USB "Quick" 18W charger ... protocol
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Another one of these silly patented methods to lock out manufacturers... It goes both ways I suppose, prevents crappy chargers but...
    LOCKS OUT THE TINKERER!
    Anyone know if these 9V 2A (18W) USB charger protocol has been hacked? I suppose this shouldn't be too hard to reverse engineer (at least I would think it is) - supposedly these high speed charge capable devices can poll the charger whether it supports 18W and then manually switches to this mode, and then the charger can automatically and immediately shut off 9V when the device gets unplugged.
    What I'm wondering is if these chargers have a USB host implementation in it... would think that it needs to.
  • japlytic
    • Oct 2005
    • 2086
    Re: USB "Quick" 18W charger ... protocol
    Are you talking about USB Type-C chargers here? The USB Type-C specification can be programmed to deliver up to 20V and a maximum of 5A through negotiation on the configuration channel.
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8701
      No, this is an older quick charger standard, uses a regular USB-A 4-pin connector.
      I believe Qualcomm is holding this patent.
      https://www.qualcomm.com/news/snapdr...logy-explained
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8701
        Hmm... knew I posted something about this before.
        Just wondering if anyone did some experiments with this. As far as I can tell, at 18W with 4+ volt lithium ion cells, at 100% conversion efficiency (HAH) these charger can pump 4 amperes into a cell phone battery. This is insane, though most smartphones are like 4Ah or so so this would be near 1C charge rate.
        However I've noticed that though it does occasionally hit 1C charge rate, frequently it drops down to 8W charging. I've never been able to see on charging apps whenever it hits 1C charge rate, is this typical for most phones to simply try to reduce heat generation, and never use 1C charge rate when someone's using the phone?
        (and when the phone is not being used, it will then use 1C charge rate? But not always? Have you caught your phone charging at 1C?)
          • Jul 2011
          • 6057
          I am going to be watching this post for educational purposes
            • 31138
            USB-C is a connector,
            your refering to "QC2.0 or 3.0" or similar which is a communication protocol to command the charger to increase output.
            most QC compatable chargers have a regular TYPE-A socket on them.
            if you go to sites like MAXIM you can download datasheets for charger chips that support these things
            • CapLeaker
              Leaking Member
              • Dec 2014
              • 8286
              With Quick Charge, they are using higher charging voltages than 5V in order to be able to not increase cable and connector size.
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8701
                USB-C charging spec (versus USB-C connector) is better than QC2/QC3, alas yes I'm only talking about QC2/QC3 which many phones appear to still use over the USB-C charging spec, even if it has a USB-C connector... my crap cheap phone is such, it has a USB-C connector but uses the QC protocol over the USB-C connector.
                It appears the USB-C charge protocol has been either documented or hacked, was curious about QC protocol initially... now that I have three QC chargers it's not much of an issue for me anymore, though still curious...
                Still surprised my 8-year old phone will still occasionally draw 17W from the wall through its adapter to charge its battery.... at 17W it must be charging quite close to 1C charge rate with its 3Ah battery pack.
                My "new" crapphone also with QC will likewise occasionally draw 17W+ from the wall, again with efficiency loss this is expected. A 5Ah battery pack, dumping 4A into the pack is not quite 1C but that's what's necessary to fill the pack closer to an hour instead of several hours...
                  • 31138
                  all the fucking phone makers have their own protocols btw,
                  samsung, htc, apple etc.
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8701
                    QC and USB-C charging are "standards" ... but as usual, there are so many standards to choose from.
                    Seems Asus and OnePlus seem to use the same QC protocol and the chargers can be swapped without an issue...
                      • Jul 2011
                      • 6057
                      iPhone and iPad use there own system that does seem to work like it has been described the most that you can charge with is 2.5 amps but your voltage has to be no higher than 5.25 volts or it turns off and refuses to charge correctly anymore until you power cycle it
                      So I do not have the voltage higher than 5.21 volts and I use a medical grade switching power supply that has a voltage controller circuit that is very easily adjusted to what ever voltage from 4.75 to 5.75 volts
                        • 31138
                        apple stuff is easy, you indicate the charger current with 4 resistors
                        2 voltage dividers - one for each data pin.
                        • CapLeaker
                          Leaking Member
                          • Dec 2014
                          • 8286
                          I've done so on one of my solar chargers. Works perfect.
