Help with a clock radio
  • lopaka1998
    • May 2014
    • 11
    • usa
    I have an old ge clock radio from the early 80s. A filter capacitor shorted and killed the transformer with it.
    The clock still works - I've used a temporary 9v transformer to test it (after removing the shorted cap) and everything works.
    There are several filter caps with Rarcan brand, and one caps with rubycon brand with the following markings:
    Rubycon
    16v 470uF
    CE W
    8145
    S.C.
    85C M
    There are ceramic disc caps for bypassing high frequencies in the areas that need it.
    Is the rubycon also a general purpose cap? I was under the impression that all of the electrolytics would be basically for filtering purposes - but this one cap makes me question that - it's the same value as one of the other Rarcan caps, 16v, 470uf - but it is about 1/2 to 1/3 of the size. Why use a rubycon there? Would it be for size - or for maybe a different ripple current rating?
    Also - should I replace the diode that all this current went though? I don't want to do the repair only to have a diode die shortly thereafter. It currently reads fine - open in one direction, 0.57 voltage drop in the other. Considering this is a 34 year old clock - would it be a good maintenance step? and if so - which ones should I use?
    • 31009
    Re: Help with a clock radio
    any cap rated at 85' is general purpose.
    • kaboom
      "Oh, Grouchy!"
      • Jan 2011
      • 2507
      Rubycon
      16v 470uF
      CE W
      8145
      S.C.
      85C M
      Be sure there is a power transformer! GE was "infamous" for keeping to "transformerless" designs well into the solid state era. It wasn't till the Thomson buyout in '86 that they started with power transformers.
      GE clock radios commonly had a 5 watt ceramic dropping resistor, in a "pocket" in the rear where the P-TX would usually be, that then fed the rectifier. The other end of this resistor connected to the AC line, either thru the alarm or function switches/linkages.
      The speaker was either an odd 45-ohm type, or an 8-ohm unit with an audio matching transformer. Are you mistaking the output transformer for a power transformer?
      You will not just have one diode if you actually have a power transformer- there's always a full-wave, or bridge, rectifier to keep net DC out of a power transformer, if used.
      Take some pix of the top of this thing, w/o the cover.
      "pokemon go... to hell!"
      EOL it...
      All style and no substance.
      guilty,guilty,guilty,guilty!
      guilty of being cheap-made!
      • lopaka1998
        • May 2014
        • 11
        • usa
        Here are some pics. Maybe this is an exception. I'm seeing end of '81 era date markings on the caps and the original transformer. I'm sure it's a power transformer with multiple out taps. But I am still learning so correct me if I'm wrong. the transformer has been removed at this point, and is on it's side.
        https://www.badcaps.net/forum/attach...1&d=1454028404
        As far as I can tell, each of 3 taps has a single diode and a filter cap, so I think it's all half-wave rectification. Also - the highest rated cap is 35 volts, indicating a lower voltage than line voltage. The lowest voltage cap is 10v, as a dc filter to the speaker. The old transformer was a tamradio.
        P-TX? What's that?
        I don't think so - but let me know if I'm mistaken.
        There are 3 as far as I can tell (one for each used tap), and the transformer has 4 outputs and two grounds.
        Thanks stj. Ok - I'll replace it with a KMG then. Love your avatar. Feeling is mutual
        If anyone can send me in the right direction for rectifier diodes it would be appreciated.
        The input on the case states the clock only uses max 4 watts... It works fine on 9v - I've tested it wiring up a transformer temporarily to see if it still functioned. I've found a 9v 750mA transformer that I think will fit the bill.
        • kaboom
          "Oh, Grouchy!"
          • Jan 2011
          • 2507
          That's an interesting unit. Early 80's GE, but has more "cheap" looking PCB of the later stuff. Definately a power transformer- the audio output transformers were about the size of that tuning cap, except about twice as tall.
          Even that far back, they used Tamradio...
          P-TX? What's that?
          Power transformer.
          EOL it...
          • lopaka1998
            • May 2014
            • 11
            • usa
            I'm still looking for replacement diodes. The new transformer is 9v, 750mA, but I don't think the clock radio will use more than about half of that.
            I was thinking of using a 1N4002 diode but I've never replaced a diode before so I'm not quite sure if the specs are ok.
            Would 1N4002 diodes work for this application?
            I think I saw one of those the other day on one of the youtube videos I was watching of a vintage radio repair. It had a hole in the center for adjustments that was about the size of a pencil.
              • 31009
              1N4007 general purpose rectifier.
              cheap and usefull upto 1a at 1000v
              • lopaka1998
                • May 2014
                • 11
                • usa
                thanks stj.
                I've got one last question. There are 4 ceramic capacitors for bypass at the transformer outputs that connect just before the diodes, so it's still technically ac. I want to replace them too as i'm not sure if any of those parts got overloaded (they do measure within spec though).
                So my question: I've heard X7R shouldn't be used for pulses... Would a Z5U work in this case instead? I'm trying to find replacements for them but find myself confused after reading up on it.
                3 of the caps read
                R
                103M
                t
                the other reads
                al-5
                471m
                tdk-u
                So the first three I think are 10nF or 0.01uF, 20%, and the fourth is 470pf, 20%
                Could I use something like this?:
                http://www.mouser.com/ProductDetail/...kmgfnHP8Zas%3d
                  • 31009
                  if they arent shorted, ignore them
                  • lopaka1998
                    • May 2014
                    • 11
                    • usa
                    Arg.. .Just when I thought I was done, I've found another problem - an open inductor. Picture attached. It goes from the mains to the input of the transformer. It's got a red dot, a black dot, and a big brownish gold colored mark on it's right side. It's marked as L9 on the board.
