LM723 adjustable bench PSU not working
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    • Romania
    Re: LM723 adjustable bench PSU not working
    A single 2N3055 will be good for 2A continuous, no more
    Why is that exactly ? Because of the eventual heat buildup ? If I have a 20v input and I want a 1v output at 2A, according to your formula, that would give me 38w - is that correct ? If so, it seems way below what a 2n3055 can dissipate. I'm assuming you suggested such a low power to keep it in the "safe" zone with the minimal heatsinking.
    Wattevah...
    • Th3_uN1Qu3
      Believe in
      • Jul 2010
      • 6031
      • Romania
      Based on the tiny heatsinks usually put inside these power supplies. You put a bigger heatsink on, it will do more current safely.
      It is advisable to keep transistor case temperature under 60C. If it burns your finger, you need a bigger heatsink.
      A working TV? How boring!
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8703
        Also note that heatsinks will saturate with heat too, so you likely need a fan for small heatsinks. Larger heatsinks may be able to passively dissipate the heat.
        • Dannyx
          CertifiedAxhole
          • Aug 2016
          • 3912
          • Romania
          So basically I CAN go higher in current as long as I manage to cool the thing....makes sense. A fan should definitely be used too IMO...I need this info to hopefully build my own from scratch one day. LONG ago, I put together a very crude design of how I imagined it should look based on Dave's design I saw in one of his videos. That one used a simple plain ol' op-amp (well not really, he eventually resorted to using an LT3080, but that's friggin' expensive), but now I got another IC I can use, this LM723 guy which is purposely built for this and I've got a couple lying around. I thought it'd be easier to upgrade this one, because it's fairly stable. The only thing it lacks is current: can't go higher than 1.5a MAX, so upgrade the transformer, tweak the current limit and it will hopefully do what I imagine.
          Wattevah...
          • Th3_uN1Qu3
            Believe in
            • Jul 2010
            • 6031
            • Romania
            I have a 2A one at work. The weak point in it is the bridge rectifier. When it died i found that it had been swapped by someone else before me.
            The one i put in isn't quite optimal either, but it has been holding up so far (about 8 months IIRC). But the Chinese 2N3055 at the back runs pretty hot too. When it's been continuously running at over 1A for more than 1 hour it starts smelling funky.
            A UPS transformer as the base for a lab power supply should make for a pretty solid setup if you size the other components adequately as well. The LM723 is very old tech (think 1980s) but it is simple and straightforward to use.
            • Dannyx
              CertifiedAxhole
              • Aug 2016
              • 3912
              • Romania
              #26
              Mine starts to reek of burnt stuff when I leave it on under high load also The 2n3055 burnt out A LOT in the past (I believe this is the third one I swap in), so to stop that from happening (or at least delay the unavoidable) I added a CPU heatsink with a fan to it. The thing that last failed now was the transformer itself: small and undersized and got extremely hot...took almost an hour to cool down enough to touch it. The rectifier hasn't failed so far and it also looks pretty beefy. It's not 4 diodes, it's a proper single-piece (don't know how you call those) part and looks like something I scavenged from TV PSUs.
              Wattevah...
              • Dannyx
                CertifiedAxhole
                • Aug 2016
                • 3912
                • Romania
                #27
                Really quick, here are some shots of the transformer I'm planning to use...not terribly huge, but still "beefy". Scale is CM (duuh)
                Wattevah...
                  • 31258
                  just use a module.
                  this is the top one, but there is a table of versions on the page.
                  https://www.banggood.com/DP50V15A-DP...p-1072236.html
                  • Dannyx
                    CertifiedAxhole
                    • Aug 2016
                    • 3912
                    • Romania
                    #29
                    Originally posted by stj
                    just use a module.
                    I feel like something's missing in your post...you mean like a step-down module or buck converter or whatever ? If so, I think there should be a link in there
                    Wattevah...
                    • eccerr0r
                      Solder Sloth
                      • Nov 2012
                      • 8703
                      no, I think he meant don't bother designing a wasteful linear design and depend on the chinese to get a switching solution without needing to do anything...
                        • 31258
                        no, you supply the dc, it does the rest.
                        so your transformer + rectifier & cap.(or a laptop supply??)
                        then a module with the apropriate max current.
                        they do make ones that have boost converters btw.
                        • eccerr0r
                          Solder Sloth
                          • Nov 2012
                          • 8703
                          Yep that seems about sums it up, no more design needed, just wire up top level stuff and make things that are just like everyone else's ...
