Can resistor used as a soldering iron?
  • Agent24
    I see dead caps
    • Oct 2007
    • 4951
    • New Zealand
    Re: Can resistor used as a soldering iron?
    Yeah, why buy brand new resistors for a few cents when the cooked ones will do?
    -David VanHorn
    • capwizard
      • Jun 2016
      • 1991
      I did it on purpose! look the pictures, I changed back to toasted resistors to finish this science project, because nobody answer my question "Can we re-use those have been red hot resistors again"! So I use customers one year warranty does free testing for me.........
      PS: The resistors are wire-wound resistors as same as soldering iron tips.
      • Agent24
        I see dead caps
        • Oct 2007
        • 4951
        • New Zealand
        I know you did it on purpose - I was being sarcastic.
        I don't understand why you want to increase your chances of a failure, return and more work by using the old parts which have been significantly stressed.
        If you want to know how long those toasted resistors last, just set them up in a circuit on your workbench passing the same current as they would have in the TV, and leave them there.
        They're vaguely similar in construction, to some soldering iron heaters, I suppose. But not designed for the same job.
        -David VanHorn
          I am wondered if those resistors still maintain the Flame Proof characteristic, if not, you may not be lucky if the fault happen again and burn down the house.
          • capwizard
            • Jun 2016
            • 1991
            I really don't wanna say "Never try Never know!" but I will remember this property is not belong to me, should be handle with care beside he is my loyal customer. Thanks you both.
            PS: but, but that two resistors are originally his.
            • Agent24
              I see dead caps
              • Oct 2007
              • 4951
              • New Zealand
              #26
              Originally posted by capwizard
              I really don't want say "Never try Never know!"
              Well, there's nothing stopping you from doing an experiment with the resistors yourself.
              -David VanHorn
              • flat-earther
                Hoover FM216LI cordless vacuum refuses to charge
                by flat-earther
                I have a Hoover FM216LI cordless vacuum which isn't charging its internal battery.
                I opened up the unit, and it has 6x Samsung ICR18650-22P cells connected in series.
                5 cells were at about 3.3-3.1V. one was at 2.4V, so I assumed this cell was bad that's why the vacuum wasn't charging so I replaced it with another 18650, but after that the problem still persists, the vacuum turns on a bit and then cuts out since the batteries are empty.
                So I think the over discharged battery wasn't the culprit, it was a symptom of the unit not being able to charge its batteries....
                06-06-2025, 03:14 AM
              • sparcktikus
                Ersa Rds 80 soldering station burnt resistor
                by sparcktikus
                Hi
                I have an Ersa rds 80 soldering station which has developed a fault and just showing err on display
                I have found a burnt resistor on pcb can anyone help me identify this resistor if you have a circuit diagram or similar unit
                The printed circuit board markings are rd80 ver 2.0 and the resistor in question is R6
                Many thanks...
                04-04-2023, 04:29 AM
              • rmjimenez455@gmail.com
                Sumsour station 8586D error H-E
                by rmjimenez455@gmail.com
                Hello everyone, next I have the following problem with the Sumsour 8586D 110v dual station I bought it a year ago and it worked wonderfully, now it presents the H-E error on the soldering iron side, the hot air side works correctly..... I disassembled the soldering iron head because the manual tells me that this error is due to ceramic resistance problems, in effect, I measured it and it is open, I bought a new one that is working verified in a soldering iron and nothing.... The same error continues, I proceeded to open the station and check visually, I found a totally damaged 1R00 surface mount...
                09-07-2024, 09:33 AM
              • kalemaroni
                Opinions on particular soldering iron tip maintenance product
                by kalemaroni
                Has anybody tested this product? Posting this question on a Facebook tech group I'm in got a few responses like "that kind of thing corrodes the tips" and "just using normal solder paste is much better" so I'm not looking for generic responses like that, but rather, does anybody know for certain whether this exact product is good or bad for soldering iron tips?
                04-12-2024, 03:52 AM
              • jinu_j
                by jinu_j
                Hi
                05-03-2025, 10:51 PM
