Apple says older devices slow down due to batteries not iOS updates (yeah OK)
  • caphair
    • Nov 2011
    • 1249
    Here’s one of many articles about this:
    https://www.google.com/amp/s/www.cne...attery-issues/
    I think it’s such bs and we can all agree that older batteries are not what causes an older device that was running smoothly on the software it was designed to handle to suddenly become slow and sluggish when updated to a newer iOS
    That’s like saying a PC designed for windows 95 will run windows 10 no problem by simply swapping out the power supply for a newer one
    • 31258
    Re: Apple says older devices slow down due to batteries not iOS updates (yeah OK)
    downgrade the firmware - next time dont buy apple junk.
    • goontron
      5000!
      • Dec 2011
      • 4108
      • US
      Originally posted by caphair
      I think it's such bs and we can all agree that older batteries are not what causes an older device that was running smoothly on the software it was designed to handle to suddenly become slow and sluggish when updated to a newer iOS
      I Think that read wrong.
      Apple claims they slow down devices in firmware updates to PRESERVE battery life. So, no, nowhere near the "replace the PSU in a 95 machine" Analogy you made. The battery doesn't slow it down. Apple slows it down because of the battery.
      They are still arses for doing this, and its most likely all bullshit. I mean, if they really where doing this for battery life, they would have it in a setting somewhere.
      "Hey, this update is a bloated pig that will kill your battery fast because it pegs the CPU. Do you want to enable a permanent battery saving mode or deal with a 2 hour battery life?
      < Enable power save> <cancel>
      Follow the white rabbit.
      • caphair
        • Nov 2011
        • 1249
        Even still a new battery won’t make the phone any faster on software that’s meant for newer hardware.
        Even with a new battery the phone responds noticeably slower on newer software that rolls out every year with the newer model
        • goontron
          5000!
          • Dec 2011
          • 4108
          • US
          ^ Yes. hence why it's BS. They claim battery, yet don't even check the age of the cells.
          • caphair
            • Nov 2011
            • 1249
            From what I've read it says the software checks the charge cycles and uses that to determine the battery's age
            But what about people who have a lot of charge cycles due to charging their phones when battery is above 50% which helps lithium ion last longer.
            Battery would have good health but indicate a lot of charge cycles
              • Jul 2011
              • 6070
              I do not think this is right for Apple to do this kind-A-nonsense and they need to get real
              Ask us if want to add this update to stop this type of freezing up do to maybe the battery being week or not
              • vinceroger69
                • Mar 2012
                • 6714
                https://www.theguardian.com/technolo...-older-iphones
                • caphair
                  • Nov 2011
                  • 1249
                  Only a matter of time lol
                  This statement “When the processor demands more current than the battery can supply, the phone abruptly shuts down to protect its internal components, as was the case with the iPhone 6S forcing Apple to replace
                  Wouldn't this just decrease on time before needing a charge? They make it sound like when it demands more current it's causing damage to the phone
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    i asked jessa at ipad rehab this question regarding this topic she says shes going to be doing a video soon
                    • eccerr0r
                      Solder Sloth
                      • Nov 2012
                      • 8703
                      I think the argument is plausible but underhanded. This should be an OS option to choose whether to accept lower battery life or slower operation.
                      I would think most li-ion applications have a battery management IC that keeps track of battery health and could make adjustments automatically. It should know if a battery is worn or not, so if someone was babying or not using the battery as much versus abusing the battery, it should know.
                      The question is if *all* old iphones of a specific model, regardless of battery abuse, run the same speed. If this is the case, then apple's explanation is wrong, and this is a cause for outrage. And if it's not, regardless, it's still very underhanded as some people don't mind recharging if things still run at the same speed.
                      I first heard of this over NPR and the explanation I heard over NPR made no sense... crappy reporting. Boo.
                      • caphair
                        • Nov 2011
                        • 1249
                        Yes same here I heard different explanations which confused me at first which is why I thought they were saying an old battery makes a phone run slow lol I was like huh?!?
                        I don’t understand why Apple would even make mention of this. I mean if they’re going to screw people over why even give out an explanation (and one that clearly didn’t help them)
                        Unless they were hoping for extra revenue through battery replacements from people who weren’t upgrading their device
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          i think as you say they may be thinking of extra revenue through replacement battery's
                          • eccerr0r
                            Solder Sloth
                            • Nov 2012
                            • 8703
                            I thought most iphones have batteries that can't easily be replaced anyway, so they just want people to buy new phones out of warranty...
                            Underhanded and sleazy.
                            No apple crap for me.
                              • 31258
                              apple is like scientology - it's a cult that wants your money!