                            • Jul 2011
                            • 6057
                            I was referring to the charging protocol for charging with USB C type chargers I have a couple of them they do not charge any different than a usb a type cable I have a IPhone SE 2020 that came with a USB C cable
                            I have one of those usb tester that shows you what charging profile and it not show it as the iPhone profile the newer iPad does not show up this way either so I do not what is up with this
                            I know that the device works correctly because I have the charging devices that are 9 12 15 and 20 volt and they show up correctly
                            • eccerr0r
                              Solder Sloth
                              • Nov 2012
                              • 8701
                              I think my Asus and Oneplus, despite being QC, will also happily draw 10W from a 5V USB brick. Alas, I was more interested in how QC works as a standard USB power brick better not be outputting 9V if not asked for -- for those non QC devices that would release magic smoke at 9V.
                              I really need to get a bona fide USB volt/current meter, but I'm pretty sure pumping 18W via 5V will make a lot of USB cords cry foul when trying to pass more than 3A. At 9V it's a lot more manageable.
                                • Jul 2011
                                • 6057
                                Originally posted by eccerr0r
                                ….—>I really need to get a bona fide USB volt/current meter, but I'm pretty sure pumping 18W via 5V will make a lot of USB cords cry foul when trying to pass more than 3A. At 9V it's a lot more manageable.
                                When you find one that is good please post a link to one because
                                I have tried a couple of them and not very impressed with them because they are very picky about showing the charging type if it has a usb type a this is the only ones that I can find but they also have usb type c also
                                which to me is not going the way to go you have to find a usb type c input and a usb type c output and no other type of usb connectors on it for best results ( but I have not yet found one to buy )
                                I have tried to hack a couple of them and each time I have fry something on the board or destroy the boards because most of the ones that I have tried to do there a minimum of two boards and one of them had three of them and the components are so tightly packed together I have given up trying to hack them just going to make a wall one into a table model and add a cooling fan and be done with it
                                Because I on having a couple devices that are meant for this type of charger
                                • eccerr0r
                                  Solder Sloth
                                  • Nov 2012
                                  • 8701
                                  I also wonder... what happens if you put 9V into a QC2/QC3 compliant device with no other intelligence? I.e. take a 5V dumb charger and set it to 9V, and plug in the QC2/QC3 device... will the device fry?
                                  Definitely if you connect a non QC compliant device into this 9V dumb charger it will fry, but will QC compliant devices also fry...
                                  • leStoppe
                                    • Oct 2022
                                    • 6
                                    • India
                                    The newer iPhones that support USB-PD seems to quick charge on standard chargers that support that protocol. It's a bit more more common than QC
                                    • eccerr0r
                                      Solder Sloth
                                      • Nov 2012
                                      • 8701
                                      Problem with QC2/QC3 is that you need electronics to tell the device that the charger is indeed capable and to trigger the QC. But I thought the number of QC capable phones out there is fairly significant (a lot of android phones), just that the number of third party QC chargers is small, if that's what you mean.
                                      You know, now I'm tempted to see what happens if I try to charge with a standard 5V2A (10W) charger and if I increase the voltage to 5.5V...and see what the QC capable phone does...
                                      • coasterghost
                                        Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                                        by coasterghost
                                        For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                                        Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                                        Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                                        System Hardware:
                                        Processor: AMD Ryzen 7 PRO 5850U
                                        Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                                        09-08-2025, 10:46 PM
                                        NVDC charger configuration...
                                        11-05-2024, 03:28 PM
                                      • flat-earther
                                        how to prevent a connected charger from draining battery when not charging?
                                        by flat-earther
                                        I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
                                        So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
                                        but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
                                        So the battery is backfeeding the charger and being drained.
                                        How can I prevent...
                                        08-07-2025, 01:04 PM
                                      • xeejem
                                        NIMH quick charger no power
                                        by xeejem
                                        Hope everyone is doing well here. I have been troubleshooting on why my charger isn't giving any charge. At the TNY IC, I did a volt test on pin 2 with closest capacitor ground lead and it is giving 0 volt. Pin 4 and ground is giving around 2v. The capacitor is getting 160v from what I can tell. Those big diodes are tested on board. I don't find any shorts. Do you know how else I can find the culprit? Please bare with my lack of skills....
                                        08-29-2024, 04:54 PM
                                      • flat-earther
                                        ASUS X54H laptop thinks it's always charging even with charger unplugged
                                        by flat-earther
                                        The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                                        Windows also shows ''Plugged in'' when charger is not connected.
                                        This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                                        Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                                        If I let battery run out and say it has 3% Windows will...
                                        06-24-2025, 09:32 AM
