Why does reverse polarity cause damage
+ More Options
Posts
  • caphair
    • Nov 2011
    • 1249
    Is it because it can exceed the reverse breakdown voltage of semiconductors?
    For instance in low voltage devices say 1-5v is the reverse voltage rated a lot lower than that for damage to occur?
    Also I watched a video where a car battery was accidentally connected backwards and the main 80 amp fuse blew yet no other damage occurred. Makes me wonder what failed that drew so much current?
    • 31199
    Re: Why does reverse polarity cause damage
    nothing failed, the current flowed across the diodes in the alternator.
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8701
      Usually it is due to some parasitic (or protective) diode that is normally reverse biased but when you connect the battery backwards, they become forward biased and conduct massive current, causing thermal breakdown.
      Indeed the alternator rectifier is one example. If you want an easier example take a look at a 4-diode bridge rectifier: compare it when you have the battery connected to charge it. Then compare what happens if you connect it wrong...
      • caphair
        • Nov 2011
        • 1249
        If the current flowed through the diodes that caused the fuse to blow, why doesn't that happen with correct polarity? Or are they orientated in one direction normally?
          • 31199
          take a look at the direction of the diodes in a bridge rectifier.
          if you put power across the + and - outputs with the polarity reversed the current will flow through the 2 series diodes.
          • R_J
            • 9588
            We had a customer with some dc equipment they would hook up via clips to their car batteries to operate, someone always connected them backwards at least once. we installed bridge recitfiers with the + and - going to the equipment and the wires going to the clips went to the ~ ac in on the bridge. that way it did'nt matter which way the clips were connected to the battery the equipment always got the correct polarity.
              There are a few reasons. The main reason is in modern CMOS devices, there is a body diode from Vdd to GND, which is reversed biased normally. (The diode is actually formed by millions of parallel transistor body diodes.) Reversing power and ground causes current to flow through these diodes, causing a high amount of power dissipation and eventually destruction of the device.
              Additionally, you have electrolytic capacitors and conventional semiconductors that may not play well with reverse biased sources.
              • Longbow
                • Jun 2011
                • 623
                It should be noted that installing a rectifier bridge on the output of a battery introduces a significant voltage drop to the downstream equipment. The diodes may also have to be mounted on large heat sinks if big current is being drawn by the load. At least the bridge prevents unnecessary blown fuses. Tradeoff.
                Is it plugged in?
                • caphair
                  • Nov 2011
                  • 1249
                  What are those diodes in CMOS devices there for in normal operation?
                    May be you should read some of these about MOSFETs.
                    https://cdn.badcaps-static.com/pdfs/...3b1facbbe8.pdf
                    http://www.microsemi.com/document-po...osfet-tutorial
                    • Dev Goose
                      Help Needed: Reverse Polarity Issue on HP EliteBook 840 G4 – Where Do I Begin?
                      by Dev Goose
                      Hi everyone, I recently acquired an HP EliteBook 840 G4 (6050A2854301-MB-A01) that I'm hoping to bring back to life. I'm fairly new to laptop repairs but eager to learn and willing to put in the effort to understand and fix this. Any advice or guidance would mean a lot!
                      What Happened
                      The issue started when the laptop was accidentally plugged in with reverse polarity. Before this incident, the laptop would show a power/charging light whenever it was plugged in. However, now it's completely unresponsive—no lights, no power, nothing. I've been doing some research and understand
                      12-13-2024, 03:13 AM
                    • Kervin Mathumbu
                      Asus E410 only works on battery after reverse polarity
                      by Kervin Mathumbu
                      Hi everyone. Fixed my AC and despite trying to be extra careful, I reversed polarity and got a notable pop sound. Now the PC will only work on battery. Windows still shows the battery as charging but the count actually goes down until empty (I have two of the same laptops).
                      I have board R3.0 so the schematics on another thread here do not match mine. I have tested the BQ charge IC and my pin 1, 2 and 3 have 3.35v each - instead of 18v or 19v. Could this be a bad BQ IC or capacitor? Any thoughtful advise sould be greatly appreciated.
                      Mobo shows no visible sign of a fried...
                      07-15-2024, 11:26 AM
                    • Grunder
                      Mecer lobo 1200 /VR-1200BKS Not switching on
                      by Grunder
                      Hello guys,
                      I'm a TV tech and a friend has asked me to look at his Mecer inverter. I haven't connected a battery but plugged it in to the mains and it does run a lamp. The lcd screen is not illuminating. My friend says he mistakenly connected the battery reverse polarity but the Mecer site says it has reverse polarity protection and that I should check the fuses. The fuses check out ok and there is no sign of damage to most of the component's I could check with my meter. I had removed the transformer and heatsinks to check print underneath. Where do I start? Thanks, Mike...
                      03-21-2024, 08:59 AM
                    • kitedude
                      DPS5020 "power supply"
                      by kitedude
                      Hello. I have the dps5020 and I've blown the mosfets which I've replaced but the D5 diode is unrecognizable.Maybe someone has the schematic or the same device? Anyone knows what it is and where does the cathode go? (left or right) I'm a noob so I know nothing about anything. Complicated answers will not be understood.
                      Damage was due to reverse polarity for a second but it worked for months with bulged mosfets, then the final blow was more input voltage than 50v.​
                      11-26-2024, 04:55 AM
                    • Joel Ohana
                      Lenovo IdeaPad 3 15IAU7 that suffered water damage
                      by Joel Ohana
                      I have a Lenovo IdeaPad 3 15IAU7 that suffered water damage. It doesn't turn on (white power light flashes when on button pressed), and the amber light flashes when plugged in.
                      Symptoms:
                      • Short detected – sparks appear when touching the charging port connection with board with a metal (even a multimeter probe).
                      • Visible damage – after cleaning corrosion, I found 4 possibly burnt memory chips near PC3165, labeled UD5, UD6, UD7, and UD8.
                      What are my next steps to diagnose and possibly repair it without replacing the entire board? Any guidance would be greatly...
                      03-06-2025, 11:25 AM
