555 countdown timer design question
+ More Options
Posts
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    #101
    Re: 555 countdown timer design question
    Originally posted by eccerr0r
    Always faster to find a solution already made instead of building one yourself!
    Was that sarcasm ? Yes, it is easier, but for beginners it's easier to adapt an existing code than trying to create one from scratch - found that myself in the past days. I'm now slowly getting the hang of it and starting to understand how it operates.
    Wattevah...
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8682
      No, that's the way things go... me, see, I still haven't gotten mine out before you found a solution code
      (but that discrete solution...)
        • 30952
        i'm actually surprised that the arduino-suit does not include a simulator yet.
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8682
          I have yet to use an emulator, never seen one for Linux yet
          Fortunately most of the times my programs work well enough to see some life, and adding that CLI is helpful in debug
            • 30952
            there is a Linux avr simulator.
            https://github.com/buserror/simavr
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8682
              Looks like this was after when I started with AVRs... no 90S2313 and 90S4433 support... they do support the similar Tiny2313 and Mega8 but they're not quite the same.
                • 30952
                so fix it, you have the source there.
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8682
                  But...but... I've been working with this over a decade and never needed it!
                    • 30952
                    so dont.
                    • Dannyx
                      CertifiedAxhole
                      • Aug 2016
                      • 3912
                      #110
                      Quick look at how the power supply for this thing is gonna look I suppose: interestingly, I was expecting the remote module to have a capacitor dropper like most cheap and cheerful China products tend to have, but it's actually got a tasty little switch mode power supply, operating in what appears to be a buck configuration, though there's no isolation as far as I can tell (notice the GND trace is common between the primary cap and the green secondary cap).
                      There's an unmarked switching regulator, a coil, a diode, two feedback resistors and that takes care of the 12v section. It's a cascading supply, meaning there's an additional 5v supply derived from the 12v one via a small 7805 regulator. It's this 5v supply I'm interested in: trying to keep the project as small as possible (so I could preferably tuck inside the light itself, though it's not a requirement), I'm not too sure whether it's better/safer to stick with this PSU to also power my arduino or to use an off-the shelf power brick....I could lower the part count even further by dropping the primary voltage straight to 5v by messing with those feedback resistors so I can eliminate the 7805 entirely....I'd probably add a varistor because I'm not liking the idea of letting my arduino "ride the live wire" like that with no protection whatsoever.....
                      Wattevah...
                        Since it is not isolated power supply I would be really careful when hooking up PC or what ever you will need. I would go with isolated power supply for safety concern.
                        • Dannyx
                          CertifiedAxhole
                          • Aug 2016
                          • 3912
                          #112
                          True that. Power pack/wall wart, whatever you call it, seems to be the way to go.
                          Wattevah...
                          • Dannyx
                            CertifiedAxhole
                            • Aug 2016
                            • 3912
                            #113
                            My Mini just arrived today and it works, but I'm not sure about its operating voltage: while I specifically asked for a 5v model when I bought it, I'm not entirely sure I really got the 5v model in the end. I applied 5v to the RAW pin and it came on just fine, but I only get 3.3v on the VCC pin....the regulator says L05 so the data is contradicting. I guess one sure way to find out is to define a pin as high and measure the output....
                            Wattevah...
                              • 30952
                              what does it say on the crystal?
                              3.3v models only run at 8MHz, while 5v ones run at 16MHz
                              • Dannyx
                                CertifiedAxhole
                                • Aug 2016
                                • 3912
                                #115
                                Says 16000 on the crystal, so I believe it should be a 5 volter.....just made up a new word apparently
                                Wattevah...
                                • Dannyx
                                  CertifiedAxhole
                                  • Aug 2016
                                  • 3912
                                  #116
                                  Finally back on this project and I'm having some issues: can't get my CH341 programmer to work with the damn thing and the information you get online is disappointing if anything: not nearly thorough enough to get a beginner up and running, as it's missing some important details, which may seem self explanatory to some, but others, myself included have some questions.
                                  I'm using a CH341 interface which I normally use for programming TV SPIs. I HAVE used it as a serial COM port before, when I connected it to a TP Link router to try and unbrick it, so I KNOW the adapter works for that purpose. I think I'm doing something wrong on the Arduino's side: I connected TX to RX and vice versa between the two boards, as well as GND of course, but I get an error saying |Not in sync" after 10 upload attempts. I'm not sure I got my arduino software configured properly...aside from obviously selecting "arduino mini" and the correct COM port corresponding to the serial programmer, I can't see too many other options like I did when I messed around with that router where I had to also set the baud rate and flow control.
                                  Another slight mystery is that reset pin of the mini...what should I do with it ? Let it float or use a 0.1uF cap between it and GND ? Does the board need to be put into some sort of "programming mode" or it just works at any point, even if the sketch already on the arduino is running ? Again, the info is not thorough enough on this....