                              • caphair
                                • Nov 2011
                                • 1249
                                They’re releasing an iOS update 11.3 in the spring to address it
                                “Apple’s next major update of its mobile software will include an option that will enable owners of older iPhones to turn off a feature that slows the device to prevent aging batteries from shutting down.
                                The free upgrade announced Wednesday will be released this spring.”
                                What good is that now when people were forced to upgrade their devices due to them being too slow lol
                                • RJARRRPCGP
                                  • Jul 2004
                                  • 6304
                                  While Motorolas are notorious for reprimanding folks who merely use a charger that's not an "official" one...
                                  (id chip in charger???)
                                  My Moto e4 may be going bye bye bye! An id chip in the charger would be a problem!
                                  Samsung don't do that kind of bullshit, IIRC...
                                  ASRock B550 PG Velocita
                                  Ryzen 9 "Vermeer" 5900X
                                  Arc A770 16 GB
                                  eVGA Supernova G3 750W
                                  Alienware AW3423DWF OLED
                                  • goontron
                                    5000!
                                    • Dec 2011
                                    • 4108
                                    • US
                                    ^ Eh, what? I have a Moto G4 that happily charges on a USB data cord chopped up and soldered to the 5v rail of a router....
                                    • RJARRRPCGP
                                      • Jul 2004
                                      • 6304
                                      I suspect that, because apparently Android Nougat tells me that it would charge faster with the original charger or cord. Is that just a bullshit generic message from Android???
                                      Arc A770 16 GB
                                      • dmill89
                                        • Dec 2011
                                        • 2534
                                        It is a generic android message when you use a lower amperage charger or thinner gauge USB cord that doesn't allow the phone to pull its maximum amperage draw. My Moto e4 doesn't give me that message with a "normal" gauge aftermarket micro-USB cable or aftermarket charger with an output of 1A or more (the factory charger that came with mine is 2A, but some e4s ship with a 1A charger), but does give the message with a retractable micro-USB cable (much thinner wire) or a aftermarket charger with an output of less than 1A, my old LG Optimus Zone 2 did the same (though it came with a 0.85A charger so it only displayed the message on 500mA [0.5A] or less aftermarket chargers).
                                        • a_p3rson
                                          Apple Watch Charging Controller Schematics / Boardview - 820-02601
                                          by a_p3rson
                                          Hi there,
                                          I'm looking for anyone who might have information on Apple's embedded Apple Watch charging daughterboard, ID 820-02601. This is currently used by Anker in their Apple Watch charging products, but likely by other Apple partner brands as well.
                                          You can see the board referenced in ChargerLab's teardown of the Anker Y1811 3-in-1 MagSafe cube - they discuss the "Apple Watch wireless charging circuit" about 2/3rds down the page. It's not pictured, but the board ID reads 820-02601-A, which sure sounds like Apple.
                                          This daughterboard uses an interesting...
                                          04-21-2025, 11:41 PM
                                        • carrzkiss
                                          Cyberpower cps1500avr not charging batteries
                                          by carrzkiss
                                          Hello, all.
                                          Cyberpower Battery Backup Unit.
                                          I bought two new ML18-12 batteries through Amazon (They have already refunded my money for the two batteries as we thought the batteries might have been bad.)
                                          When I got them in, they were not fully charged. I connected them to the UPS and waited 24 hours before connecting any networking equipment.
                                          In parallel, they read 24v, but within 24 hours, the meter on the front of the unit dropped from 4 to 3 bars on the battery charge indicator.
                                          Checking the voltage, it was down to 22v.
                                          I quickly removed everything...
                                          06-15-2024, 02:10 PM
                                        • jolivares
                                          Black tape in the mainboard inside apple's devices
                                          by jolivares
                                          Hi everybody.
                                          i'm looking for the black tape inside apple's devices.
                                          Is the tape tha covers the shield on the mainboard. when you take it out, loses the adhesive.
                                          It is very thin.
                                          can somenone help me to find it for a better repair?
                                          Thanks, God bless you.
                                          09-09-2024, 08:07 AM
                                          HP ProDesk 600 G5 + Apple AirPods ProDesk 600 i7-9700 Specification for Upgrade or Repair
                                          This specification for the HP ProDesk 600 G5 + Apple AirPods can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + Apple AirPods boardview and ProDesk 600 G5 + Apple AirPods schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                                          09-12-2024, 02:30 PM
                                          HP EliteBook 840 G6 + Apple AirPods Pro Notebook 800 Specification for Upgrade or Repair
                                          This specification for the HP EliteBook 840 G6 + Apple AirPods Pro Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G6 + Apple AirPods Pro boardview and 840 G6 + Apple AirPods Pro schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                          09-06-2024, 07:50 PM
