Am I understanding this circuit right?
  • caphair
    • Nov 2011
    • 1249
    This is from an iPhone 6. I'm having a hard time understanding how q1401 controls the "handshake" to Tristar_pin to allow charging.
    I don't see anything controlling the gate of q1401 either. Am I write to assume current flow that I've traced in red?
    Re: Am I understanding this circuit right?
    Do you mean Q1701?
    Voltage Source is fed to the Source pin of that P-CH MOSFET (Positive is applied to SOURCE pin so DRAIN has to be less positive than the SOURCE pin), when the Gate Voltage is 3~5V below the Source the MOSFET will be turned on then you will have Voltage at the Drain pin.
    Do you see that NETLIST named 'REVERSE GATE'? That pin goes to other circuit that has the same NETLIST name that you need to find, that will be what control the MOSFET, that NETLIST named 'REVERSE GATE' may go to more than one place.
    May be you should upload the whole schematics for people to see.
    • caphair
      • Nov 2011
      • 1249
      Here is full schematic. I don't see netlist 'reverse gate' anywhere. Even searched entire PDF
        That NETLIST 'REVERSE GATE' has to be some where in the schematics.
        That one page Schematic is not going to be enough.
        • caphair
          • Nov 2011
          • 1249
          I've searched the entire PDF of iPhone 6 and did not find another 'reverse gate' net. There aren't even any page numbers next to it indicating where else it would be found in the PDF. I'm puzzled as well
            BTW, so what DCV do you have right now at S, G, and D?
              • 31138
              look more closely.
              the fet is bypassed with a diode to allow INCOMING power to reach the chip,
              the fet is only used to enable OUTGOING power for USB-OTG use.
              • caphair
                • Nov 2011
                • 1249
                Originally posted by stj
                look more closely.
                Could you explain this more?
                @budm I don't have one to test I'm just trying to understand the operation
                  • 31138
                  usb-otg = a usb port that can act as a master supplying power, or a slave like a memory stick.
                  the device needs to be able to detect 5v on the connector to know if it's plugged into a pc,
                  but also needs to be able to power it up with 5v incase you connect a memory stick etc.
                  • caphair
                    • Nov 2011
                    • 1249
                    So the p_in terminal acts both as an input and output? It's confusing because it's tagged "p_in" and the line "handshake" so makes me think USB 5v flows into it.
                    But if q1701 is a p channel then the source pin (Tristar) would mean 5v USB is being provided to the drain
                      • 31138
                      i would need the full schems.
                      what's your interest anyway? curiosity - or a faulty fone?
                      • caphair
                        • Nov 2011
                        • 1249
                        Curiosity. Trying to figure out how that chip knows you're using a genuine Apple charger. As I've read the Tristar chip is responsible for that and I see "handshake pin" on that line
                          • 31138
                          that's easy,
                          there are resistors between the power and data pins.
                          the combination of resistances tells the fone what charger your using.
                          this was originally done by blackberry btw, so the fone would not "boost-charge" itself when plugged into a pc and trash your usb ports!
                            • 31138
                            look at this:
                            there is a table on page16
                            • caphair
                              • Nov 2011
                              • 1249
                              Oh geez so what's all that "handshake" pin stuff about? I was under the assumption that because an Apple lightning cable had an integrated chip in it that it operated more complexly
                              • gabiz_ro
                                • Mar 2011
                                • 167
                                • Romania
                                Note that genuine Apple charger is charger
                                Lightning cable is ... cable.
                                For charger stj is right.Just resistors.
                                But for lightning there is more complicated things.
                                More info on http://ramtin-amin.fr/#tristar
                                • caphair
                                  • Nov 2011
                                  • 1249
                                  Ah yes I was referring to the cable. My mistake. It does look somewhat complex.
                                  So in my original post, are the red arrows I drew the wrong way current flows into that line?
                                  • gabiz_ro
                                    • Mar 2011
                                    • 167
                                    • Romania
                                    On the phone is little hard to follow schematics.
                                    But from a quick look I don't see any protection to reverse voltage.Could be in dock flex connector,but not sure.
                                    Also looking on 5S schematic,looks similar and 5V usb protect.
                                    As result if voltage right aplied tristar may enable charging and usb data,if reverse voltage aplied tristar disable charging and other circuits to protect.
                                    • caphair
                                      • Nov 2011
                                      • 1249
                                      What do you mean by reverse voltage applied?