                                  This SHOULD still work right ?! I don't see much difference between my adapter and others demonstrated online...a little help pls ?
                                  Wattevah...
                                    • 30952
                                    let the reset float - it should have a pullup on the board, connect tx,rx & ground and make sure the arduino software is set to use the right comport.
                                    try swapping tx and rx if it's not getting anywhere
                                    • Dannyx
                                      CertifiedAxhole
                                      • Aug 2016
                                      • 3912
                                      #118
                                      I did manage to get it to upload one sketch, by some sort of luck....and I say that because I thought I got it going and the problem got solved (I selected ProMini in the menu), but then when I tried uploading another one, I got "programmer not responding" again, even though I touched no-bloody-thing....the wires going from the arduino to the CH341 thing are about 20cm long...could that be too much and cause spotty functionality ?
                                      Wattevah...
                                      • Dannyx
                                        CertifiedAxhole
                                        • Aug 2016
                                        • 3912
                                        #119
                                        Same thing happened just now: it decided to upload once again...I still don't know what gets it going...I even tried replacing the wires with a shorter piece (shielded even) but made no difference.
                                        My mate suggested the CH341 adapter is crap.....
                                        Guess I'll also try with the MISO MOSI CSK pins.....I believe it's called ISP ?
                                        Wattevah...
                                          • 30952
                                          isp needs a dedicated programmer - preferably a USBasp
                                          i can tell you why your second upload failed,
                                          on a full arduino the reset pin on the atmel is linked to a handshake line on the serial port/chip so the software can reset the atmel into it's bootloader.
                                          can you dig out a 100n film cap?
                                          • DeanWy
                                            WD Sentinel DS5100 (NAS) boot issues
                                            by DeanWy
                                            I have a Western Digital Sentinel DS5100 NAS system which has stopped working. It has dual BIOS. I bought the system second hand with an already broken primary BIOS (it rebooted multiple times until second BIOS was used).
                                            It worked until recently. The system was idle in Windows Server 2012 and a BSOD occurred, I think it was 'critical process died'. Thereafter it didn't boot, it just sat there with no video output and fan speed at 100% (there's a proprietary Windows driver by WD which controls the fan, outside of that it always runs at 100%).
                                            There...
                                            07-30-2024, 04:13 AM
                                          • beogeek
                                            820-2915-A Wont power on with battery connected
                                            by beogeek
                                            Ok so this doing my head in and hopefully someone more knowledgeable will be able to assist.
                                            I've got a MacBook Pro 820-2915-A it will power on without the battery connected, but when the battery is connected it will do a 2,3-second fan spin when pressing the power button and then nothing.
                                            After measuring and probing around I found that R7051 was bad, reading high instead of 2.2Ω so I replaced it. Still the same issue, I have the green light on the charger but it won't power on or charge the battery.
                                            So to cut the long story short I've replaced U7000,...
                                            02-26-2022, 01:29 AM
                                          • survivalbloke
                                            Acer Predator Helios 300 - will not power up if battery is CONNECTED
                                            by survivalbloke
                                            This was a no power initially. Thanks to your help, I discovered it was the first mosfet, so I replaced. Now, the device will power up only if the battery is NOT connected. As soon as I connect the battery, it shuts off. If I connected the battery while the device is off, it simply will not respond to the power button. I replaced the battery, and while I suppose the new battery could be faulty, I'm assuming it is not. I'm having the same behavior with the new battery. I measure .2v at the charging coil. Manually applying power to the + and - at the battery header, there is no charging happening....
                                            06-25-2025, 12:20 PM
                                          • muhuruu
                                            PS5 too many USB devices connected
                                            by muhuruu
                                            Hello. I have a problem with a PS5 console that I bought to learn electronics repair. The auction description indicated that the console had been dropped. The HDMI port and USB ports were damaged. The HDMI port was replaced by the previous owner, and after his repair, the console worked for 2 days and then became dead. After receiving the console, I replaced all the USB ports. After replacing them, the console started to turn on. On the logo screen, it displays "too many USB devices connected". My further attempts to fix the error involved replacing the Southbridge, 4 TPS2001D chips,...
                                            05-19-2025, 07:14 AM
                                          • versionlab
                                            Weird problem, laptop stays on when connected to another pc
                                            by versionlab
                                            Hi, I want to ask for advice about an interesting issue I've been having with a sony vaio laptop.
                                            Client came and said that "a desklamp touched the back of the lid while laptop was operating normally and it caused the office's circuit breaker to trip. Laptop had never turned on since".
                                            After taking the laptop apart (checked dc adapter everythin ok), I found a faulty MOSFET on the motherboard which I replaced. Laptop managed to turn on. However, while booting it shut down. Nothing else seemed faulty and thermals were ok. Shutting down was coming at random...
                                            10-26-2022, 03:43 AM
