LM723 adjustable bench PSU not working
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8703
    Re: LM723 adjustable bench PSU not working
    I think I just either killed a LM723 or have a dead LM723 in my hands. I'm not sure if I tried feeding in the entire 12V+ output voltage back to the negative input of the error amplifier or not, but now with a voltage divider there, it seems stuck at 0.9V...
    That's when I read the datasheet: absolute maximum input is 8.5 volts....
    so I might have killed it... One dead LM723!
    • Dannyx
      CertifiedAxhole
      • Aug 2016
      • 3912
      #62
      And here I was thinking those things are virtually indestructible
      Wattevah...
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8703
        Hmm... I dug up all the µA723/LM723/MC1723's I could find ... they all behave differently? Weird. Need to see if I can hack up a test jig and toss the broken ones if there are any (some are untested pulls...)
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8703
          I tested the chip that I thought was dead in a reference design... it works despite its behavior is different than another 723 I had (by another manufacturer)!
          WTF? Maybe these really are indestructible *shrug*. My test circuit must be bad or differential between the +/- is over 5 volts, though it too didn't destroy it...
          Tested three of them in the jig, they seem to regulate OK, weird...
          • ohren
            Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
            by ohren
            Hello!
            I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
            Measured voltages with no load:
            After rectifier diodes
            12V: 6.17 V
            5V: 5.67 V
            Secondary transformer pins AC measurement (really don't know if this says anything)
            12V: 2-2.5 V
            5V: 1.04 V
            I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
            03-18-2023, 10:33 AM
          • mikey5791
            Is it possible for transformer substitution?
            by mikey5791
            Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
            Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
            My questions are
            1. How do i test to see if the transformer is in good working condition?
            2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
            Hope you guys understand what i was asking. My intention is...
            11-03-2022, 02:11 AM
          • dennis_elx33
            3PHASE STEP-DOWN Transformer in Check
            by dennis_elx33
            Hello All,
            i would like to post an interesting topic regarding 3-phase stepdown transformer which we suspect to cause an overcurrent (138A) which resulted to power tripped off of the HV power supply (80KV output).
            Problem statement: Power tripped Off
            Initial Problem: Found 2 IGBT and 2 rectifier diodes shorted (burnt).
            Action Done:
            1) Replaced the faulty parts with good spare.
            2) Measured impedance of the 3phase input lines and found that L2 to L3 has 23.3ohm while other pairs are 51Kohm. This pins will...
            12-02-2024, 06:52 AM
            ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) Book Specification for Upgrade or Repair
            This specification for the ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T101HA - X5DHD boardview and T101HA - X5DHD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
            09-06-2024, 04:40 PM
            ASUS Transformer T304UA-P71SP-CA Hybrid (2-in-1) Pro Specification for Upgrade or Repair
            This specification for the ASUS Transformer T304UA-P71SP-CA Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T304UA-P71SP-CA boardview and T304UA-P71SP-CA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
            09-06-2024, 12:00 PM