                            • 31258
                            it works - spend your time making stuff, not the tools to make stuff
                            • eccerr0r
                              Solder Sloth
                              • Nov 2012
                              • 8703
                              It can also be said... know your tools... instead of having a black box.
                                • 31258
                                black boxes matter!
                                so do translucent ones with leds inside - all from china!
                                • Dannyx
                                  CertifiedAxhole
                                  • Aug 2016
                                  • 3912
                                  • Romania
                                  #36
                                  The one you linked to looks interesting as heck - would like to have a go on it and it's DEFINITELY beyond anything I'd be able to design I've seen things like that before around here also, though less fancy. Of course, I could just buy a pre-made circuit like that, but to me half the fun is building stuff...or at least TRYING to I'll definitely keep it as an option though. Cheers.
                                  Wattevah...
                                    • Jul 2011
                                    • 6070
                                    How good is Banggood about getting the stuff that you order can you trust there site
                                    • Th3_uN1Qu3
                                      Believe in
                                      • Jul 2010
                                      • 6031
                                      • Romania
                                      #38
                                      I have seen a lot of popular youtubers ordering from there. It is at least as trustable as AliExpress.
                                      • Dannyx
                                        CertifiedAxhole
                                        • Aug 2016
                                        • 3912
                                        • Romania
                                        #39
                                        Would definitely like to get the DC-DC supply STJ linked to....not terribly expensive and looks fairly professional....stick an UPS transformer on it and I'd have myself a decent PSU. Some of my colleagues order stuff from Ebay and Aliexpress all the friggin' time, albeit very cheap stuff, like miscellaneous tablet and phone components, so I'm not sure at what value customs tax is added...or VAT...or some stuff like that...anyway SOMETHING extra is added if the parcel's value is higher than X. Will have to do some research. If this thing costs 36 dollars, I don't know if that's the final price I'll actually pay or I'll also pay a tax twice that, at which point it's probably not worth it...:|
                                        Wattevah...
                                        • eccerr0r
                                          Solder Sloth
                                          • Nov 2012
                                          • 8703
                                          Sometimes I wonder, the chinese selling unfinished stuff which are "virtually" finished to other countries as "parts" ... because the whole unit if it were "finished" has a tax on it and could not sell as many due to higher price.
                                          I know this happened to laser diodes, not because it was a trade protection tax but rather FDA approval because unprotected high powered laser pointers are illegal in the US, but if you buy the parts to make a high power laser pointer, that's your prerogative. Except that the high power laser diode can easily be incorporated into a design and you still can fry your eyes with it...
                                          Oh well, yeah this is off topic, alas I see all this 'dumping' going on and people snapping them up...
                                          • ohren
                                            Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
                                            by ohren
                                            Hello!
                                            I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
                                            Measured voltages with no load:
                                            After rectifier diodes
                                            12V: 6.17 V
                                            5V: 5.67 V
                                            Secondary transformer pins AC measurement (really don't know if this says anything)
                                            12V: 2-2.5 V
                                            5V: 1.04 V
                                            I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
                                            03-18-2023, 10:33 AM
                                          • mikey5791
                                            Is it possible for transformer substitution?
                                            by mikey5791
                                            Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
                                            Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
                                            My questions are
                                            1. How do i test to see if the transformer is in good working condition?
                                            2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
                                            Hope you guys understand what i was asking. My intention is...
                                            11-03-2022, 02:11 AM
                                          • dennis_elx33
                                            3PHASE STEP-DOWN Transformer in Check
                                            by dennis_elx33
                                            Hello All,
                                            i would like to post an interesting topic regarding 3-phase stepdown transformer which we suspect to cause an overcurrent (138A) which resulted to power tripped off of the HV power supply (80KV output).
                                            Problem statement: Power tripped Off
                                            Initial Problem: Found 2 IGBT and 2 rectifier diodes shorted (burnt).
                                            Action Done:
                                            1) Replaced the faulty parts with good spare.
                                            2) Measured impedance of the 3phase input lines and found that L2 to L3 has 23.3ohm while other pairs are 51Kohm. This pins will...
                                            12-02-2024, 06:52 AM
                                            ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) Book Specification for Upgrade or Repair
                                            This specification for the ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T101HA - X5DHD boardview and T101HA - X5DHD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-06-2024, 04:40 PM
                                            ASUS Transformer T304UA-P71SP-CA Hybrid (2-in-1) Pro Specification for Upgrade or Repair
                                            This specification for the ASUS Transformer T304UA-P71SP-CA Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T304UA-P71SP-CA boardview and T304UA-P71SP-CA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-06-2024, 12:00 PM
