Basic Board Help
  • jamesmcuk
    • Apr 2016
    • 20
    Basic Board Help
    Hi
    I need a bit of help with this board. This board is one of two that work similarly. One which is working detect a printer cart being inserted when a bit of dark plastic goes between two sensors. The second pictured works the same way but detects if ink is in the cartridge through a window in it. Anyway. Its not working but I don't really know how to bypass it.
    One the back of the board represented by the colours on the pic are the sensors each colour is the pair for each cart. I could do with help trying to understand how to solder this up to make the board think the sensor can not see the other i.e. there i ink in the tank.
    Also what would NT1 be?
    Thanks in advance
    James
    • 31250
    Re: Basic Board Help
    no idea on NT1, mer the resistance on the working one.
    as for the rest, they are pairs of an led and sensor.
    to see which is which - look at them with a camera.
    or show the other side of the board.
    what printer is it, brother?
      What is the P/N of those OptoInterupter?
      http://www.utopiamechanicus.com/arti...ptical-switch/
      • jamesmcuk
        • Apr 2016
        • 20
        Hi Guys, Thanks very much for getting back to me.
        When I use a camera to look at them they do not light up as would be expected. I am going to go get my VM now and see whats supplied to the led circuit and yes its a brother.
        OptoInterupter! Thats what I should have searched for would have saved me a lot of time lol! Thanks. As for P/N - it says N73 on the bottom and 2x2 o the side. attached is a pic of the top side.
        Will measure now and update.
        Thanks again guys for your interest.
          Can you show the pictures of what are printed on the body of those Opto?
          • jamesmcuk
            • Apr 2016
            • 20
            This a few views of the board
            • jamesmcuk
              • Apr 2016
              • 20
              OK Bit of an update. The working cart inserted board seems to have 1.18v at the LED side of the sensors and just over 3v on the receiver side. The resistance of the receiver goes from around 2k when covered to 900ohms uncovered. Does this sound right?
              The none working board has the 1.18v on the led side but does not seem to have a voltage on the receiver. I am not sure though if this is due to one being snapped off on the end of the receiver circuit. I can't see that is the case though as they appear to be wired in parallel.
              With no volts the receivers are open circuit.
                • 31250
                what model is that? i'v never seen inside a modern brother, interesting to see the cartridge area, and where the waste goes etc.
                • jamesmcuk
                  • Apr 2016
                  • 20
                  its a mfc-j65100w
                    OK based on this picture:
                    https://www.badcaps.net/forum/attach...0&d=1461868467
                    That part to the right of the board is the LED for the P11 Photointerupter, and the two holes with 'E', and 'C' marking are for the Phototransistor.
                    So look at the other sensor and look for E, C markings on the board.
                      BTW, when you check the DCV between Pin E and pin C without anything between the slot, the DCV should be <1V, and when the slot is blocked by solid material, the DCV should go lots higher than 1VDC.
                      • jamesmcuk
                        • Apr 2016
                        • 20
                        OK done a few measures but get nothing on the damaged board across the phototrans. The working board however does as you say and ramps up when blocked.
                        This is the best I can work out for the layout of the board attached. I can see the 1.18 v supplying the LEDs but cant see any v on the phototrans. That said if I put one lead on the phototrans and the other on pin 3 or 4 of the ribbon I can see it go above 2.5v.
                        • jamesmcuk
                          • Apr 2016
                          • 20
                          On another note the missing part was there and it wasn't detecting the black cart. Now its snapped off its the same error. Do you think I just need to jumper 3v to pin 2 on the ribbon?
                            So you put the bad board in the good working machine and the Voltages do not look right compared to the good working board?
                            The Photo transistor is turned off when you have blocker between the slot so the DCV between E-C will be high. So the one that showing 0V between E and C when blocked means that the transistor is bad and not being turned off.
                            • jamesmcuk
                              • Apr 2016
                              • 20
                              The machine has 2 boards doing the same thing. One set monitor the carts being inserted which is working. Once inserted the second board is used to see if there is ink in the cart. This is the one that appears to be broke as the printer acknowledges the cart but then says can't detect which from what I have read is what happens when this board goes faulty.
                              So there is only one machine and I am trying to figure out how to override or fix the ink monitoring board to get it to print again. If I could just remove this board I would but it doesn't like that either LOL. Ultimately I just want to trick the printer into seeing full ink carts. The broken board straddles the cartridges and the beam is broken by a window. I guess if there is ink in the window it breaks the beam.
                              • jamesmcuk
                                • Apr 2016
                                • 20
                                another forum showed this http://www.techsupportforum.com/foru...ml#post2423149
                                its a different cable and printer but interestingly its pin 5 they cut. Do you think that would work here for me.
                                  To simulate that the Photo Transistor is turned OFF (Blocked) you will need to remove the E leg or the C leg off the board so the transistor will no longer be in the circuit.
                                  • jamesmcuk
                                    • Apr 2016
                                    • 20
                                    looks like the problem may be somewhere else then as the black cart PT is not even on the baord any more lol and it still says cannot detect black cart.
                                      • 31250
                                      i thought it detected what cartridge was in each slot by reading the eeprom on the top?
                                      • fzabkar
                                        • Mar 2009
                                        • 772
                                        I can't understand how you can measure 0V between the E and C pads in the black circuit if the transistor is not present, unless there is a problem on the main logic board.
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
                                        • howardc64
                                          by howardc64
                                          07-24-2025, 05:17 PM
                                        • Soulzink
                                          Samsug washing machine. Power supply DC41-00189a board issue
                                          by Soulzink
                                          I am trying to fix a samsung washinmachine power supply main board.
                                          I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
                                          Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
                                          The power supply board reference is the following: DC41-00189a
                                          I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
                                          04-19-2025, 06:26 AM
                                        • jb_Bak
                                          by jb_Bak
                                          CN6401
                                          Pin 01 NC
                                          Pin 02 NC
                                          Pin 03 "BL_ON": 0V
                                          Pin 04 "N/C"
                                          Pin 05 "STBY 3.3V": 3.5V
                                          Pin 06 "GND": N/C
                                          Pin 07 "AC_OFF"...
                                          09-27-2021, 04:52 PM
