Need help to ID this transistor
    • 31015
    Re: Need help to ID this transistor
    so it's an N type device that needs a high base drive - hence the transformer
    i bet this turns out to be a fucking ceramic capacitor shorted - it always turns out to be something annoying like that!
    btw, forget standard pinouts - they mean nothing if the device is a custom job.
    • CapLeaker
      Leaking Member
      • 8146
      Originally posted by stj
      strange.
      lets see what it connects.
      is the screwhole(s) actually connected to the groundplane that the metal case also goes on?
      and, does the large track go to any pins on the big connector?
      Here is what I get. Yes, the large track where the screws go on for the TO-3 case goes to the GND pins on the connector (orange). The two pins from the TO-3 go also to the connector on the positive (blue). The ground plane on the board isn't always ground, specifically after the connector going to the orange caps!
      Watch the pictures if you compare between top, bottom and the one where I was shining a light thorough. It revealed another layer with traces in between.
        • 31015
        about the coating, did you try white spirit on it? i know the plastic on Honda ecu's melts with it.
        • CapLeaker
          Leaking Member
          • 8146
          Here where I live there is no white Spirit. It's not like Europe where white spirit is readily available. I brought a white spirit cooker with me back then but I have to fuel it with 99% rubbing alcohol around here. I found that the thick hard goo crystallizes under heat (hot air soldering station) then I can scrape it off.
          • CapLeaker
            Leaking Member
            • 8146
            Cording to my Leakseeker the short is in between the 2 pins of the TO-3 pads, any further I go, as further I get away from the short. What gives?! I cant find anything wrong, checked all the ceramic caps too. Is there a mad purpose of having these two pads shorted together? For some reason I doubt that this TO-3 thing is a FET. Nothing really fits if I compare my M11 ECU to a N14 ECU in the VGB supply.
              • 31015
              maybe dremel the top off the device - see if it looks like a single gate or something else.
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8701
                If it's a nonstandard part then we can also forget substitution?
                Other things... this is "supposed" to be high reliability and I would be very surprised if Mot/Cummins would omit the protective gate zener if that were a MOSFET. That is, if it doesn't have the protective zener inside...
                So is it a dead short or how many ohms are you seeing between the pins? If this low resistance was "normal" then it could likely rule out a MOSFET as it would need several volts to hit saturation threshold and the low resistance would thus dissipate a lot of power.
                IC Regulator - ruled out?
                IC other - ruled out?
                Transistor BJT - not ruled out
                Transistor MOSFET - possibly ruled out
                Transistor IGBT - possibly ruled out
                Thyristor SCR - not ruled out?
                Thyristor TRIAC - ruled out
                For fun:
                Left: 2N3055 (NPN-Si)
                Middle: 2N1136A (PNP-Ge)
                Right: MCR649 (SCR)
                All from the days where stamping pinout was not a luxury...
                  • 31015
                  bullshit.
                  never surrender!
                  • CapLeaker
                    Leaking Member
                    • 8146
                    Dead short means a dead short like 0.12 Ohms short.
                    So I called a company that re manufactures those Cummins ECMs. The answer I got was: "No, I am not telling you what the part is or does" and after I stressed that 828S14 being shorted, "That this is a bad core and want me to get another one". No kidding. Anyway, I guess they are looking for a new ECM now up there. Many thanks to those that tried to help.
                    • eccerr0r
                      Solder Sloth
                      • Nov 2012
                      • 8701
                      I'm with stj, it's Dremel time! (with a microscope) To at least figure out what the part is...
                      and hope it didn't go molten and thus impossible to figure out what it was...
                      • CapLeaker
                        Leaking Member
                        • 8146
                        It's out of my hands now. :-(
                        • CapLeaker
                          Leaking Member
                          • 8146
                          Well guys, you won't believe that one, but the boss smacked that ECU back on my bench with another junk ECU. So this thread isn't over quite yet! :-D
                          Problem right now is that I can't get the covers off the other ECU. Everything is corroded so hard, that whoever took it off, he cut the wires as no one can unplug the plugs.
                          • CapLeaker
                            Leaking Member
                            • 8146
                            after grinding the case open, it turns out that the ECM is for a N14 again, just like the other one, identical. So back to square one.
                              • 31015
                              same fault?
