Need a protection circuit
  • EasyGoing1
    Shock Therapist
    • Sep 2016
    • 977
    I have a situation where a battery charger will be destroyed if the battery that it is charging is accidentally connected backwards. So Id like to come up with some kind of circuit that will not allow current to flow from the battery being charged back into the charger if it is accidentally connected backwards. A diode will not work because the voltage drop across the diode is significant enough that the battery being charged will not be charged properly.
    I realize that people will question the application and wonder why this or why that, but I've been through all that, I just need to know if there is something out there or some kind of circuit I can apply to this function that will produce the results I am looking for.
    I have attached a small simple diagram.
    Thank you,
    sigpic
  • petehall347
    • Jan 2015
    • 4427
    • United Kingdom
    Re: Need a protection circuit
    diode across charger output . fuse on plus wire .
    like this . choose suitable diode and fuse .
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8701
      Technically just a fuse is enough, there will be a lot of current flowing if you connect it backwards that will be easy to blow a fuse. It also helps against shorted charger output/shorted battery. However I don't know how sensitive that charger is to self destruction if you reverse connect.
      I accidentally hooked up my car charger to my car battery wrong, yeah that was a lot of current. I noticed it right away and fixed it, luckily no damage.
      I noticed in one of HFT's battery chargers that it had an intricate polarity detector and would cut off the charge if it were hooked up backwards - mostly to protect the battery from getting reverse charged, not protecting the charger. I suppose most of today's smart chargers can completely disconnect the charge outputs, likely via MOSFETs, and test the terminal connections with a voltmeter before attempting to charge.
      • NeedsMoreFlux
        • Oct 2017
        • 121
        • California
        I have a ton of diodes laying around.
        If you want I can check to see if I have a 5408 in my pile and mail it to you.
        Let me know.
        Disclaimer: Don't trust a thing I say-I am frequently wrong!!!
        I have tons of spare parts, some used, some N.O.S. ham transistors and caps. Message me if you need any parts.
        Some of the things I've fixed:
        60" Vizio-bad LED's. iBook G4: Resoldered VCC Plug. Geo Tracker ECU: Swollen / Leaking capacitors. Windows Laptop: Soldered broken LVDS wires. Dryer: Burned contact on temp switch. Oven in R.V.: Bad contacts in relays-Exploded by the looks of them! Samsung Oven: Burned contacts on Relays. MSI Motherboard: BSOD-Swollen capacitors, bad graphics card, Moved SATA Input from SATA 1 to SATA 2 plug
        • EasyGoing1
          Shock Therapist
          • Sep 2016
          • 977
          Interesting ... Perhaps a resettable fuse would be sufficient. The charger is one of those inexpensive TP4056 LiIon chargers ... They fry pretty quickly when you connect the battery backward but if the fuse is fast enough, I'm sure it would protect it. Im curious does the diode serve to divert the current away from the charge ciurcuit?
          sigpic
          • EasyGoing1
            Shock Therapist
            • Sep 2016
            • 977
            The charge circuit is a TP4056 ... they fry pretty quickly if the battery has enough charge on it when you connect it backward. I've connected batteries to them backwards that were too weak to fry it.
            sigpic
            • EasyGoing1
              Shock Therapist
              • Sep 2016
              • 977
              So I found this Texas Instruments N-MOSFET protection circuit and I gave it a shot and it actually works, but for some reason, the MOSFET that I'm using gets super hot while the battery is charging ... not sure why though ... it is, however, hot enough to be worried that it might cause issues depending on what it's resting on. It's certainly too hot to touch without some protection on the skin.
              sigpic
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8701
                You need a low Vth MOSFET for this if you're working with single cell lithium ion batteries, else it just won't turn on hard enough. Plus you need to worry about damaging the gate from static...
                  master hoarder
                  • May 2008
                  • 12175
                  • Bulgaria
                  I don't see how that circuit will protect anything. The body diode in the MOSFET will allow reverse current to flow through it and still damage the charger.
                  Meanwhile, this circuit is simple, but it *will* protect your charger just fine. However, if the diode shorts due to connecting the battery in backwards and you don't happen to notice it, you can end up with a case where the battery gets completely discharged through the diode. With Lithium batteries, that can be dangerous.
