Looking for a better telephone line transformer.
Currently ETAL P5100 transformer is fitted while an older version of the same device had an ETAL P1200 which was fully enclosed and potted(?) by “vacuum impregnation” process (according to ETAL website).
There is an electrical buzzing audible via the earpiece of the “programming” telephone that connects to the device (Pyronix Vocalizer alarm system speech dialler) connection is via the UK BT telephone socket mounted directly on the PCB (top right corner – white in colour) – the “programming” telephone is just a regular UK telephone plugged in to that socket on the PCB.
An older version of the same device used the ETAL P1200 and had no buzzing but the newer version with the P5100 had a small buzz from day one – “buzz” in this context means audible only via programming telephone earpiece and very slightly audible on the telephone line but not a vibrating buzz you could hear by physically putting your ear to the device – disconnect device from phone line and line goes totally quiet and ADSL speed improves.
Having replaced all the capacitors, the buzzing is greatly reduced (less buzzing then when it was brand new) – you can no longer hear the buzzing in the alarm voice messages (telephone side-tone effect was probably transferring the buzzing to recordings).
The speech dialler in circuit buzzing is having a negative impact on ADSL/Broadband performance on the same phone line – that's why I am interested in different transformer choices, makes and models.
So, which transformer is better the P5100 or the P1200?
Other than the two transformers I mentioned - Is there an even better transformer for this application made by ETAL or a different manufacturer?
What specifications should I be looking at to compare transformers.
Here is another thread that explains the Vocaliser https://www.badcaps.net/forum/showthread.php?t=60126