                    When I patched a different transformer in there temporarily, I bypassed the inductor because I used the power cord already connected to the new transformer - thus I didn't spot this earlier. Anyone know how to read these old part values, and what a suitable replacement would be?
                    It's 120v/60hz here.
                    • xelectech
                      retired tech
                      • Nov 2014
                      • 238
                      That attachment didn't work for me - brings up this error "Invalid Attachment specified. If you followed a valid link, please notify the administrator"
                        • 31009
                        brownish gold isnt good enough, it's brown OR it's gold.
                        you need to decide.
                        codes are like resistors,
                        so red, black = 20
                        now we need the multiplier/divider digit
                        • lopaka1998
                          • May 2014
                          • 11
                          • usa
                          Weird... it was working yesterday! Seriously
                          Here's attempt 2. I've reattached to this post.
                          The picture reasonably represents the 3rd color. Stj - it's sort of in the middle. I would guess gold but look at the picture and let me know what you think.
                          I've got two other opinions, one person thinks brown, one thinks gold. I guess this is the question of the day, for me at least.
                            • 31009
                            it's gold.
                            there is a brown one for comparison in the bottom of the foto.
                            so it's 2uH at whatever minimum voltage & current you need to put through it.
                            • eccerr0r
                              Solder Sloth
                              • Nov 2012
                              • 8701
                              That inductor looks like a primary noise filter... 120V mains -> inductor -> transformer.
                              I was wondering if there's a way to tell whether that is more sanely 200µH or 2µH as I am not an AC power expert... though I'd say either will probably work just fine.
                                • 31009
                                it probably doesnt even need it unless the power is noisy,
                                i suspect the clock uses the ac rather than a crystal for timing and doesnt want to get fooled by glitches.
                                • fzabkar
                                  • Mar 2009
                                  • 772
                                  Xc at 60Hz for a 200uH inductor is 75 milliohm.
                                  Xc for a 2uH inductor would be 0.75 mohm.
                                  I don't know which frequencies would be targeted by the filter. I guess that would depend on the capacitor (LC filter).
                                  • lopaka1998
                                    • May 2014
                                    • 11
                                    • usa
                                    I want to put in in anyway. I would have replied sooner but there was a half-day power outage. A power spike from a previous outage is what actually took the end-of-life capacitor over the edge and short causing this problem.
                                    The power quality hasn't been good lately as all the power transmission infrastructure hardware is past end of life.
                                    The clock has a non-polarized plug, and each side has an inductor - but of different values. 2uH on one (open), and it looks like the other working one is rated 10uH (brown, black, black).
                                    What do you think of this one?
                                    http://www.digikey.com/product-detai...250-ND/2682541
                                    Would it be ok with line voltage? I've measured between 7-8mm between leads on the old inductor - so I might have to bend one of the leads little bit on the one I picked. If you know of something better, I'm all ears. AC input to the transformer is 120v, with about 5 watt max so 0.0416 Amps.
                                    To the person who asked about what's on the other side of the transformer, there are bypass caps (ceramic) rated at 0.01 uf, and then the diodes, then filter caps, etc...
                                    • shelby5041
                                      clock radio / radio lifespan?
                                      by shelby5041
                                      hi
                                      ive got a modern digital clock radio approx 15yrs old
                                      my question is how long can a clock radio or a simple radio last ss farcas operating hours?
                                      since elec components have limited hour lifecspan i would imagine the radio or clock radio would eventually fail.
                                      the reason i ask is because i have my clock radio on radio function 24/7 for the past 7 years and its still working fine....i leave the radio on ..never turn off past 7years...thats approx 60000 hours
                                      it uses very little power just a few watts i would imagine that may have something...
                                      09-14-2024, 03:30 AM
                                    • UserXP
                                      Vintage SONY Digital Clock Radio ICF-C12W no audio
                                      by UserXP
                                      Dear all,
                                      I have this old radio clock by Sony from the early 80s, I guess. The clock display works, but is dim, the function board appears to be OK - but the radio unit shows no signs of life. It doesn't produce a single noise, crack or anything from either FM or AM band. It's like it doesn't even power up.
                                      i opened the radio and it is full of some TRACON gray capacitors. They only have their negative strip printed, voltage and capacitace markings - no series, no temperature marking, nothing else.
                                      My question is, do you know of this brand of capacitors and how bad are...
                                      07-21-2025, 08:35 AM
                                    • littlejohn
                                      Emerson clock radio transformer
                                      by littlejohn
                                      Hello I have a Emerson research clock radio model CKS3516C and the transformer went out on it ,the label on the clock radio says 120VAC 6 watt backup battery DC 3v CR2430. the numbers on the transformer ST3591C-13SEN which I can't find anywhere for it. Can anyone please tell me the AC output voltage. Thanks
                                      08-30-2023, 07:13 PM
                                    • TinkerTron
                                      Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
                                      by TinkerTron
                                      Hey everyone,
                                      I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
                                      Instead, here's what's been bugging me so far:
                                      The schematic...
                                      03-06-2025, 02:03 PM
                                    • ClockChip
                                      GE 7-4643A Clock radio - Is this a common pictogramme for 9-volt battery backup on appliances?
                                      by ClockChip
                                      I came across this sticker recently:
                                      (It's from a 1980s GE clock radio - the model number is at the bottom left.)
                                      I worked out the top pictogramme (indicating a 12/24 hour facility) and bottom pictogramme (120v or 220v mains power) fairly quickly. But the middle pictogramme...ah. That one left me baffled for a time.
                                      (I won't say how long, exactly, because it would be too embarrassing.)
                                      Eventually, it dawned upon me that this was a pictogramme to indicate a 9-volt battery backup facility.
                                      My question is: has anyone...
                                      08-27-2024, 09:02 AM
