Can resistor used as a soldering iron?
  • flat-earther
    Hoover FM216LI cordless vacuum refuses to charge
    by flat-earther
    I have a Hoover FM216LI cordless vacuum which isn't charging its internal battery.
    I opened up the unit, and it has 6x Samsung ICR18650-22P cells connected in series.
    5 cells were at about 3.3-3.1V. one was at 2.4V, so I assumed this cell was bad that's why the vacuum wasn't charging so I replaced it with another 18650, but after that the problem still persists, the vacuum turns on a bit and then cuts out since the batteries are empty.
    So I think the over discharged battery wasn't the culprit, it was a symptom of the unit not being able to charge its batteries....
    06-06-2025, 03:14 AM
  • sparcktikus
    Ersa Rds 80 soldering station burnt resistor
    by sparcktikus
    Hi
    I have an Ersa rds 80 soldering station which has developed a fault and just showing err on display
    I have found a burnt resistor on pcb can anyone help me identify this resistor if you have a circuit diagram or similar unit
    The printed circuit board markings are rd80 ver 2.0 and the resistor in question is R6
    Many thanks...
    04-04-2023, 04:29 AM
  • rmjimenez455@gmail.com
    Sumsour station 8586D error H-E
    by rmjimenez455@gmail.com
    Hello everyone, next I have the following problem with the Sumsour 8586D 110v dual station I bought it a year ago and it worked wonderfully, now it presents the H-E error on the soldering iron side, the hot air side works correctly..... I disassembled the soldering iron head because the manual tells me that this error is due to ceramic resistance problems, in effect, I measured it and it is open, I bought a new one that is working verified in a soldering iron and nothing.... The same error continues, I proceeded to open the station and check visually, I found a totally damaged 1R00 surface mount...
    09-07-2024, 09:33 AM
  • kalemaroni
    Opinions on particular soldering iron tip maintenance product
    by kalemaroni
    Has anybody tested this product? Posting this question on a Facebook tech group I'm in got a few responses like "that kind of thing corrodes the tips" and "just using normal solder paste is much better" so I'm not looking for generic responses like that, but rather, does anybody know for certain whether this exact product is good or bad for soldering iron tips?
    04-12-2024, 03:52 AM
  • jinu_j
    by jinu_j
    Hi
    05-03-2025, 10:51 PM
