An insulated-gate bipolar transistor?
  • capwizard
    • Jun 2016
    • 1991
    IGBT?
    Testing an IGBT
    https://www.youtube.com/watch?v=_Ygmbfw-9XE
    IGBT gate drivers
    https://www.youtube.com/watch?v=BEp6NUQLBuE
    Lecture 32 IGBT
    https://www.youtube.com/watch?v=P9CDR3VVbHo
    Insulated-Gate Bipolar Transistor or IGBT
    https://www.youtube.com/watch?v=3HDzqDZaprE
    Reinforced Isolated IGBT Gate-Drive Flyback Power
    Supply With Eight Outputs
    https://cdn.badcaps-static.com/pdfs/...41705d57a2.pdf
    Why Opt for IGBTs in SMPS Applications?
    http://powerelectronics.com/content/...s-applications
    PDP Power Devices
    https://cdn.badcaps-static.com/pdfs/...2a8dd1430c.pdf
  • capwizard
    • Jun 2016
    • 1991
    Re: An insulated-gate bipolar transistor?
    After I sub with IGBTs if it works I will have a feeling of accomplished Mission Impossible, and I'm addicted to it. So PL don't ask why I do that?
    Case one: LG 60PV450 Z-board has 4 FGPF4633 shorted I sub with 30j124, when I turn the power on, I scared put both of my hands on my ears, because I don't like the pop noise.... HA HA your a chicken! ...Yes, TV works, For how long , customer will test for me with my one year warranty!
    PS: If you never sub with IGBTs you never know of which can do it..........Errors built up experiences........By CapWizard...............
    just Now, one lady opened the door gave me an air kiss with her lips and closed the door, leaved,... Mental Problem......horny......Why....because she is not A good looking girl who does that to me once in awhile........... I don't even know her name and I'm old and ugly..........
    • capwizard
      • Jun 2016
      • 1991
      After i changed TV works, an IGBT I was used on Panasonic TV. Let's look at the specifications. they are perry closed, I'm lucky with this one..........
      PS: This one is caused by underneath 3 big coils's bad connections no needs to upgrade them.
      30J124 GT30J124 IGBT 600V 300A TO-220SIS
      FGPF4633 330 V 300A PDP Trench IGBT 300A
      https://cdn.badcaps-static.com/pdfs/...a9fdcb5c6d.pdf
        So what is the Vge(th) and Vce(sat) of the sub? It is not just the breakdown Voltage and current handling that you need to look at.
        • capwizard
          • Jun 2016
          • 1991
          I thought about the Vge(th)= g-e treshold voltage 3.3v and Vce(sat)= c-e saturation voltage=1.35v , but Toshiba's IGBT GT30J124 has no information for many years. it's like blind dates for this two IGBTs. You can tell for me this is not my first attempt to do that. the old CRT TVs I sub all the HOTs with damper diode to 2SD1556.
          • Longbow
            • Jun 2011
            • 623
            A substitute of any kind of part can often work for short times. Usually there is a reason the designer chose that particular part. Also, once the circuit is built, adjustments are made at the design stage to eliminate parasitics, overheating, ringing in the waveforms and lots of other stuff. A new part will definitely change the values of parasitic capacitance and inductance, etc. But everyone gets lucky sometimes.
            A good way to start on the topic is really to ask "why use an IGBT" in this circuit? There are perfectly good MOSFETS and low Vce switching transistors out there that can do the same thing.
            Is it plugged in?
              Only time will tell if the sub will last or not.
              • capwizard
                • Jun 2016
                • 1991
                Longbow Thank you for your advice.
                "a reason the designer chose that particular part."
                All I try to do is surpass the LG south Korean's college graduated young TV circuits designer...............
                  But you did not find many other critical specs of the original part to know if the sub is OK for long term or not, you only went by the breakdown Voltage and current handling spec.
                  • capwizard
                    • Jun 2016
                    • 1991
                    I am telling Trump! This is not a fair game to play, because all we get is this (attached file).
                    and TV has no parts , no screens , no diagrams for us. How can we blindfold and play game with them?............
