Liquid flux question ?
  • bianchi77
    • Jun 2016
    • 1121
    Guys,
    Does anyone know where I can buy liquid flux ?
    The one I have is paste one...
    • 31138
    Re: Liquid flux question ?
    for what? there are many types of liquid flux.
    • bianchi77
      • Jun 2016
      • 1121
      for soldering bga, reflowing...
      • bianchi77
        • Jun 2016
        • 1121
        is it safe if I thin paste flux with alcohol ?
        • mariushm
          • May 2011
          • 3799
          I use a no-clean liquid flux made by a polish company, AG Thermopasty, it comes in bottles from 50 ml to 500ml and prices from under $2.
          TME.EU distributes this brand in Europe, it's a reputable company.
          However, for bga and reflow you'll probably be better served by a flux that's more paste-ish, no water like liquid.
          Louis Rossman has a Youtube channel where he repairs Apple products and took it upon himself (and his company) to buy big quantities of flux from Amtech (which have an antiquated sales mechanism involving signing and faxing authorizations and crap like that) and reselling it in his online store.
          Here's the store link : https://mailin.repair/amtech-nc-559-v2-30-cc-16160.html and here's a video he made about this explaining in more detail: https://www.youtube.com/watch?v=9skxEr1eQ9o
          It's expensive (for quantity) but genuine stuff.
            • 31138
            http://www.mektronics.com.au/solder-...-flux-gel.html
            seems local to you - relativly.
            • Longbow
              • Jun 2011
              • 623
              I've never seen such a fanfare made over flux. Sure there are exotic products. Or should we say there are simple products out there with exotic packaging and prices. I'll let the professional micro-solderers use whatever magic product they want, but there are basically only 2 types of lead solder flux and they are acid core and rosin core.
              Paste flux is usually acid flux designed to solder copper pipes. Personally, I like to use liquid flux because it will hold a chip in place on the pcb. Flux really becomes an issue when higher temps and other metals are used, such as silver braze and brass. Then you might worry about burning off the flux, but not at electronic soldering stations. Pulleeze.
              Is it plugged in?
                • 31138
                no, there are many types of flux using many types of chemicals - using tree-sap is ancient history!
                i use EC45 with a small brush.
                • rhomanski
                  nowhere man
                  • 5157
                  • U S of A
                  Yeah but if your rosin sits too long and gets hard you can use it on your violin bow.
                  sigpicThe Sky Is Falling
                    • 31138
                    no rosin in my solder or flux.
                    if you do use rosin based flux, you can thin it with IPA, it's based on it anyway.
                    • capwizard
                      • Jun 2016
                      • 1991
                      I've been used Organic fluxes for 6 years, I collected pine tree rosin+alcohol +Lard or tallow +Olive oil then mixed it . (see the picture,look horrible but taste good.)
                      Tall oil rosin finds increased use due to its higher thermal stability and therefore lower tendency to form insoluble thermal decomposition residues.
                      One of the early fluxes was a mixture of equal amounts of rosin and vaseline. A more aggressive early composition was a mixture of saturated solution of zinc chloride, alcohol, and glycerol.(add acid, u can make a bomb.) (from WiKi)
                      • bianchi77
                        • Jun 2016
                        • 1121
                        What's IPA mate ?
                        • bianchi77
                          • Jun 2016
                          • 1121
                          Is it safe if I use rosin and acetone for soldering flux ? or alcolhol and rosin ?
                          because they're flamable liquid and I will use it in 300 degree celcius ?
                          http://dangerousprototypes.com/docs/Flux,_flux,_flux
                          I'm interested making it myself....
                            • 31138
                            IPA = IsoPropyl-Alcohol
                            dont use acetone unless you want an impressive fire.
                            • ozzy214
                              • Nov 2013
                              • 319
                              • usa
                              Coming soon to another Jackass episode
                              • phat34
                                • Jul 2016
                                • 13
                                Oh I thought he meant IPA beer.... India Pale Ale
                                • Per Hansson
                                  • Jul 2005
                                  • 5895
                                  • Sweden
                                  Yes that too, but you should drink that while doing the repair, not use it for cleaning
                                  • Kemer
                                    Liquid flux in kitchen owen
                                    by Kemer
                                    I will heat a graphics card in kitchen owen and will use a little liquid flux on it. I probably won't use that small owen for cooking pupose but want to ask if someone tried the same thing. Thank you.
                                    10-20-2024, 03:05 PM
                                  • Eleways
                                    Liquid Flux no clean
                                    by Eleways
                                    Hi
                                    I've just finish my favorite Flux, I used Loctite MF210.
                                    So my supplier is closed and I cannot find it in other place.
                                    I ask you a suggestion to find a better Flux to use for rework.
                                    I need a liquid flux no clean, no water based.
                                    I use it for rework/reflow on laptop motherboard by use an infrared machine (Achi Pro).
                                    I've got another good flux, a Solder Chemistry PRo, it's good but I need to clean it after rework, and in case of reflow the Bga don't move at temperature.
                                    Can you help me on this?...
                                    06-05-2021, 10:14 AM
                                  • Veyron7887
                                    Laptop overheating after replacement thermal paste
                                    by Veyron7887
                                    Hi. I have Asus X55C laptop from year 2013. It has i3-2328M CPU. I replaced stock thermal paste with high quality thermal paste. Before thermal paste replacement, I measured CPU temperature Around 65-70 degrees Celcius with stock thermal paste. If after the replace thermal paste, I measured CPU temperature around 80-84 degrees Celcius and fan don't stop when system is idle. I replaced the thermal paste several times but still did not change. Where is the problem?
                                    11-24-2024, 05:08 AM
                                  • chth96
                                    Is it good to use chemistronic flux off es835b for flux remover?
                                    by chth96
                                    I want to purchase any good flux remover But "chemistronic flux off es835b" is the most common flux remover in my nation..
                                    Or I have to purchase "3m novec flux remover" which is quite expensive in my nation?
                                    11-17-2023, 07:25 AM
                                  • silver60618
                                    How to clean Liquid Metal from under CPU?
                                    by silver60618
                                    Hi all, Im working on a board, that my customer brought to another shop, and smeared liquid metal all over the board.
                                    The laptop powers on, then shuts off. I noticed traces of Liquid Metal near the edge of the CPU, but I fear some maybe underneath.
                                    Has anyone ever tried Ultrasonic cleaning, or compressed air to remove or agitate the liquid metal?
                                    07-11-2025, 01:47 PM
