Use 74LS instead 74HC and 74HCT
  • Tioleco
    • Apr 2010
    • 46
    • Brazil
    I'm going to mount this prescaler but I only have of LS series , can I use it instead of HC and HCT?
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: Use 74LS instead 74HC and 74HCT
    Sure. The power consumption will be somewhat higher (but less so at high frequencies) but since you're already running linear 5V, and with comparable switching speeds, I say try it.
    sigpic
    (Insert witty quote here)
      • 31003
      no, read your datasheets.
      HC is not 100% compatable with LS, HCT is.
      and all 3 have different maximum speeds and drive handling.
      if speed is a problem look at AHC / AHCT series.
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8701
        I don't think speed will be a problem, but likely you will run into a power problem - The PP3 battery and the 78L05 will be woefully underpowered with all LS devices, but using the AC/HC/HCT devices it will be fine.
        • redwire
          • 3906
          The output voltage of the first pre-scaler (divide 128) may not be enough for 'LS02.
          There is an error on the schematic (100R and 2k2, probably missing capacitor there).
          Anyhow, the 1k and 2k2 resistors may need to be changed. The uPB1507 only data is "1.2Vpp output" but no idea of output impedance, so it might not drive the 'LS02 sufficiently.
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8701
            It says it's an emitter follower output... which make sense why a pull down is added. Vp-p seems to imply that's peak to peak voltage/swing voltage and not absolute voltage.
            If it only gets to 1.2V from GND, that's not enough to even flip a 74HCT02 @5V, granted that cap there will help temporarily. The Fujitsu datasheet says it can source up to 10mA but 1.2mA recommended. A 74LS02 only needs 100µA for a high, so that should be fine...
            • redwire
              • 3906
              Emitter-follower output in uPB1506 cannot sink (any) current for an 'LS02 gate input to go low. That logic family needs -1.6mA and <0.8V or a max. 500 ohm pulldown to work.
              For a logic "1" you need >2V at 40uA which is nothing, LS inputs float high.
              OP will have to change the resistor values and see if the pre-scaler puts out more than 2V. Not sure how this works at 27MHz.
              'HC02, 'HCT02 datasheet
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8701
                Another thing that should be changed is that the original schematic wants both inputs tied together, might work better if one input is simply tied low instead, so you don't have to sink as much current. Yeah likely the biasing resistors may need to be changed a bit, but I think it should be possible to solve.
                If you need to swap devices, perhaps leaving the 74HCT02 would be best so you don't have to rebias, and the others should be OK to swap to 74LS161. You'll be near the limits of the switching speed of the LS161 if passed a 3GHz signal, whereas the HC161 has some breathing room.
                • Tioleco
                  • Apr 2010
                  • 46
                  • Brazil
                  The original design uses a MC12079 for input.
                    • Jul 2011
                    • 6037
                    Here is my two cents worth to this
                    If I was doing this project———>
                    I would use the exact parts that it calls for because otherwise it might not work the way it should
                    Let us know how this works when you are finished with this project
                    • japlytic
                      • Oct 2005
                      • 2086
                      74LS/74HCT runs on 5V while 74HC can run on on 3-5V.
                        Surface Mount Fuses Fundamentals Datasheet
                        TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                        TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                        10-07-2024, 06:07 AM
                      • KYBOSH
                        OTHER WORLD COMPUTING OWCTB3DK13PSL OWC 13 Port Thunderbolt 3 Dock - Disconnects when READING from External HD at high speeds
                        by KYBOSH
                        Weird one and way out of my league but I thought i drop it here in case anyone might have an idea on where to start looking.
                        I have a Thunderbolt Dock that has been behaving fine for a long time.
                        Admittedly I have only used it for menial data transfer tasks.
                        A few days ago I connected a USB-C external hard drive to it and wanted to test the transfer speeds.
                        I connected the proper high speed cables (USB-C to USB-C) and started the test with BlackMagic Disk Speed Test.
                        It wrote to the disk just fine. Got nearly 900MB/s+ write speeds but when it came time...
                        07-31-2024, 12:30 AM
                      • dragometin
                        Hitachi 40HYC42
                        by dragometin
                        TV Model: Hitachi 40HYC42
                        Power Supply: 17IPS71
                        MainBoard: 17MB95M
                        Panel: VES400UNDS-2D-NO3
                        When the set came in it was dead. Fuse was open primary side and the power mosfet was shorted. So I ordered a new power supply. Now it turns on, only displays "Hitachi" and then power off red and blue led flashing.
                        I had to modify the 0ohm resistors in the led backlight of the new PS like the original power supply.
                        Is there any variants on 17IPS71 power supply's?
                        UART output pins 10 and 12 on scart connector:
                        Code:
                        12:24:04.595
                        08-08-2024, 05:53 AM
                        TF-FUSE Thin Film Surface Mount Fuses (Very Fast Acting), 0603 Size Datasheet
                        FF Series (Very Fast Acting), 0603 Size
                        Features
                        ● Very fast acting at 200% overload current levels
                        ● Low DCR
                        ● High inrush current withstanding capability
                        ● Fiberglass enforced epoxy fuse body
                        ● Copper termination with nickel and tin plating
                        ● Halogen free, RoHS compliance and lead-free
                        Applications
                        ● Notebook computers and tablets
                        ● Digital cameras
                        ● Memory cards
                        ● Toys
                        ● Bluetooth earphones
                        ● Portable electronic devices​...
                        10-07-2024, 05:50 AM
                      • wolf1976
                        wireless receiver for 6 speeds fan control with remote control
                        by wolf1976
                        hi i have a receiver that is destroyed from the overvoltage i guess
                        my question is has three wires u v w for driving a motor fan i found an other receiver wireless from aliexpresss with the same propertiew but for dc motor
                        the motor fan has not label
                        i have an other receiver operational
                        In your opinion can i measure the voltage at the output ?
                        what do you suggest me with a simple instrument multimeter or using someone instrument more specific ?
                        thanks in advance...
                        07-23-2025, 03:12 PM
