Re: Can anyone help me identify this transformer?
So you are using two wires and no safety GND ground wire at all. Are you sure that brown wire connected to L2 (N) is actually Neutral not HOT (LINE/PHASE) wire?
And if you check the AC Voltage between GND terminal of the outlet and the NEUTRAL of the OUTLET what do you get?
What do you get between The Hot of the outlet and GND of the outlet?
Your wiring looks confusing with all those red wires and the way one of the brown wire is connected to pin 6. and it does not seem to match your user manual.
