Turning a wifi router into a cell phone booster...
  • TheMik
    • Oct 2008
    • 8
    Hello all, first time posting here, so be gentle haha.
    Anyways I am a cheap cheap person, and I love new ideas and trying them for myself. So I am searching around for a solution to my sisters internet/cell phone problems, crap reception inside, and I am finding dropping 500 dollars will solve the problem (mostly). Well to make a long story short she is enrolled in college, with some of her classes being online and like most college students she is broke. So it makes the wilson/others solution impossible. I have looked into wilson/others and have pretty much found if your not within 10 feet of the indoor antenna the signal drops off rapidly anyways.
    So I can't help but to keep staring at my router thinking of a way to use the transmitter to do the job. In a nutshell I am thinking, outside antenna, low loss cable screwed into the receiver antenna on the router, and then have the router sent the signal around the house. It would require taking the 2.4 ghz and changing it to 1.9 ghz of course, but beyond that I am not sure what it would require. Could I just strip the transmitter/receiver part out and use it? I am also not sure how it is 2.4 ghz, meaning back in the day it was controlled by crystals. Now what is used, capacitors and transistors?
    I have searched high and low to see if anyone has attempted this and come up with nothing, I figured the brains here could help, if it can be done. Thanks to this site I have a free dell for my wife that works beautifully after some cap replacement (shop was going to toss it in the trash). Thanks for bearing with me and any info on the subject.
    ~Josh
  • Newbie2
    • Sep 2005
    • 885
    Re: Turning a wifi router into a cell phone booster...
    Wi-Fi for wireless Internet and GSM or CDMA for cell phones are completely different.
    What you're trying to do will never happen, because it is impossible.
    My gaming PC:
    AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
    ASUS M4A77TD AMD 770 AM3 Motherboard
    PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
    G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
    TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
    WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
    ASUS Xonar DG 5.1 Channel PCI sound card
    Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
    Antec Three Hundred Mid-Tower Case
    Microsoft Windows 10 Pro 64-bit
    Microsoft Windows 7 Ultimate SP1 64-bit
    • arneson
      • Sep 2005
      • 1267
      You're absolutely right about the system of phone repeaters costing $500.
      I install those on yachts, with an antenna on the arch.
      But there are two types of system depending on your service.
      I think it's one for Verizon and the other for everyone else.
      It's possible like my older nokia, that there's a base station cradle for that phone.
      When I walk in the front door, I drop the phone into the cradle and the whole house becomes a cell. It's called the VoxLink II.
      http://www.twacomm.com/catalog/model_VOXLINK-131.htm
      Jim
      • TheMik
        • Oct 2008
        • 8
        A digital signal is nothing more then information tied to an analog frequency. I was basically asking if anyone knew a way to alter the freq of a basic wi-fi router. As long as the digital info isn't stripped and the freq matches the router isn't going to care what it's broadcasting. I am not looking to use the router as a access point just a repeater. Thank you for the link, interesting piece of equipment.
        • willawake
          Super Modulator
          • Nov 2003
          • 8457
          • Greece
          like this?
          gsm up the vsat
          anyway this what you need
          http://www.starmarinedepot.com/Digit...+DA4000MR.html
          http://www.digitalantenna.com/prods/...lrepeater.html
          • arneson
            • Sep 2005
            • 1267
            Remember where I am Will, we only have 100 footers here max.
            So I use this DA-4000 system. About 60 mile range offshore.
            http://www.wmjmarine.com/sda4000.html
            Jim
            • Latoof
              • May 2008
              • 22
              Heres a thought... use a couple of passive mobile antennas...
              get a glass mount mobile phone antenna (like THIS )and put the antenna on a window facing the closest cell tower. Run a low loss coax cable to the preferred location in the house and connect it to another antenna (like THIS ).
              Obviously there will be some losses in the system, however it may just work for you.
              E8400 8G Kingston PC6400 RAM
              GA-EP35-DS3R mobo
              HD4850 512M GA, 2x 1T WD SATA drives
              CoolerMaster case/Seasonic 850w PSU
              • ibooster
                • May 2010
                ~Josh
                Josh,
                you are misinformed about the distance these cell phone boosters will cover when installed, the thing is these repeater systems work on the principle that that goes in /get multipled and comes out. So, the sweep in signal coverage is based on that you give at the input (generally +2 bars is prefered) and next factore is the gain in the amplifier, if you get anything over 55dB gain you can cover a comfortable 2000 to 3000 sq ft.
                • cellphonebooster
                  Banned
                  • Feb 2012
                  • 5
                  • india
                  yehh !
                  it can happen
                  • SluggerB
                    Help with trying to fix phone that is not charging (Pics inside)
                    by SluggerB
                    I have two TCL A30 phones.
                    Old Phone: This phone worked fine for years, then stopped charging If you plugged a charger into it, the phone would make the charging sound, the phone would tell you it is charging, but the battery icon would not have the charging symbol in it and the battery would not charge.I tried new battery, same behavior.
                    New Phone: Works fine, bought as a donor board to try and repair Old Phone
                    My interest here is to repair Old Phone, using components parts off New Phone if needed. I am not interested in replacing Old Phone with New Phone....
                    08-12-2024, 08:11 AM
                  • keeney123
                    new OS on a Sonim XP5s phone
                    by keeney123
                    To you programmers out there I want to know if it is possible to put a new OS on the Sonim XP5s phone? I only need this phone to make calls, receive calls, have a list of contacts and be able to call voice mail.
                    I bought this phone new Sep.2021 as an unlock phone from a third-party seller. The phone worked fine until Jan 2022. I then had intermittent problems with the sound setting resetting itself. One of the settings, outdoor, would go to silent all by itself. When in silent mode it does not indicate a call has come in. I missed very important phone calls. All the other setting in sound...
                    05-13-2022, 07:19 PM
                  • mikey5791
                    Help with Samsung Galaxy J7 Prime phone
                    by mikey5791
                    Got this smart phone free from a guy who dropped it hard until the lcd display cracked with no seen display.
                    Opened it and found the display ribbon cable partly damaged. I charged the phone full in 2 hours time, the led red light turns to green indicate full charge.
                    Then i use a usb cable connect the phone to laptop but it only showed as media player with firmware version. Too bad there is no option to check folder.
                    Does anyone know any method to check if the phone is working good? Looking forward for any advice and help possible.
                    If tested the...
                    09-15-2021, 07:54 PM
                  • shadow666
                    Router Xiaomi M4A Gigabit
                    by shadow666
                    hello
                    i need dump backup for wifi router Xiaomi M4A Gigabit M43 R0101
                    Mi Router 4A Gigabit Edition
                    ROM CHIP is 16 MB
                    i attached picture of motherboard​...
                    11-30-2024, 03:49 PM
                    Nokia C2-01 RM-721 RM-722 Phone Schematic
                    The Nokia C2-01 RM-721 RM-722 was a mobile phone produced by Nokia. The Nokia C2-01 supported 3G and had a 3.2 megapixel back camera. It had a single SIM card. The handset was introduced to the markets in 2011. It replaced its predecessor, the Nokia 2700 classic and Nokia 2730 classic and has improved specifications....
                    11-05-2024, 07:40 AM
