Component identification
  • halfloaf
    • Dec 2017
    • 20
    • Uk
    I have a component I need to replace on a PCB of a very old custom graphics card for an SGI machine. I've managed to take a picture of an intact one, does anybody know what this is and how I can spec a replacement?
    The part looks like a very small fuse but with a metal half loop cage around it. The cage is soldered to the PCB as well as the ends of the insulated section. On the broken part I can see a copper wire connecting the two ends. The metal cage is just that, metal. L511 on the board
    Thank you.
  • petehall347
    • Jan 2015
    • 4448
    • United Kingdom
    Re: Component identification
    L is designation for a coil
    • R_J
      • 9621
      I suspect it is used as a small filter, basically a wire coil with a ground shield around it, made by MuRata maybe?
      https://www.murata.com/~/media/webre...ifil/c31e.ashx
      • halfloaf
        • Dec 2017
        • 20
        • Uk
        Thanks! From googling it seems to be the MuRata feed through capacitor used as an EMI filter as you've suggested. Question is, how do I go about measuring the capacitance of the one on the board? They seem to come in a few pF ratings.
        • R_J
          • 9621
          I don't really know, I doubt they are that critical, try measure the capacity from one end to the center.
          • petehall347
            • Jan 2015
            • 4448
            • United Kingdom
            why do you suspect as faulty ?
            • halfloaf
              • Dec 2017
              • 20
              • Uk
              Hi, the other one on the board is smashed to bits. Seems like it was knocked, the one end has come off the board, the ceramic and coil winding have been broken as well.
              • R_J
                • 9621
                The parts from digikey are only $1.00 each, get a couple different values and try them.
                • halfloaf
                  • Dec 2017
                  • 20
                  • Uk
                  Thank you for your help.
                  I've managed to source a replica PCB in non-working state, I'll pull one from the donor board as there are about 5 on each board. These aren't usually the culprits when these boards fail, it's most likely the old style IBM compression connectors that get damaged.
                  Failing all this I'll just buy a few new ones.
                  Thanks again.
                  Picture of broken filter below...
                  • Shane711
                    • 493
                    I have a part I can not identify. It says XTL on the circuit board. Here are some pictures. Does anyone know what this is? I am guessing it is a crystal or oscillator. But if so I need to know it's value so I can order some. It has 3 legs.
                    • eccerr0r
                      Solder Sloth
                      • Nov 2012
                      • 8706
                      what's the bottom of the board look like, what's this being used in?
                      Three pin crystals are usually crystal filters, which are normally only found in radio equipment. There are some crystal resonators that are used in lieu of crystals for oscillators. This one appears to be 8MHz which is strange for radio use. What makes you think it's broken?
                      • R_J
                        • 9621
                        It's an 8Mhz 3 terminal ceramic resonator with built-in load capacitors
                        PDF for Murata brand https://www.murata.com/~/media/webre...lock/p17e.ashx
                        • Shane711
                          • 493
                          Awesome, so glad I got some answers. Well it is on a main board for a GE microwave. The reason I suspect it to be bad is because it is located next to 3 resistors that get very hot. All the capacitors near the resistors are fried from the heat and after replacing all the capacitors on the board the display still flickers but before replacing the capacitors the microwave was completely dead. So I suspect this part is bad because I can confirm all the other parts are good. And I test all my capacitors before installing them for correct value and ESR. from what I can see online, this part is responsible for creating the microwaves but could also be the cause of the flickering display.
                          • Shane711
                            • 493
                            I now need to know the value of the internal capacitor. Would help to know the manufacture as well. I guess the brand is Murata.
                            • R_J
                              • 9621
                              That part is the oscillator for the microprocessor ic It has NOTHING to do with creating microwaves. If you are getting any display at all the part is ok. The microwaves are created from the magnatron NOT from that ceramic resonator/crystal.
                              post pictures of the board and the model number
                              You really need to be carefull when working on microwave ovens, there is over 2 KILLovolts on the capacitor for the high voltage to the magnatron
                              • Shane711
                                • 493
                                I know it does not create the microwaves but it might have something to do with the frequency that makes the magnatron work, anyway that is what I believe I read in the datasheet. As far as if the part is bad or not I will know in the next few weeks as I have a bunch of these microwaves to test on. You might be right about it not being the problem but I will figure it out no matter what part is bad.
                                • R_J
                                  • 9621
                                  It has NOTHING to do with the frequency of the microwaves either. The frequency is determined by the magnatron at approx. 2.45 Ghz.
                                  If you do something wrong you could expose the people using this mwo to harmfull radiation.
                                  These ovens need to be tested for proper operation (shutdown when door is opened) and have a leakage test done after working on them.
                                  • howardc64
                                    by howardc64
                                    Problem
                                    08-04-2024, 10:36 PM
                                  • questore
                                    nvme and wifi error after liquid metal spill
                                    by questore
                                    Someone brought me a liquid metal damaged motherboard.
                                    First I have removed alll liquid metal from the board.
                                    0,75V_ALW was burned, and had to be removed and I have separated the layers until no short was on the VIN (B+) line and the output is no longer shorted.
                                    Applying 0,77V on the output with my lab PSU make the laptop caming on and i running windows from USB drive SSD
                                    There are 2 things that not working.
                                    1. The WIFI card keeps turning off and on with an error code 43 and 10 abouth every 10 seconds
                                    2. nvme devices are not detected on either of the 2 slots....
                                    11-11-2025, 01:16 AM
                                  • silver60618
                                    How to clean Liquid Metal from under CPU?
                                    by silver60618
                                    Hi all, Im working on a board, that my customer brought to another shop, and smeared liquid metal all over the board.
                                    The laptop powers on, then shuts off. I noticed traces of Liquid Metal near the edge of the CPU, but I fear some maybe underneath.
                                    Has anyone ever tried Ultrasonic cleaning, or compressed air to remove or agitate the liquid metal?
                                    07-11-2025, 01:47 PM
                                  • Shulgin
                                    Acer predator XB241YU Component identification
                                    by Shulgin
                                    I have a problem with my Acer predator XB241YU screen. When I plug it in, the startup LED turns on instantly, and I can't turn off the screen without unplugging it.
                                    After disassembly and inspection of the electronic cards I found what looks like a broken inductor, it is marked with the letter A and is at location L58.
                                    In the first photo you can see the broken component, in the second photo you can see where it is on the board, in the third photo you can see the silkscreen and in the fourth photo you can see the identification sticker of the main board
                                    I...
                                    05-11-2024, 11:06 AM
                                  • thebomb602
                                    ASUS GA402R IC identification
                                    by thebomb602
                                    Hey guys! my name is kyle, new to motherboard troubleshooting and a little confused still on chip identification if yall could help identify this chip..
                                    also if you could teach me how to fish on this particular topic... i did read through the ic identification sticky, and couldnt identify this with that info... thanks!
                                    EDIT, just realized thats a 5 and not an S in the first line... finding results for it now. cant figure out how to take down thread so im not embarrassed...
                                    11-21-2023, 02:30 PM
