
                                • 1523
                                I have to agree with goontron also. Bypassing the original 10 amp fuse is dangerous. If a short develops the smallest gauge wire (witch in this case is most likely to be the motor winding) would be the new fuse.
                                These types of pumps are rated for use with a duty cycle of about 10 minutes ON and 20 minutes OFF. anymore than that is risking it.
                                • redwire
                                  • Dec 2010
                                  • 3912
                                  It's chinese 250psi, so useable to much less.
                                  I think the motor is simply too small. Once loaded heavy, the motor's efficiency drops off and if the magnets are not strong enough the motor just cooks.
                                  You would need a slower motor (or smaller piston pump) to do the same amount of work (generate 115psi).
                                  In the good old days, these 12V compressors "Grasshopper" used a 1960's Ford windshield wiper motor, and just chugged along at 115psi. But massive in size compared to these toy compressors.
                                  • eccerr0r
                                    Solder Sloth
                                    • Nov 2012
                                    • 8701
                                    Not sure if it also takes into account that older PM motors are likely using alnico or some other iron based magnets, and newer ones may be using neodymium magnets, which will reduce size. But yes if it's loaded down to stop, that compressor is done.
                                    I don't know what the gearing is like on compressors too, to reduce costs, direct drive is preferred of course.
                                    I tried playing with my Campbell Hausfeld mini compressor. It's so cheap it doesn't have a pressure gauge. I hooked it up to my "big" bench psu and measured it drawing 4A @ 13.8V (btw, increasing voltage may help it pump but at risk of quicker overheating of windings). I also seem to be able to block off the pressure with my thumb, and during which it draws 10A. If I'm pressing 5lbs (I'm not sure how much pressure I'm actually holding against that hole however), that's the equivalent of about 200PSI which means that this thing is under the spec of 250PSI or my finger is pushing more than 5lbs. However the compressor continues to spin, it doesn't stop...
                                    Sorry I'm not converting pressure/weight to SI, I write the imperial units for you convert to SI you SI nuts
                                    Last edited by eccerr0r; 02-22-2018, 07:16 PM. Reason: added detail that I couldn't stop the motor, but could stop the air
                                    • R_J
                                      • Jun 2012
                                      • 9594
                                      Caphair: did it blow the fuse in the cigar plug attached to the pump or was it the fuse that protects the lighter plug?
                                      I thought it blew the fuse in the ligter plug in the vehicle and NOT the fuse in the cigar plug, thats why I said to connect it direct. Also the wiring to the vehicle plug could be too light to run the pump, thats why it worked better connected to the power supply.
                                      • caphair
                                        • Nov 2011
                                        • 1249
                                        It blew the lighter plug fuse in the car
                                        • Dannyx
                                          Remote pump control ideas.
                                          by Dannyx
                                          Good day folks. A task was given to me to redesign the control system for a pump system in a remote location. The idea is that there's a tank which has a float or some sort of switch/sensor to detect when it's full/empty and this runs some pumps accordingly. The trouble is the pump and the tank are like 4km apart, from what the chap who inspected them on our behalf told me, so the way this currently works is by using some unknown boards based on SIM cards (see the pictures). From what I can assume, when a contact closes at the "client side" (the tank), it calls up the "server side"...
                                          09-11-2020, 04:10 AM
                                        • jm1234
                                          Siemens dryer iQ800 WT48Y780EU
                                          by jm1234
                                          I'm looking for ideas on how to aproach this, I spent many ours already.
                                          The dryer doesn't get hot, only warm and then gives error E25 (Fault with the sensor or electronics detected).
                                          Now I'm testing it using the service mode - it gets the temperature of the heat pump liquid to 52C and then it stops the heat pump. After few minutes it then produces E25.
                                          I tried to understand if it stops the testing because the final temperature was reached and I don't think that's true. While it was running, I heated that sensor using hot air to 80C and then it stopped. So I think the...
                                          04-12-2024, 06:24 AM
                                          ZD-915 vacuum pump motor mount service alert
                                          If you have this Desoldering Gun Station there is something you should be aware of the two screws that hold the motor to mounting for pump can come loose and make raddling noise
                                          One note this unit has been repaired already once because of switching power supply regulator ic chip failure
                                          Now this with the vacuum motor mounting issue yes I give this Desoldering station a very hard work out and use about every weekend to do some type of project
                                          The fix is taking the vacuum pump assembly out and take the metal cover off and you will see the two screws on it
                                          09-19-2021, 02:15 AM
                                          Is there any high current pouch battery that are size 60mmX80mm maximum thickness 21mm for a battery operated tab welder
                                          I have a battery operated tab welder and the battery does not have enough current for the battery tab welder because after about 30 welded it does not have the same current output it voltage has gone down by at least 0.500 volts or maybe a more than that
                                          I can fit 21700 battery cells in the enclosure it is very tight fit for four of them that are 35 amp high current capacity 35X4=140 high current output this should work a lot better than what is installed right now
                                          I tested the battery cells there are installed right now and they are testing good with no issues that I...
                                          02-04-2025, 08:08 PM
                                        • harp
                                          high voltage high resistance marking resistor
                                          by harp
                                          Is there any reason why high voltage high resistance resistor use weird marking and value on it? Standard nomenclature, EIA value not used?...
                                          08-26-2024, 01:42 PM
