1lb solder US $136.00 ?
  • capwizard
    • Jun 2016
    • 1991
    Re: 1lb solder US $136.00 ?
    "I thought that the people in US are generally better financially than in eastern Europe.. "
    Because I am At bottom of the food chain.........Electronics-repair-man........ ................
    States ranked by median household income
    Rank State 2014
    1 Maryland $70,004
    2 New Jersey $69,825
    3 California $67,458
    4 Connecticut $65,753
    Here is the BEST.....KESTER......USA....
    The company was founded in 1899 as the Chicago Solder Company to produce flux-cored solder.This patented Kester manufacturing process has had a major impact in the electronics industry to this day.
    Why 1lb solder US $136.00 ? The answer is Silver, I bet yu, Intel, F-22, NASA use more expensive solder (with precious metals) for IC chips, Weapons and Space applications.
    http://www.kester.com/products/category/solder-wire Which I bought was 44 and 285 Flex Cored Wire (opened box)
    Which metal conducts electricity the best?
    The answer: Pure Silver. The problem with Silver is that it can tarnish. This issue can cause problems in applications where skin effect is important, such as with high frequency currents. It is also more expensive than copper and the slight increase in conductivity is not worth the added cost.
    So if all metals conduct electricity, how do they all rank? Take a look at this chart:
    Material IACS (International Annealed Copper Standard)
    Ranking Metal % Conductivity*
    1 Silver (Pure) 105%
    2 Copper 100%
    3 Gold (Pure) 70%
    4 Aluminum 61%
    5 Brass 28%
    6 Zinc 27%
    7 Nickel 22%
    8 Iron (Pure) 17%
    9 Tin 15%
    10 Phosphor Bronze 15%
    11 Steel (Stainless included) 3-15%
    12 Lead (Pure) 7%
    13 Nickel Aluminum Bronze 7%
    * Conductivity ratings are expressed as a relative measurement to copper. A 100% rating does not indicate no resistance.
    As you can see the differences in electrical conductivity vary considerably depending on the metal. As mentioned, Brass has a very low conductivity rating despite containing copper, so it is very important that assumptions are not made on the electrical conductivity of a material. Always do as much research as possible!
    • televizora
      ghettomodmaster
      • Nov 2016
      • 957
      ...Here is the BEST.....KESTER......USA....
      In this forum I've read some topics, where people say how much technicians take in USA for repair jobs...
      About silver solder - fragile joints, need for higher soldering temperatures... The only reason to use solders without lead is to comply with the ROHS directive. Much of the problems with customer electronics today are either because of faulty capacitors or cold joints, caused by leadfree solder.
      Made in USA? Reason enough for me to be unattractive. . Not in EU. Expensive shipping, customs fees and long shipping time.
      Useful conversions. I don't "speak" imperial. Please use metric, if you want to address me.
      1km=1000m=100000cm, 1inch=2.54cm, 1mile=1609.344meters, 1ft=30.48cm 1gal(US)=3.785liters, 1lb=453grams, 1oz=28.34grams
      • capwizard
        • Jun 2016
        • 1991
        We need to adapt the variety of this world, the electrical outlet plugs, there are currently 15 types of electrical outlet plugs in use today.
        TV 50" nobody says 1.27 meters TV. The highest speed limits are generally 70 mph (113 km/h), 2 by 4 building stud : 2 in. x 4 in. x 96 in.
        We are using Imperial units, which I don't like. is because we were British colonies in 1607. British colonization of the Americas (including colonization by both the English and the Scots).
        Foot: Good King John, who ruled the kingdom in that time, said “Enough of this! My foot is the foot! Throughout all the kingdom, when anyone counts the number of ‘feet’ it will mean my foot!
        Yard: A yard was originally the length of a man's belt or girdle, as it was called. In the 12th century, King Henry I of England fixed the yard as the distance from his nose to the thumb of his out-stretched arm. Today it is 36 inches.
        Inch: At first an inch was the width of a man's thumb. In the 14th century, King Edward II of England ruled that 1 inch equalled 3 grains of barley placed end to end lengthwise.
        Cubit: In ancient Egypt, a cubit was the distance from the elbow to the fingertips. Today a cubit is about 18 inches
        Lick: A Lick was used by the Greeks to measure the distance from the tip of the thumb to the tip of the index finger.
        Pace: The ancient Roman soldiers marched in paces, which were the length of a double step, about 5 feet; 1,000 paces was a mile. Today, a pace is the length of one step, 21/2 to 3 feet.
        PS: I have A big question: What gonna happen if King uses something in the body is variable length as a measurement, How can we use as A standard ???
        • mariushm
          • May 2011
          • 3799
          The author of the post bought some "new old stock" solder of a quality brand.
          Again, I said compared to above mentioned brands , the Cynel solder is crap. It may be good compared to chinese or no-name brands, but nevertheless is not up to the level of those other brands.
          eccerr0r , don't even think about that.
          You have a lot of impurities in it like steel from leads of components, burnt flux basically he ratio between tin and lead is all screwed up.
          There's lots of combinations of percentages of Tin and Lead that will result in OK solder, some would be euctetic, some won't, some would be more suited than other for some applications... but if the percentage you have now happens to be a bad one or the impurities screw up the solder you won't know how reliable that soldering job would be.
          A 2lb solder bar is 20 bucks : https://www.digikey.com/product-deta...139-ND/2498937
          If you need solder for a solder pot (for tinning wires or whatever) 20$ is cheaper than risking everything with that ball. I'd say just throw that ball away.
          • televizora
            ghettomodmaster
            • Nov 2016
            • 957
            We need to adapt the variety of this world, the electrical outlet plugs..
            The almost all of EU, Russia and post soviet republics use Schuko plug, so I don't need to adapt.