                    PS: Any car or equipment sale to US, needs to have 10 years parts in stock. Can someone make sure this law?
                      Do you have circuit diagram for your car computer module, your HVAC board you just replaced, and lots more of other products you have in your house?
                      • capwizard
                        • Jun 2016
                        • 1991
                        No! but I am telling Trump! This world is not fair!...................
                          If you design the circuit for your products, will you give away your design out to any one that want it, even your competition??
                          • capwizard
                            • Jun 2016
                            • 1991
                            if you apply for A patent you need to prove everything to patent office. Every time I design a circuit or a device I always gave to Badcaps.
                              Not all the design needs to be applied for patent, patent is not going to stop people copying your products.
                              Not applying for patent does not mean the products do not work.
                              • Longbow
                                • Jun 2011
                                • 623
                                I assume that your IGBT device was used as the horizontal output transistor? In that case you obviously need a part that has a high Collector to Emitter breakdown voltage and a low Vsat. Sometimes IGBT's are chosen because they have a lower saturated "resistance" (voltage actually) which can be around .2 volts sometimes - lower than the E-B bias in regualr transistors. Usually it is wise to replace the HV diode in the secondary. We always had a "ringer" tool to test the output transformer and the horizontal deflection yokes. Either or both of these parts can fail and be the cause for the switching transistor to smoke. If they are bad however, you will usually have a funny looking picture. Suprisingly, companies like MCM carry a lot of aftermarket parts for old sets - not ideal but better than nothing.
                                I have read a number of journal articles that compare MOSFET's with IGBT's for power switching, such as with 3-phase motor control. It seems that there is a difference of opinion on which is better, but some choices are dictated by parts availability and specific voltage/current levels involved. Not so easy. At one time there were no IGBT's and all the TV's used special HV transistors for the horizontal outputs. And, they didn't usually fail unless something else downstream shorted out. Just an opinion.
                                And you are correct about why some designers use certain parts. I know for a fact that if a manufacturer has 100,000 unused transistors in his inventory, he will make a design that uses up the overstock. I've seen it in lots of cases. Clever.
                                Is it plugged in?
                                • capwizard
                                  • Jun 2016
                                  • 1991
                                  "We always had a "ringer" tool to test the output transformer and the horizontal deflection yokes." We use ESR meter to ring test HV transformers and deflection yokes and it works OK. The best is use frequency counter and scope to check them.
                                    You mean square wave generator (or function generator since you need to drive the winding) and scope .
                                    • capwizard
                                      • Jun 2016
                                      • 1991
                                      Why south Korean's LG and Samsung company during 10 years period of time can surpass Japan TV company like Sony, Sharp...Become No 1 TV makers in the world! Because the USA is behind them and give A technical support, , Why? Since Korean war US is the majority aid of South Korea and America finance the war needs money, so if South Korea can afford its own defense the quickest way to make money is from consumer electronics? I think UK is behind them also because Britain is an important anti-communist country, plus an ally of the United States........Russian has 100 more advantages, benefits than South Korea became A TV leader in the world..............Am i right?.......................
                                      Bibliography:
                                      South Korea Can Afford Its Own Defense
                                      http://www.theamericanconservative.c...s-own-defense/
                                      the South Koreans currently pay about 40 percent of the costs of keeping U.S. forces in their country
                                      I am telling Trump!!!
                                      http://www.globalresearch.ca/make-am...lated_articles
                                      Why America Needs War
                                      http://www.globalresearch.ca/why-ame...ds-war/5328631
                                      During the Second World War America had witnessed a modest redistribution of the collective wealth of the nation to the advantage of the less privileged members of society.
                                      America, or rather, corporate America, was orphaned of its useful Soviet enemy, and urgently needed to conjure up new enemies and new threats in order to justify a high level of military spending.
                                      And so Mars could remain the patron saint of the American economy or, more accurately, the godfather of the corporate Mafia that manipulates this war-driven economy and reaps its huge profits without bearing its costs. The despised project of a peace dividend could be unceremoniously buried, and military expenditures could remain the dynamo of the economy and the wellspring of sufficiently high profits.
                                      • capwizard
                                        • Jun 2016
                                        • 1991
                                        Yes.