                  So here is a slightly safer circuit that I just threw together. It probably can be refined, if anyone cares to do that. It's only downside is that it uses a lot more parts and considerable amount of power from the charger to run its relay. But for multi-cell Lead-Acid and Lithium batteries, this may not be a problem, as they are charged until reaching a constant voltage level per cell. That said, if anyone finds any mistakes, please point them out. So far, I don't see anything obvious.
                  https://www.badcaps.net/forum/attach...1&d=1510117776
                  • EasyGoing1
                    Shock Therapist
                    • Sep 2016
                    • 977
                    And yet I actually tested it by attaching a battery backward and it was fully charged... now SOME current got back to the charger, but it was not enough to damage it.
                    sigpic
                    • EasyGoing1
                      Shock Therapist
                      • Sep 2016
                      • 977
                      I couldn't see this cheap little LiIon charger actually being able to work this circuit and charge the battery ... I like it though ... maybe I could use it in my Arduino LiIon charger project that's been ongoing from time to time as I am able.. :-)
                      sigpic
                      • EasyGoing1
                        Shock Therapist
                        • Sep 2016
                        • 977
                        So the MOSFET Im using is a STP16NF06L
                        sigpic
                          master hoarder
                          • May 2008
                          • 12175
                          • Bulgaria
                          Hmmm... not sure why that is. But again, given the body diode of the MOSFET, I don't think this circuit will work. If it appears to be working, there may be something else going on with your charger that we are not seeing here.
                          Either way, that is still a poor design for the reasons eccerr0r mentioned.
                          Relays typically only require about 1/2 Watts to run, so I imagine most Li-ion batteries should be able to supply that. The only thing that might stop this from working is if your charger is made for charging a single Li-ion cell, as then you will need a relay that is rated to run at that low voltage.
                          That said, you could also have an external adapter to power the relay circuit, and only use the battery and charger to enable the relay logic (which should take only several mA at most). I'll see if I can draw a circuit for that later tonight.
                            http://handstronix.blogspot.com/2017...-teardown.html
                            HT3582DA universal charger control chip.
                            • R_J
                              • 9557
                              Why don't you put a diode in series with the + lead?
                              • petehall347
                                • Jan 2015
                                • 4427
                                • United Kingdom
                                voltage drop maybe ..schottky is pretty low .
                                • eccerr0r
                                  Solder Sloth
                                  • Nov 2012
                                  • 8701
                                  Actually none of these solutions work on the charger side, they all need to be implemented on the device/battery side. I still think it's a design flaw of the charger if it will instantly fry if connected wrong or shorted, but putting the diode/fet on the charger side doesn't quite work... only a fuse *may* work.
                                  Since they all need to be on the device/battery side, then the other option might well be mechanical reversal prevention: don't use alligator clips, use one-way mating connectors...
                                    master hoarder
                                    • May 2008
                                    • 12175
                                    • Bulgaria
                                    There! Attached below.
                                    Just don't call this circuit convoluted.
                                      NVDC charger configuration...
                                      11-05-2024, 03:28 PM
                                    • flat-earther
                                      how to prevent a connected charger from draining battery when not charging?
                                      by flat-earther
                                      I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
                                      So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
                                      but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
                                      So the battery is backfeeding the charger and being drained.
                                      How can I prevent...
                                      08-07-2025, 01:04 PM
                                    • flat-earther
                                      ASUS X54H laptop thinks it's always charging even with charger unplugged
                                      by flat-earther
                                      The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                                      Windows also shows ''Plugged in'' when charger is not connected.
                                      This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                                      Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                                      If I let battery run out and say it has 3% Windows will...
                                      06-24-2025, 09:32 AM
                                    • brispuss
                                      Ryobi 36V (aka 40V) 6Ah Faulty Battery Pack
                                      by brispuss
                                      Purchased a Ryobi 36V 6Ah battery pack maybe just over a year ago.
                                      Battery pack had been used on about 3 or 4 occasions for powering a cordless lawnmower. I was wanting to use this battery pack again recently, but on checking the battery charge state via the battery pack test button, there was no LED indication at all of charge state which suggested the pack was fully discharged.
                                      I found this to be odd as I usually fully recharge battery packs shortly after use. So either the pack developed some sort of fault which completely discharged the pack cells (after recharging),...
                                      12-28-2022, 02:58 AM
                                      ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
                                      Highly Integrated Narrow VDC Battery Charger for Notebook Computers
                                      The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
                                      for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
                                      Narrow VDC applications where the system power source is
                                      either the battery pack or the regulated output of the charger.
                                      This makes the max voltage to the system equal to the max
                                      battery voltage instead of the max adapter voltage. Operating
                                      at lower system voltage can improve...
                                      11-05-2024, 04:43 PM