            And I really, really dislike inches. Because they are imprecise, and I need to convert to metric to understand how big something is.
            Why? Explain. The joints are bad, or what? One reason to be bad, other than it's polish.
            If it does the job, how it is bad?
            • capwizard
              • Jun 2016
              • 1991
              Last Year I went to British, I don't like they drive on the left side of the road, same as Hong kong, Japan. but city is clean and peoples are obey the rule.
              http://www.worldstandards.eu/cars/driving-on-the-left/
              I deviate from topic, Is that ture UK and French are leaving EU, for good?
              • jazzie366
                • May 2016
                • 304
                Thank you very much,They are all good stuff but I can't afford now, I hate cheap solder before I use only USA made solder. but now more and more cheap China TV so I think China solder will blend good with it.
                More and more SMD parts do not need any solder I just use Hot Air put it right back............
                Next topic : How to make Homemade recycled poorman's solder or How to solder without solder.
                That's a car amplifier and I know it, I repair those from time to time. That one looked like a Maxxsonics board, is it?
                Popcorn.
                • capwizard
                  • Jun 2016
                  • 1991
                  16-PRX1.1500 - Memphis Monoblock 1500W
                  http://www.woofersetc.com/16-prx1-15...kyoaAihL8P8HAQ
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8681
                    Silver solder (at least the PbSnAg solders) with it's whole 2% silver content isn't really going to increase the cost of the solder much. At silver spot price, of say $20/oz, and let's say we have a 1 pound of 63/37 which is around $16. 2% means 1/50th of it is silver, so
                    ($16/lb*49/50)+($20/oz*16oz/lb*1/50) = a bit more than $22
                    Let's say 100% markup for this solder and it shouldn't even be worth $50.
                    The amount of silver in silver solder is so little that it contributes only a marginal amount to conductance, granted the lead and tin components of solder are horrible. However solder was not meant to be for conductivity, it's for strength (wires should be twisted together or mechanically connected before soldering for lowest resistance.)
                    The silver is to help wet some metals that don't stick well to tin and lead. Also if the contacts are already silver plated, you don't want the solder to eat the silver away, so you use silver solder. I think only very old Tektronix equipment was like this.
                    Also I don't really worry much about reusing the ball. Since iron and copper won't dissolve significantly in the solder, it can be removed by filtering (on the other hand, the gold content of this solder is probably higher than virgin solder). Burnt flux is going to float. Also more tin - which what ROHS solder is - will generally keep the melting point down and it will counter the small amount of 50/50 solder.
                    I'm not going to be using it to solder anything useful, would like to use it as fill solder so I don't have to waste the fresh wire solder.
                    After I melted down the ball into the dish, I have a disc which no longer has many voids in it anymore. It weighs 120g - about 1/4 lb, so not really that much solder, all in all. Also, come to think of it, the lump of solder does not really have much of a half liquid half solid region, so I suspect (and pretty sure) I did not add much ROHS solder into it, which means it's probably still very close to eutectic or leaning towards 60/40.
                    • corrize
                      Best way to solder LVDS connector for beginner (and qfn) ?
                      by corrize
                      Hello, I'm a beginner for micro soldering. Right now I have some difficult to solder a qfn 20, I guess I put too much solder on the thermal-ground pad, the result is a corner of chip wich don't touch the board (last try).
                      I use a wire solder with hot air, I tin the board and chip before with iron and I use good flux.
                      I will have to solder a LVDS connector (40 pins, laptop pc), I saw a solder paste in seringe, good quality (it does not scatter).
                      See the test :
                      https://youtu.be/bNAzC-EvqHs?t=1767
                      With hot air from bellow the board, that's...
                      03-09-2023, 02:57 AM
                    • myth77
                      UV solder mask - high temp resistent, recomendation?
                      by myth77
                      Can someone recommend any good UV solder mask? But i need a solder mask that will stand high temperetures. The thing is...sometimes i have a bigger cooper ripped from the board, lets say mosfet pad... i reconstract it with cooper sheet, then i "glue it" with solder mask...then i use UV light...and let it cool a bit. After, i try to clean the cooper of extra solder mask..and till that part all is ok. But, when i use a soldering iron to solder that pad/cooper...the solder mask gets weaker or destroyed and finally the pad is ripped again from the board .
                      Is there any solder mask...
                      03-28-2022, 04:04 AM
                    • petemanuk
                      BGA solder balls not connecting - help pls
                      by petemanuk
                      So I though in my spare time I’d set myself up repairing motherboards mainly pin damaged lga1151 sockets types.
                      I’m using an achi ir sc pro rework station (gave up on my Achie ir6500 - don’t recommend)
                      I’ve managed to get my rework profile somewhere in the correct region (after a lot of trial and error) to get the old sockets off and reflow new ones back on again, the problems I’m getting is not all of the solder balls are re-attaching when re-flow occurs. I know this because when socket is removed pads still look clean and have no solder...
                      11-16-2022, 05:21 AM
                    • acedogblast
                      by acedogblast
                      11-02-2024, 05:13 PM
                    • sircastor
                      Solder not reflowing - what am I doing wrong?
                      by sircastor
                      I'm trying to fix a broken MacBook Air, and got a parts board to salvage components from. Following the suggestions of many folks here, I wanted to get in a little practice of using my hot air station (A Quick 957DW+) on the parts board so I know what kind of behavior to expect.
                      For the life of me, I can't get anything done with this thing. I have tried multiple temperatures (from 210-425c), different air speeds, preheating the board (with the hot air, just warming it all around). I have applied what feels like excessive amounts of flux (Amtech V2-TF-559) and the solder on these components...
                      03-03-2024, 02:44 AM
