New soldering station required.
  • 6BW6
    • Jan 2015
    • 55
    I'm looking for a new soldering station, general usage, repairs, through hole and SMD components.
    Now I'm looking at Weller stations, rather than buy one of their earlier models I started looking at the WD 1012 series, has anyone any thoughts on these?
    I was nearly caught out buying a Atten ST station, from RS components - they are NOT temperature controlled!!!! There is only three wires in the soldering pen handle, ground and a power feed to the element, they do have one draw back the tip cools when soldering and anything but the temperature displayed.
    Imagine removing a components with solder wick braid and the tip cools down, and ideal situation for the copper track to tear and rip, I can guess the sensing is done via a current shunt resistor, certainly done on-board and not in the iron. I put this to RS and have confirmed my suspicions, they also confirmed Tenma was the same.
    I know Hakko is a good iron used by many, to be honest I don't like the design and it seems fiddly pressing this and that buttons and that it looks like something from Fisher Price toys, so do do, ideas anyone?
    Dave
    • 30919
    Re: New soldering station required.
    there are many threads on this,
    i always recommend some chinese Hakko clone with T12 tips.
    that's the important thing - T12 tips.
    here is a high-end one.
    http://www.circuitspecialists.eu/sol...older-station/
    and a cheap one.
    http://www.banggood.com/BAKON-950D-7...-p-982824.html
    and a set of tips
    http://www.banggood.com/T12-Series-S...-p-932701.html
    and something "interesting"
    http://dangerousprototypes.com/forum...hp?f=56&t=7218
    • 6BW6
      • Jan 2015
      • 55
      Thanks stj, I did visit some of those links you gave, I didn't scan the pages of badcaps regarding similar threads.
      You can't be too careful these day's when buying spares, I always prefer buying from the manufactures or their distributors.
      Since nearly getting a Atten soldering station and finding no real temperature control I want to be extra cautious..... I've got some fake rf driver transistors here supposed to be from a 'reputable company' that started in the West.... lol, they won't even fit in a Kenwood TS2000 - nothing like the original Mitsubishi's, I later learned the die the silicon is mounted on is only quarter the size.
      Dave
        • 30919
        the T12 clones are fine,
        and they are special, the heater & sensor are in the actual tip.
        so you just plug the tip into the handle.
        this makes them heat up very fast and keep hot even when you suddenly put them on a large part.
        https://www.youtube.com/watch?v=u588...ature=youtu.be
        • 6BW6
          • Jan 2015
          • 55
          Originally posted by stj
          ..... the heater & sensor are in the actual tip.
          I thought the heater was separate. The video was pretty impressive, thanks for the link.
          Dave
            • 30919
            no. heater & sensor all combined into one.
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8663
              I LOL when I saw the picture of the controller that has a label:
              "Imported Large Capacitance"
              pointing to the Chongx main filter capacitor...
              I guess it is still technically true...
                • 30919
                yes, but nice of them to show the guts - i wish sellers did that with more stuff!
                • steviewonder
                  • Dec 2013
                  • 183
                  • england
                  I would certainly side with a Hakko- I bought the genuine japanese one,even the power supply is very well built,And got fed up with my semi-trustworthy weller ps3D, still good,but the tcp iron is a pain for failing thermostats,and elements,not cheap either.
                  The Hakko is much better by comparison,being variable temp,With the weller,Temp is set by the magnastat tip fitted...Not sure on the new Weller gear,But Hakko well worth considering!
                  • EasyGoing1
                    Shock Therapist
                    • Sep 2016
                    • 977
                    Stj,
                    That is actually VERY interesting ... any idea what the cost of the parts would be? Id love to build that project.
                    Mike
                    sigpic
                      • 30919
                      pcb can be got from a russian guy on ebay.
                      http://www.ebay.co.uk/sch/tto44ka/m.html
                      parts are not cheap - i have read on the forum it can be as much as 70Euro
                        07-01-2024, 06:34 AM
                      • chth96
                        What soldering station should I purchase for 900M-TJ-I tip?
                        by chth96
                        hello.
                        A few months ago,I have purchased 0.1mm Soldering Iron Tip of below aliexpress link,But I noticed that It is totally impossible to use this 0.1mm iron tip in the T12 soldering station
                        https://ko.aliexpress.com/item/4001275635593.html
                        Is there any good soldering station which is possible to use 900M-TJ-I tip and have inexpensive or reasonable price in aliexpress?
                        Any reply would be appreciated.
                        11-24-2023, 05:08 PM
                      • mkbehbeh
                        KSGER C245 Soldering station PSU 220V only?
                        by mkbehbeh
                        I purchased this soldering station when it was on sale at amazon. It had a slew of one star reviews, but the price was low enough that even if the controller and PSU were toast, the handle tips and stand were worth more than the price. All of the reviews mentioned that the unit was either DOA, or died on the first use. I looked on Aliexpress and the first clue was that KSGER still sold the 220V version of this station, but all of the 110V versions had been discontinued. I figured That there was a problem with the 110V on the power suppply and the controller would be fine.
                        I am...
                        04-17-2023, 03:11 PM
                      • deep000
                        Looking for a budget hot air soldering station for hobby use
                        by deep000
                        I'm looking to get on Aliexpress a hot air soldering station for hobby use, nothing too fancy, just something "reliable" and budget-friendly.
                        Any recommendations for a "good" cheap one that gets the job done?
                        Thanks in advance
                        04-25-2025, 02:29 AM
                      • nbdy
                        QUICKO soldering station
                        by nbdy
                        HI,
                        Have a QUICKO soldering station with no numbers for the model ... (think it's a KSGER or similar copy)
                        All worked nice, till some day it heats the iron till it was RED (HOT) ...
                        Turned it off, and tryed today again, and all the same, even with a second iron ...
                        The display shows that the iron is not connected, like not inserted in the handle ...
                        The second thing is that it has 6 pins connector and can't find a handle that is similar for my station ...
                        Has someone some advice what to do, where to look, even how to...
                        01-07-2024, 05:44 PM