                              • CapLeaker
                                Leaking Member
                                • 8146
                                no, not identical as a fault. I meant identical to the first spare I opened, or as the same as the schematic is for, basically the N14. :-(
                                  • 31015
                                  does it have a similar circuit though, possibly with a more conventional TO218 / 220 package
                                  • CapLeaker
                                    Leaking Member
                                    • 8146
                                    Nope, it doesn't. The one for the N14 has a comperator (LM2901) as a gate drive for the Mosfet (MTD3055). The board I am working on doesn't have anything like the LM2901 at the gate. That is my problem. I do not understand how the TO-3 is driven, if it is a mosfet. I've never seen anything like it. For example there is also no 1.8 Ohm 1W resitor to GND, no gate drive resistor etc.
                                    • petehall347
                                      • Jan 2015
                                      • 4426
                                      • United Kingdom
                                      #58
                                      shot in the dark but might be possible to find the circuit designer to ask how it works .. tread carefully and use pr skills to the max ..befriend them . it is far from easy but been there just once . not really but very close .. there will be paperwork documents . its finding copies thats the hard bit . automotive electronics seems to be a closed shop. i gave up on a power steering pump ecu this week and bought a used one . its gone now and i got paid
                                      • redwire
                                        • 3907
                                        The DC-DC converter for Vgb supply it generates drive voltage for the high-side N-ch. mosfets. The hard part is the DC-DC transformer is on the output and input of the power transistor.
                                        It looks like a self-resonant switcher, for Vgb.
                                        The old model ECM uses discretes and the next gen ECM (Cummins Celect N14) uses LM2901 comparators.
                                        I would sketch out a schematic.
                                        I confirmed the boost-converter is for the diesel fuel rack solenoid.
                                        • CapLeaker
                                          Leaking Member
                                          • 8146
                                          Maybe you can enlighten me why the 2 pads from the TO-3 are shorted (as a self resonant switcher)? I don't think this is supposed to be like that. However, there is no external diode, or shorted cap that I could find that. So maybe there is a diode internally in the FET?
                                          Making a schematic is out of question, unless I unpopulate the board. The board has at least 3 layers and I am loosing the traces as the go underneath of some IC, cap or whatever.
                                          • corrize
                                            Where to find a very small fpc connector 0.3mm between 2 pins ?
                                            by corrize
                                            Hello, I search this connector (oxydated).
                                            It's a fpc zif low profile connector. It come from camera sensor, it is very small : 0.3mm between 2 pins.
                                            I ordered 2 from Aliexpress called « 0.3mm pitch » but one was 0.5mm between 2 pins and the other 0.6mm. In fact « 0.3mm pitch » seams to be the pad width and not the distance between 2 pins.
                                            I can't find it. The other websites like mouser dont show the datasheet, and I can't check if it is 0.3mm between 2 pins ?
                                            Do you know how to find this connector please ? What is the exact name for find it ?
                                            08-06-2024, 05:25 PM
                                          • SS454
                                            vizio e650i-a2 backlight flashes then turns off
                                            by SS454
                                            vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                                            panel: au optronics T650HVN05.4
                                            72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                                            link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                                            Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                                            https://www.shopjimmy.com/vizio-56-0...-power-supply/
                                            Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                                            08-20-2020, 03:57 PM
                                          • DominanceINC
                                            MSI Pro Z790-P Wifi 1missing CPU pins
                                            by DominanceINC
                                            I am a new forum member. I found a broken MSI motherboard with lot of problems. The other problems need schematic. Because, the missing parts what were breaking down with screwdriver and pliers at a standoff.
                                            So, its actual problem is a missing Vcore and Gnd pins in the CPU socket. My question is that, can it be used safely without these two pins? Only for testing at first, while the other problems will be solved. I would wish repair them later.
                                            The other spots are thermal phaste, because, the under educated installer of the CPU did wipe the contacts of the...
                                            07-21-2025, 05:38 AM
                                          • magneh
                                            Behringer Eurolive B205D repair - help identifying transistor
                                            by magneh
                                            Hello
                                            Got this speaker from a friend , defective. Power led comes on and off , in a loop.
                                            Disassembled, got the board out, and after a bit of measuring I found a low resistance on a 5v6 line. With a bit of current I found a transistor heating up on that line (labeled T1 and 113 as on pic).
                                            After removing this guy, I got a value of 0.7 in diode mode on that 5v6 line, which before had 0.02 or something like that.
                                            I tested powering it up without the IC, and the speaker turns on and stays on, and works fine
                                            Still, I need to replace this transistor....
                                            06-18-2025, 02:34 AM
                                          • elsomer
                                            help to identify transistor msi ms-15ck1
                                            by elsomer
                                            hi people, i need some help to identify a transistor(q14) that is missing on the board, so the gpu has no voltage i think that q14 activate the phases for gpu, but i dont have schematic or boardview, but i think its the same transistor than q15 and q16, thanks...
                                            02-17-2025, 05:30 PM