                                        Pic1:
                                        Measuring the Q-factor of a resonator with the ring-down method
                                        http://www.giangrandi.ch/electronics...ingdownq.shtml
                                        pic2:
                                        http://seniorphysics.com/physics/eei.html
                                        • mikkele86
                                          Power amplifier SMPS IGBT keeps blowing - Artcoustic PDA1000
                                          by mikkele86
                                          hello.
                                          I have two power amplifiers, both having their IGBT blown on the PSU.
                                          The original mounted IGBT where marked with IRGB20B60PD1PbF and the gate driver is a IR2156STRPBF.
                                          I looked at mouser and digikey and could not find any available IRGB20B60PD1PbF and somehow ended up using a Bourns BIDW20N60T.
                                          I replaced the gate driver, the gate resistor and both IGBT. But as soon power is turned on, both IGBT shorts out completely (gate, emitter, collector) and the fuse on the AC line gets killed.
                                          So I though i missed a capacitor or diode. I removed...
                                          01-06-2024, 06:45 AM
                                          NVIDIA PCB ID / BOARD ID Chart
                                          PCB ID - Core model
                                          v218470 - AMD/215-0767003
                                          v218510 - AMD/215-0767003
                                          v27314s HD7850
                                          v27937s - HD7730
                                          v310440 - GM107-400-A2
                                          v313070 - GK208-201-B1
                                          v313080 - GK208-201-B1
                                          v313120 - GK208-201-B1
                                          v313130 - GK208-201-B1
                                          v313140 - GK208-201-B1
                                          v313220 - GK208-201-B1
                                          v31609s - GM204-200-A1
                                          v31615s GM204-200-A1
                                          v316320 - GM204-200-A1
                                          v317290 - GM204-200-A1
                                          v32002s - GM206-300-A1
                                          v320040 - GM206-300-A1
                                          v32005s - GM206-300-A1
                                          v32010s - GM206-300-A1
                                          v320115s - GM206-251-A1
                                          v320120s...
                                          10-02-2024, 09:21 AM
                                        • sigmeyer
                                          LG TV Need help replacing a Bipolar Small signal Transistor
                                          by sigmeyer
                                          Ok , so i got this TV from a friend of mine.So to start it off Its a plasma TV.When turned on it the red light comes on , then after a couple seconds the light goes off, and it repeats like that. You can hear the Relay click on for a few seconds then off ... So it wasnt an obvious short on the mains input thats for sure. I opened it up , and mind you, i have never seen an inside of a plasma TV so it suprised me to say the least. There are 3 massive power boards. The main one , then we have the board that is connected to another board which then goes to the TV (i assume those are some kind of drivers...
                                          10-16-2020, 03:28 PM
                                        • tony359
                                          Bipolar capacitor for vintage Apple CRT monitor
                                          by tony359
                                          Good day all,
                                          I have a question about some old monochrome Apple monitors.
                                          Inside those monitors there is one bipolar capacitor. From the schematics I have it's part of the horizontal linearity circuit.
                                          A friend replaced a bipolar 4.7uF 25V capacitor with a Nichicon bipolar 4.7uF 25V. The cap popped after about one hour. The new capacitor was much smaller than the original one but that's not a surprise as the original one was from 1980. (I am not sure whether the original was was actually 4uF and was replaced with a 4.7uF?)
                                          The new capacitor:...
                                          08-12-2024, 03:27 AM
                                        • magneh
                                          Behringer Eurolive B205D repair - help identifying transistor
                                          by magneh
                                          Hello
                                          Got this speaker from a friend , defective. Power led comes on and off , in a loop.
                                          Disassembled, got the board out, and after a bit of measuring I found a low resistance on a 5v6 line. With a bit of current I found a transistor heating up on that line (labeled T1 and 113 as on pic).
                                          After removing this guy, I got a value of 0.7 in diode mode on that 5v6 line, which before had 0.02 or something like that.
                                          I tested powering it up without the IC, and the speaker turns on and stays on, and works fine
                                          Still, I need to replace this transistor....
                                          06-18-2025, 02:34 AM
