Has anyone made ?
  • bianchi77
    • Jun 2016
    • 1121
    Has anyone made ?
    Guys,
    Has anyone of you made a solder plate with heater and plate of metal ?
    I want to unsolder multiple pins of header and connector so I can reuse it...
    It would be easy if all the pins solder are melted together and I pull it out of the board...
    Anyone ?
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Has anyone made ?
    Check youtube I know theres some videos.
    • bianchi77
      • Jun 2016
      • 1121
      Any links or keywords for that video?
        • 31246
        buy a desoldering unit.
        • bianchi77
          • Jun 2016
          • 1121
          desoldering ? I have that, I don't want to take the solder one by one,
          my idea is, solder all the pins at once and it will come of by itself...
            • 31246
            yes, i have seen a solder pot used that way, but the pins dont come out clean and the holes are blocked.
            • NCSailor
              • Mar 2016
              • 9
              I would use ChipQuik before I would go to the trouble of making a tool for what sounds like a one time operation.
              http://www.chipquik.com/store/produc...ucts_id=210001
              No affiliation and it is a little expensive but it really works well for the jobs like this one.
              • bianchi77
                • Jun 2016
                • 1121
                Chip quick is simillar with solder paste then ?
                • bianchi77
                  • Jun 2016
                  • 1121
                  can it be with copper plate on the botom and heat up ?
                    • 31246
                    if you really want to heat a large area, you may be better with a 300-500w halogen lamp
                    • Andyy
                      • Aug 2016
                      • 28
                      Originally posted by bianchi77
                      Guys,
                      Anyone ?
                      Perhaps try a variant of the technique used in this youtube video:
                      http://www.youtube.com/watch?v=dCUSwADP6DE
                      • Tech2k
                        • Oct 2016
                        What my friends use to do back in the day to scavenge all the chips of old mainframe computer boards was to take an old aluminum, electric frying pan and fill it with high temperature cooking oil.
                        Turn up the thermostat to the highest point. You need about 365 deg. F. to melt solder.
                        If the oil doesn't get hot enough, take the thermostat apart and bend the contact on the bi-metal contact 'till it does. About 400 deg should do it.
                        Float your circuit board on the hot oil until the solder melts.
                        Hold the board with vice-grips and yank the parts off one by one.
                        Of course, great caution must be taken during this process and do it outside, not in your kitchen!
                        Try on an old unneeded circuit board to practice and see if this method will do what you need it to do.
                        BE CAREFUL!
                        • mariushm
                          • May 2011
                          • 3799
                          Soldering pots: https://www.youtube.com/watch?v=sHL0a80_oJc
                          Cup is made of a ceramic or metal material that resists high temperatures (200c+) , you melt solder without flux (solder bars) or solder with flux in it as long as you feed solder slowly and in a ventilated space (as the flux melts and evapores the chemicals in the flux aren't great for your lungs)
                          Soldering pots were designed and meant to be used initially for purposes like tinning leads of components or wires (put liquid flux on leads or wire, use a spoon or something to move away the dross that forms at the top and then put the wires or leads down in the solder and they get tinned.. here's an example: https://www.youtube.com/watch?v=BiVkI4IooH4 )
                          If you overfill the pot with solder it forms a sort of balloon top (i think the term is convex surface) so you can put a board or something that has through hole leads on top of that and the liquid solder will melt the solder joints quickly allowing you to pull out parts.
                          Similar tech is used in wave soldering.. a pump pushes liquid solder up towards a circuit board that was previously sprayed with lots of liquid flux and as the wave of solder goes over the leads and contacts it sticks to everything and the parts get soldered.
                          There's also solder suckers, there's desoldering guns (they have pumps which create a void at the tip so solder gets sucked inside the pump and solder gets stuck in a container.
                          Desoldering guns: https://www.youtube.com/watch?v=Ft50m8UU5WQ
                          There's also solder braid, which allows you to suck solder from surfaces through capilary action (liquid solder wants to flow up on the braid).
                          I don't really like to use solder braid because it's expensive and it's pretty much one time use - you use a piece and then you have to cut it off.
