Double din car stereo freezes with GPS use
  • caphair
    • Nov 2011
    • 1249
    Model # fba-2531gnn
    This is a friend's and the problem is the entire unit freezes and becomes inoperable only when the external gps antenna is installed.
    Would this be an antenna fault or gps circuit? Connected to an adjustable power supply the current draw jumps up when the antenna is installed compared to normal draw when it's not
  • redwire
    • 3912
    Re: Double din car stereo freezes with GPS use
    There's three different kinds of car GPS "antennas":
    1. RF antenna only, coax feed to GPS receiver in double DIN.
    2. Active antenna, 2 or 3 wires, its an antenna with built in amplifier.
    3. Integrated module with GPS antenna and receiver. These output TTL serial data and usually take 5V power in; 3 wires. Most popular.
    Water can get in and short out #2,#3.
    What does the double DIN connect to?
    I would say the power may be loaded down, GPS takes 100-200mA roughly.
    Or the GPS receiver has corrupt configuration. Default is usually 4800,N,8,1 with NMEA format. You can connect a PC and terminal with level shifter and see the data stream.
    If the baud rate is bad, garbled data may crash the double DIN.
    Some GPS settings are stored in the receiver's EEPROM, or NVRAM. There is sometimes a little coin battery to keep the ephemeris saved for faster sat. lock.
    • caphair
      • Nov 2011
      • 1249
      It's a coax style antenna. Can they fail causing the freeze up or it would be internal to the radio
      • redwire
        • 3912
        Can't see an ordinary RF antenna problem crashing a radio.
        I think only an active antenna can use coax and be able to crash the double din radio. Check for a short on the antenna coax or see what voltage the radio has on the connector before you plug in the antenna. Looks like the antenna to me.
        An active antenna has a built in preamp yet only two wires: GND and combined signal+power. Something called a "bias-tee" separates the RF signal and power, inside the receiver.
        • caphair
          • Nov 2011
          • 1249
          I measure 0 ohms from center terminal to outside. Does that mean it's shorted?
          • caphair
            • Nov 2011
            • 1249
            Touchscreen not working on double din car radio - service manual?
            Model # fba-2531gnn
            Can't find service manual or schematics. Trying to troubleshoot touch issue not responding
            • petehall347
              • Jan 2015
              • 4442
              • United Kingdom
              just above the plug is your problem .the wire has been trapped
              • redwire
                • 3912
                Yes that coax is crushed! slammed in the trunk. Active antenna should not read zero ohms. If the antenna comes apart, maybe cut off damaged piece and solder back onto the PCB.
                It is possible to put GPS antenna inside the car, under the dash or rear deck.
                • caphair
                  • Nov 2011
                  • 1249
                  Thanks guys
                  It's having touch issues. Started another thread about it if you have any idea for troubleshooting: https://www.badcaps.net/forum/showth...385#post738385
                  • Hellfiya
                    iPhone Repair
                    • Mar 2017
                    • 16
                    Originally posted by caphair
                    Thanks guys
                    It seems that your link redirects to this post, at least for me
                    • caphair
                      • Nov 2011
                      • 1249
                      It appears maybe a moderator merged that thread into this one. It's now shown in post #6
                      Question on the antenna. Can I use an universal replacment? Can't find any specs on this one, can't open the model to attempt soldering the wire. Found this on eBay:
                      https://www.ebay.com/itm/222187342951
                      • petehall347
                        • Jan 2015
                        • 4442
                        • United Kingdom
                        i would cut the wire beyond the squashed bit and see if it still looks shorted .. then maybe do a tidy fix with a new plug and socket
                        • grosseader
                          MSI B450 Gaming Plus Max - freezes randomly
                          by grosseader
                          Hello everyone, i got this mobo for long time, now i decided to rearrange some hardware and build a office pc, but 1 week so far, this motherboard drives me crazy.
                          What is the issue:
                          PC freezes randomly. While loading win, while installing win, while in windows , and just once did it while in bios.
                          Hardware:
                          MSI B450 Gaming Plus Max , MSI A320m A-pro
                          BIOS : 7B86vHG - latest
                          CPU: Ryzen 3 1200, 3200G , Ryzen 5 3500x, Ryzen 5 5500
                          GPU: Vega 7 in 3200g and MSI 1060 6GB
                          RAM: 2x8 ADATA spectrix 3000 , 2x8 SiliconePower 3200
                          01-30-2023, 03:24 PM
                        • Hondaman
                          Single-channel antenna?
                          by Hondaman
                          Recently I switched from my Gray-Hoverman to the Antennas Direct ClearStream 4 MAX. Seems to work about as well as the old G-H in my attic (one-story ranch home), but the Antennas Direct unit can be mounted outside on my chimney if desired.
                          I should mention that I was also using a 29-inch "T" shaped antenna for RF channel 11. I know you're not supposed to use TWO antennas unless they have the same length coaxial cable going into your combiner (and even then there might be problems). So I made sure the cables were equal length.
                          Years ago I made a "T"...
                          11-18-2024, 01:14 AM
                        • netgearnetgear
                          TOSHIBA 32C100U1 - Faulty display (double images and lines)
                          by netgearnetgear
                          Good day all,
                          I have a Toshiba TV, model 32C100U1 that turns on, displays fine for 5 min, sometimes 10 min and even 25 min then it starts to show double image, wrong colours together with lines as seen in the attached. I have measured and documented the tcon voltages both when the Television works fine and when the problems described occurs. It is important to note that the voltages are the same on the tcon board. The LVDS cable, tge panel ribbon all test good. I resoldred all the main ic's connections pins, connectors and even reflowed gamma chip. I tried to block some of the...
                          10-27-2025, 08:07 PM
                        • alltvrepairs
                          Hisense 55AS6G screen double sided tape required
                          by alltvrepairs
                          I need to replace the LEDs of this TV. The screen is glued with double sided tape. This video shows the proceudre required.
                          I need a source for this type of double sided tape adhesive please.
                          https://www.youtube.com/watch?v=bN6g...nel=QUADRA-NET
                          Tks!
                          07-17-2025, 09:32 AM
                        • howardc64
                          TCL 49S405 double image
                          by howardc64
                          LCD displays a 2nd image slighty offset vertically. And multiple pairs of black lines along the bottom. Probably common as google "TCL 49S405 double image" pulls up this ifixit post ( link ) with identical ( nearly, but their fault seems to be on the other half of the panel than mine ) problem without solution.
                          This one looks to be a more difficult to diagnose because most? of TCON seems integrated ( CSOT BGA on buffer baord) into the left panel edge board ( looking from rear of TV) There are 2 buffer boards for each 1/2 of the screen. Main connects to the left buffer board...
                          06-23-2025, 03:20 PM
