LED TV dummy load.
  • capwizard
    • Jun 2016
    • 1991
    LED TV dummy load.
    Any help will be appreciated. I try to built "universal TV LED screen dummy load." .
    Basically, put a lots of LEDs try to cheat LED driver to work. So we can distinguish the problem is at LED screen or LED driver.
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: LED TV dummy load.
    Just use some 10w leds in series to match the output load of the driver easy
    • capwizard
      • Jun 2016
      • 1991
      Maybe some 10w leds and some 3v leds, but for some critical driver we will need exactly same current.
      TV LED screen dummy load version I : This is work OK, but customer will think you still in school.
      TV LED screen dummy load version Il : add some protection.
      TV LED screen dummy load version Il: 10 x10 =100 leds, some TV have 8 strips, I need 8 of them.
      TV LED screen dummy load version Iv: use Edge tv strips but is hard to solder
      Best way to do it probably have customer made PCB . (last two pic)
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Awesome
        • capwizard
          • Jun 2016
          • 1991
          Maybe modified form this. cheap. Pic 1
          https://www.aliexpress.com/item/SMD-...999.414.kjp8Qb
          • capwizard
            • Jun 2016
            • 1991
            Instead of LEDs, can I use this:
            http://www.eevblog.com/forum/project...-load-project/
            http://www.eevblog.com/forum/project..._next=prev#new
            • capwizard
              • Jun 2016
              • 1991
              Must-have Sharp LG Vizio edge led tv dummy load.
              I need to make 100% sure Sharp LC60LE660U TV problem is caused by edge LEDs .
              The easy way is to use the same one as a tester.
              What happened to test different size TV, I will need universal LED dummy load!
              Sharp LC-52C6400U LC-52LE640U LC-60C6400U LC-60LE640U LC-70C6400U LC-70LE640U LC-80LE633U
              at picture 2: the tester got hot in second will needs heat-sink like pic 3 (too long to carry around.)
              Pic 4,5 : Connector pin out
                The key is trying to figure out how many LEDs there are in the string without taking the panel apart to get to the LEDs.
                Also need to find out if the LED strips are connected in series to form one big string or each strip is driven by its own driver.
                You can tell by looking at the PWM Controlled MOSFETs for the Cathode return for the LED string, if it has two PWM controlled MOSFETs then two drivers circuits are used.
                https://www.badcaps.net/forum/attach...5&d=1481642097
                I can see that it has four drive circuits for the LEDs' strings.
                • capwizard
                  • Jun 2016
                  • 1991
                  Thanks for your reply.
                  Over this Sharp tv has 4 drivers 34 LEDs each.
                  Can I use something else instead of LEDs to test ?
                  • ZXCVBS
                    • Jun 2019
                    • Argentina
                    Sorry to revive an old thread, but I just wanted to ask.
                    I know i can calculate led resistance knowing the loaded voltage, and current.
                    i.e if i the power board outputs 200v 250 mA to the leds
                    I could use ohms law:
                    R= V/I 800 ohms. W = i*i*v 12.5W. An replace leds with a 800 ohm 12.5 W resistor
                    But if i lower those 200v (250 mA) to 20 v 2.5 A
                    can i connect that output to an electronic load, and start at minimal values until the led backlight is on its working condition range?
                    Don't know if i'm shooting a mosquito with a shotgun.
                    • Ryan.man
                      by Ryan.man
                      02-04-2025, 12:23 PM
                    • smic717394
                      by smic717394
                      07-25-2024, 10:16 AM
                    • aaabddoo
                      Dell 3520 intel vga error when i instel vga intel driver The screen flickers need help pls
                      by aaabddoo
                      Dell Precision 3520​ intel vga error when Run the programl vga intel driver The screen flickers need help pls
                      Sorry for the language
                      06-15-2025, 02:42 PM
                    • Chrissygizmo
                      by Chrissygizmo
                      02-10-2025, 12:33 AM
                    • howardc64
                      by howardc64
                      Problem
                      08-04-2024, 10:36 PM
