Biglite led driver mbd001 Over Volatage
  • lorins_core
    BlackSmith
    • Dec 2012
    • 552
    • Philippines
    i have a Biglite led driver.
    specification
    model:MBD001
    Input: 100-265VAC 50/60Hz
    Outout: 80-90VDC
    how come now the output is 125VDC...
    how can i fix this?
    first i check the 3 caps. all has been ok
    Any Solutions?
    TIA
    • 31138
    Re: Biglite led driver mbd001 Over Volatage
    is this 125v with the leds connected?
    btw, you have some cracked solder joints, resolder all the ones with a faint ring around them.
    • lorins_core
      BlackSmith
      • Dec 2012
      • 552
      • Philippines
      Thanks for you Advice.
      i do it. not luck.
      i check the voltage out. i notice fluctuate the voltage the meter 125v reading prove the 123V the 125V...
      advice to fix this?
        I think you are getting 125Vdc because it has no load, the 80~90V rating is probably if it has working LED string connected to the output, LED power supply is the constant source power supply. Did you verify that the LEDs are OK?
        Any more details you have about this LED driver and the LEDs strings?
        You should also provide good clear straight shot pictures of the top and bottom side of the board.
        • lorins_core
          BlackSmith
          • Dec 2012
          • 552
          • Philippines
          Thanks for your fast Response.
          I test new used working LED Panel. same problem if i used this led driver kit? Flicker then normal then after 3 sec. flicker.
            Is the LED panel made to be used with that power supply? What kind of panel is it?
            • lorins_core
              BlackSmith
              • Dec 2012
              • 552
              • Philippines
              Yes Done. i Change The Caps..
              Thanks to stj and Master budm.
                • Jul 2011
                • 6057
                So is the power supply working good now that you changed the three caps
                • lorins_core
                  BlackSmith
                  • Dec 2012
                  • 552
                  • Philippines
                  Thanks For Additional Info Men... I appreciate For your Answer i dont have a Esr Tester Someday i buy it.
                  Now My Boss Happy i fix this Stuff from China Made
                  Now I know how to Fix and I Share the Simple Knowledge to newbe's and other not know how to fix this BigLight Led Light Driver.
                  Flickering Problem. replace 2 Capacitor on the following area main filter 150Uf/400V and output Filter Cap 100uf/100v. with Circle Red see. the image attach below
                  Other info I Used The Name Brand Rubicon
                  Thanks Again. specially to Mr. Stj and Master Budm And to This Forum Site Owner and All Members More Power
                  • lorins_core
                    BlackSmith
                    • Dec 2012
                    • 552
                    • Philippines
                    Master budm sorry for late response for your question...
                    Here the Image
                    LED Light Panel
                    BigLite LED Inverter Driver
                      Thanks for the follow-up.
                      "i notice fluctuate the voltage the meter 125v reading prove the 123V the 125V."
                      I am surprised that what you found on the output Voltage swing was only a couple of Volts, I expected a lot more if it has bad caps, may be your does not have fast response.
                      • lorins_core
                        BlackSmith
                        • Dec 2012
                        • 552
                        • Philippines
                        Thanks Master Idol budm...
                        • osrex
                          LED DRIVER KEEPS DYING
                          by osrex
                          Hello, this is my first post and im just a beginner, so be easy on me guy. thanks
                          i have a LED chandeilier that switches colors from white to cool white to warm when toggling the switch, it has 24 LED arms, each arm is 30 CM length.
                          i have no datasheet at all for the LED lights, all i have is its length.
                          long story short, testing the chandelier on the ground, and it works fine for 1 - 2 - 6 hours, no problem.
                          as soon as i fix the chandelier to the ceiling and bury the driver inside the hub,...
                          05-05-2025, 03:36 PM
                        • howardc64
                          Vizio E55-F1 dark backlight zones. LED failure or Dimming Zone Driver?
                          by howardc64
                          Problem
                          Fixing a dimming zone TV with LEDs not lighting up. Dimming zone circuit introduces added variable to diagnose LED and/or Dimming Zone Driver board? Some 1/2 rows of LEDs appears to be out in active dimming zone off AND some brightness flickering with active dimming zone high while playing changing video
                          Model & Board Pics
                          Conflicting Spec
                          Vizio indicate this TV has 10 dimming zones. However, LED strips and Zoned light driver connector suggest 12
                          https://www.shopjimmy.com/vizio-gj-2k1...
                          10-10-2024, 01:16 PM
                        • charif
                          Audio Driver for Thomson P14C4BK128
                          by charif
                          Need Audio Driver for Thomson P14C4BK128 (Windows 10/11)
                          I'm looking for help finding the correct audio driver for my Thomson P14C4BK128 laptop.
                          The sound is not working properly, and I believe the audio driver is missing or not installed correctly.
                          Here are the details:
                          • Model: Thomson P14C4BK128
                          • Operating System: Windows 10 64-bit
                          If anyone has a working link to the driver or knows where I can download it, I'd really appreciate it.
                          Thanks in advance for your help!
                          04-30-2025, 05:41 PM
                        • bohaboha
                          how to install gl usb2.0 uvc camera device driver on windows 10
                          by bohaboha
                          Hello all am trying to reinstall my AMCAP Microscope on windows 10 but it is not working anymore. But the cam and the drivers are present in the Device Manager but there it saysWindows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39) the drivers is : gl usb2.0 uvc camera device driver and i also get this mesage: Windows found driver software for your device but encou​ntered an error.
                          but it is quite strange because it did work on this same OS for one week ago and even for sometimes ago on that same but now nix.
                          any help?
                          01-26-2025, 08:33 PM
                        • Daveleone
                          UN55D6900 BN44-00428B partial led driver circuit failure
                          by Daveleone
                          Hello TV experts! I have a UN55D6900. The successfully TV turns on, and the backlights light up, and I get a picture, but there is a section that is dim. I took it apart and 1 out of 4 segments of backlight LEDs are not lighting on both sides of the TV (in other words, the same segment is out on both LED strips).
                          I tested the LED strips with my LED tester and all of the LEDs light properly, so I believe the problem is with the PSU/LED driver board (BN44-00428B). The voltages at CNM810 (between PSU and main board) look ok to me. The voltages at CNL801A and CNL801B look off for one...
                          07-23-2021, 06:31 PM