                          It's also important to use QUALITY solder braid, with flux on the braid. Braids without flux are pretty much unusable.
                          Chipquick is basically a low melting point solder, the combination of metals is well known and other companies make that kind of solder as well, but they're all more expensive as the raw materials used are more expensive.
                          It's basically a solder that melts at something like 100c and stays semi-liquid for longer time, which means if you add this solder to existing solder, you drop the melting point of existing solders down and the solder on the joints of a chip or component stays molten for longer time, which allows you to pull out a part more easily in some cases.
                          • pfrcom
                            Oldbie
                            • Jun 2006
                            • 1230
                            Badcaps solder pot thread
                            better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
                            • 6BW6
                              • Jan 2015
                              • 55
                              I have often thought of making a 'pre-heater'..... using a cooker element and thyristor or triac, a temperature sensor shouldn't be too hard to knock up, someone mentioned a frying pan wonder if 'Er in doors will notice anything missin'? Be hard explaining a missing cooker ring though.
                              Dave
                                • 31246
                                you would be better off using a linear halogen lamp, they are made in 120,300,500 & 1000w and they can be controlled a lot faster than a cooker element.
                                they also have a reflector and are dirt cheap - a 500w one costs about £7 fitting, reflector, lamp etc.
                                • prasad3030
                                  • Oct 2015
                                  • 11
                                  • India
                                  Hai
                                  • kc8adu
                                    • Nov 2003
                                    • 8832
                                    • U.S.A!
                                    i made a tip with #12 bare solid copper(house wire) for a weller gun to desolder dimm sockets.you could do the same.
                                    still have to clear holes but speeds up the job.
                                    • bianchi77
                                      • Jun 2016
                                      • 1121
                                      can you show me the photo please ? thanks
                                      • langbaobao
                                        DIY 3D-Printer WSON8 Pogo Pin Adapter
                                        by langbaobao
                                        Hi.
                                        I'm posting this here in part as a memo to self as well as to describe the procedure I used in case anyone else found it useful. I found a lot of the necessary information to make this work on this forum and I figured I would give something back. If this is not the appropriate place to post this, I don't mind it being deleted but I hope it can help other people.
                                        I got an admin password locked HP Elitebook 840 G5 recently that I wanted to unlock. I'm a relative newcomer to reprogramming and unlocking firmware. The only previous experience I had was unlocking a BIOS...
                                        01-08-2024, 05:58 PM
                                      • acedogblast
                                        by acedogblast
                                        11-02-2024, 05:13 PM
                                      • SS454
                                        vizio e650i-a2 backlight flashes then turns off
                                        by SS454
                                        vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                                        panel: au optronics T650HVN05.4
                                        72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                                        link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                                        Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                                        https://www.shopjimmy.com/vizio-56-0...-power-supply/
                                        Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                                        08-20-2020, 03:57 PM
                                      • Jidis
                                        Need T-Con Advice (Vizio P602ui-B3)
                                        by Jidis
                                        I made a big-ass mess here of my father's beloved P602, and I'm trying to figure out if I should order a batch of overpriced ribbons or if I'd just be throwing more good money at the bad.
                                        He woke up recently to a bunch of white bars going down the right side of the screen. From what I'd seen in these places, I figured the T-con board has gone out or has a bad connection. I took the back off and gently poked at the socketed ribbons and sure enough, got the image back. It was mainly the far left ribbon, and it would snap back to stripes if I let off the pressure....
                                        09-22-2025, 05:10 PM
                                      • GraphicMan
                                        Pioneer amplifier A-205 Relay not clicking after a mistake i made
                                        by GraphicMan
                                        Hello guys
                                        Because the unit is old (but only occasionally used) the loudness button causes some noise due to bad contact,
                                        sprays did not work, so i decided to solder the pins that it connects on the pcb at the on (loudness on) position
                                        i did that and it worked fine, i know from the bottom of my heart that the switch connects 2 pins and also d/c other 2 pins
                                        on every position it have (6 pin switch), so i was curious what would happen if i clicked the switch off while the pins are soldered at on (so basiclly on and off at the same time), when i did so the sound is gone, nothing...
                                        05-05-2024, 06:20 AM