                                      • gabiz_ro
                                        • Mar 2011
                                        • 167
                                        • Romania
                                        Reverse voltage,when you doesn't use genuine cable,chargers,etc.
                                        When right is + to + and gnd to gnd,is right,reversed when reversed.
                                        If you take a look at iPhone schematics from iPhone 3 to newer ones,you'll see that first ones use two transistors.If voltage applied right,then 5V from USB or charger reach to phone internals.If wrong or reversed voltage applied,then nothing.
                                        Seems like newer ones doesn't care if power line are reversed so only protect circuit is for tristar,if OK will power if not just do nothing.
                                        Seems hard to explain,but take a look at +5V from USB on iphone 3,3GS,4,4S...
                                        On all seems to be something that prevent reversed polarity,on 6 except circuit you ask in first post,nothing.
                                        This is not first post where you ask something iphone related.
                                        As you may noticed,for many components there is no generic info or datasheets available.
                                        So we may only guess what is about this.
                                        Short answer.
                                        Tristar P_IN pin needs to be powered with +5V to start charging and power on.
                                        Why? I don't know since I can't see or find tristar datasheet.
                                        • Astonished
                                          Fixing the Charge Circuit of the Batteries of the DC Motor
                                          by Astonished
                                          Hi friends of electronics
                                          What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
                                          The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
                                          Please help me fix this circuit.
                                          (the datasheet of the IC: https://pdf.datasheet.live/28...
                                          01-28-2025, 06:24 AM
                                        • Tarot Superstars
                                          Short Circuit tester
                                          by Tarot Superstars
                                          Hello.
                                          I have seen a short circuit tester made with 3 * 9V batteries, a voltage limiter component and a resistor connected to the probes of a multimeter.
                                          The theory is that the meter becomes sensitive enough to read very low resistances and the lowest resistance to ground on a circuit is likely to be a short circuit in that area.
                                          Link
                                          The Amazing $1 Short Finder Upgraded! Convert ... - YouTube
                                          https://www.youtube.com/watch?v=0eixDdCpiO4
                                          My multimeter isn't normally sensitive to very small resistance, but when I put a 1 mega ohm resistor...
                                          09-25-2023, 09:11 AM
                                        • Lvsitano
                                          Asus X532FL 3.2V at source and gate
                                          by Lvsitano
                                          I am having some trouble with troubleshooting a Asus X532FL rev 2.0 motherboard, which does not power on. So at the first MOSFET, I am getting 19V at the drain, and then 3.2V on both gate and source (compared with ground). Of course, the 2nd MOSFET's source will have 3.2v at source.
                                          First MOSFET is a QM3056M6 and 2nd MOSFET is a QM0930M3
                                          I already checked first MOSFET and source and gate are not shorted (drain with source not shorted either). Also I have 1.7V at the LDO rail (measured at the keyboard connector, as the power button is on the keyboard).
                                          First...
                                          06-26-2024, 02:13 PM
                                        • Alimash
                                          op amp circuit function?
                                          by Alimash
                                          I am repairing a ups which doesn't turn on ,it has the following ICs:
                                          SG3525 used to drive inverter mosfets.
                                          couple of uc3483, one for the power supply and another to drive a big mosfet at the output stage(i think the technique is called boost)
                                          A LM358 and TL074 for control mechanism and of course the uController.
                                          The SG3525 is shutting down every time the ups is turned on.
                                          I want your help to know the function of LM358 and TL074 in the system.
                                          I reverse engineered the LM358 circuit and i think that one of the block(A) is used for battery level...
                                          07-31-2025, 07:45 AM
                                        • Zentech
                                          Help Understanding Discharging Circuit on Laptop Motherboard
                                          by Zentech
                                          Ok, I have an HP Pavilion G6 and I'm trying to understand the "Discharging" circuit on the motherboard DA0R53MB6E1 REV E R53. I'm going to link to the diagram here https://cdn.badcaps-static.com/pdfs/...3fee8687da.pdf
                                          Discharger circuit is on page 41. So PU12 is the driver for all the MOSFET, my question is when you plugin the charger and before you press the power button, are you expected to have power on the source of MOSFET? Let's take for example PQ55, which is suppose to have 3V on Source. But with power off, there's no 3VS5 on Drain, so no 3V on Source....
                                          03-30-2021, 08:30 AM
