Ideas to modify a 12v air pump to pump high pressures
    master hoarder
    • May 2008
    • 12175
    #41
    Re: Ideas to modify a 12v air pump to pump high pressures
    Originally posted by caphair
    Thanks for this. So the poor connection on the motor, did it cause a voltage drop and thus a lower stall current?
    Yes, the poor connection caused the motor to see a lower voltage, which also means lower stall current and thus also lower maximum output torque. With the maximum torque being lower, it's possible that the motor kept being stalled or used in a very inefficient state. And the thing about DC motors is that their stall current is usually much much higher than their optimal running current. So even though the voltage was lower, it's possible that the motor drew more current (than normal / in optimal state) in order to output the same torque as before that the pump requires.
    So again, the motor didn't draw more current because it was trying to make up for the lower voltage. Rather, it was drawing more current because it was trying to output the requested torque going to the pump.
    • caphair
      • Nov 2011
      • 1249
      #42
      What determines the output torque? Just the general construction of the motor? Windings?
        master hoarder
        • May 2008
        • 12175
        #43
        Correct.
        The maximum stall current is dependent on the resistance of the rotor windings. And the rotor windings are affected by rotor size. That is, the rotor size determines how much copper will fit on it - i.e. a choice between wire thickness and wire length (number of turns).
        The rotor's physical specs also affect the torque and speed (i.e. you can have the same wire thickness and length for the rotor, but you will get different torques depending on if you have a "fat" short rotor or a "skinny" long one... or something in between.)
        Then there's the number of rotor elements. The small/miniature DC motors usually have 3. More sophisticated and expensive DC motors usually have more.
        And finally, there's also the stator. For a permanent magnet motor, bigger stator magnet size = higher torque, lower maximum no-load speed. Magnet composition also matters (ceramic/ferrite vs. Neodymium vs. other composition). With universal motors (DC motor capable of running on AC - i.e. motors in regular wall-powered vacuum cleaners, some washing machines, and corded drills), the stator windings specs/size will also matter just like for the rotor's.
        • Dannyx
          Remote pump control ideas.
          by Dannyx
          Good day folks. A task was given to me to redesign the control system for a pump system in a remote location. The idea is that there's a tank which has a float or some sort of switch/sensor to detect when it's full/empty and this runs some pumps accordingly. The trouble is the pump and the tank are like 4km apart, from what the chap who inspected them on our behalf told me, so the way this currently works is by using some unknown boards based on SIM cards (see the pictures). From what I can assume, when a contact closes at the "client side" (the tank), it calls up the "server side"...
          09-11-2020, 04:10 AM
        • jm1234
          Siemens dryer iQ800 WT48Y780EU
          by jm1234
          I'm looking for ideas on how to aproach this, I spent many ours already.
          The dryer doesn't get hot, only warm and then gives error E25 (Fault with the sensor or electronics detected).
          Now I'm testing it using the service mode - it gets the temperature of the heat pump liquid to 52C and then it stops the heat pump. After few minutes it then produces E25.
          I tried to understand if it stops the testing because the final temperature was reached and I don't think that's true. While it was running, I heated that sensor using hot air to 80C and then it stopped. So I think the...
          04-12-2024, 06:24 AM
          ZD-915 vacuum pump motor mount service alert
          If you have this Desoldering Gun Station there is something you should be aware of the two screws that hold the motor to mounting for pump can come loose and make raddling noise
          One note this unit has been repaired already once because of switching power supply regulator ic chip failure
          Now this with the vacuum motor mounting issue yes I give this Desoldering station a very hard work out and use about every weekend to do some type of project
          The fix is taking the vacuum pump assembly out and take the metal cover off and you will see the two screws on it
          09-19-2021, 02:15 AM
          Is there any high current pouch battery that are size 60mmX80mm maximum thickness 21mm for a battery operated tab welder
          I have a battery operated tab welder and the battery does not have enough current for the battery tab welder because after about 30 welded it does not have the same current output it voltage has gone down by at least 0.500 volts or maybe a more than that
          I can fit 21700 battery cells in the enclosure it is very tight fit for four of them that are 35 amp high current capacity 35X4=140 high current output this should work a lot better than what is installed right now
          I tested the battery cells there are installed right now and they are testing good with no issues that I...
          02-04-2025, 08:08 PM
        • harp
          high voltage high resistance marking resistor
          by harp
          Is there any reason why high voltage high resistance resistor use weird marking and value on it? Standard nomenclature, EIA value not used?...
          08-26-2024, 01:42 PM
