What is telephony? where does the VCC come from?
  • keeney123
    Lauren
    • Sep 2014
    • 2536
    Re: What is telephony? where does the VCC come from?
    So this is the problem 2 volts at pin8 when you need a minimum 4.75 VDC to operate that chip. I am not sure but I would say the 5 volts is being generated on this remote board and is being fed by another connector. If you unplug this R11 connectors and leave the other connectors connected then measure the same two points again pin 8 and pin 5 what do you get?
    • scampo77
      • 233
      There is no other connectors, only these 4 conductors on the phone cord. I am pretty sure the power comes from this logic board leaving on the red "D" terminal.
      I was wondering if I could just jam 5v to this D terminal, to see what happens? I don't know if this is a good idea or not.
      • keeney123
        Lauren
        • Sep 2014
        • 2536
        If the voltage goes away between pin 8 and pin5 with the R11 connectors disconnected we will "assume" the 5 volts is coming from the main board.If it is coming from the main board we need to determine which board is causing this. So now I would measure the voltages on the R11 connector while it is unplugged from the remote board in reference to the gnd pin on the R11 connector that is unplugged. See if the voltages change their reading while unconnected as oppose to connected. If they do we will again "assume" the problem lays in the remote board. Also when the R11 connectors are unconnected from the remote bd. go the the main board and measure the same points on the main board. This will verify what ever the main board is putting out it is getting to the end of the cable if both readings are the same.
        • fzabkar
          • Mar 2009
          • 772
          Sipex was acquired by Exar.
          Here is the current support page and datasheet for the SP483E:
          http://www.exar.com/connectivity/tra.../rs485/sp483e/
          http://www.exar.com/common/content/d...et&part=sp483e
          R5F21256SNFP, Renesas, R8C, SINGLE-CHIP 16-BIT CMOS MCU, 2.2V - 5.5V (f(XIN) = 5 MHz):
          • fzabkar
            • Mar 2009
            • 772
            The component marked "F" on the logic board appears to be a polyswitch resettable fuse. I would expect that it would be protecting the outgoing supply. What voltage do you measure there? Does it connect to the RJ11 jack?
            • keeney123
              Lauren
              • Sep 2014
              • 2536
              The F is near the RJ11 jack right above the TP10 on your picture of the main board. You can do that, but you still are going to have to determine which board is causing your problem.
              • fzabkar
                • Mar 2009
                • 772
                ISTM that the "logic" board has a problem.
                The A&D differential pair appear to connect to the data pins of the SP483 transceiver, so that's OK. The B&C pair are the power pins. C is ground, so that looks OK, too. The OP needs to determine where the -1.1V is coming from. AFAICT, that should be a positive supply. I would look for any chip that might be a regulator. In fact I can see at least one LDO (Sipex SPX2951ACS) in the earlier photos.
                There is also a DF04S bridge rectifier (near CON111). I wonder if that's the source of the negative voltage.
                https://cdn.badcaps-static.com/pdfs/...415d4937ea.pdf
                • scampo77
                  • 233
                  #28
                  The voltage defiantly drops to 0v on the remote board when I unplug the phone line. on the main logic board I get an unusual result, I get 4.2v when I unplug the remote and then I get 3v when I plug the rj11 in.
                  I have 0v on both sides of the F thing located below the 483ECN
                  while taking measurements for this photo. I moved the board someway that it didn't like and one of the big relays clicked and now everything is 0v, DAMMIT!!
                  now as soon as I connect the B+ it clicks the relay and now I have no remote to visually see what the hell is going on, I am so discouraged.
                  • scampo77
                    • 233
                    #29
                    so after throwing my hat in the air and kicking my cat across the room out of frustration, I came back and realized that my main logic board is not totally dead. I have power to most of the ICs I had before. I now have 4.25v at terminal D leaving the logic board and arriving at the remote board, The remote board is still not working.
                    I still have power to the 483ECN on the logic board, the only difference now is that I have 4.25v output to the red D circuit.
                    • fzabkar
                      • Mar 2009
                      • 772
                      Is the supply to the remote unit actually AC, and are you actually measuring a DC offset of -1.1V on this supply??? An AC supply would resist galvanic corrosion.
                      Is there a rectifier and regulator on the remote PCB?
                      • scampo77
                        • 233
                        #31
                        Measuring A+B together with my meter on ACV I am getting 2.5VAC. I have no way to scope this reading but I suspect you are onto something.
                        If you look on post #6 there is a photo of the remote board, I don't think there is any rectification circuits here, but I'm not 100% sure what I am looking for.
                        • fzabkar
                          • Mar 2009
                          • 772
                          The two middle pins (B & C) would be the power pins.
                          What is that other 8-pin IC on the remote PCB? Where do those electrolytic capacitors connect?
                            Reverse the meter probes to see if you are still getting 2.5 VAC.
                            is this the remote board or main board? https://www.badcaps.net/forum/attach...5&d=1451312753, based on post 6 showing the remote unit.
                            So you do have bridge rectifier on the remote board. So you are getting AC between the two ~ pins of the bridge? You indicated 0V, and 5V and 7.5V, diode check OK for the bridge? 2.5Vac is not enough to produce 5VDC from the bridge.
                            • scampo77
                              • 233
                              #34
                              if I measure for ACV on pins on B&C then I get about 2.5VAC and if I reverse the probes I get 3.5VAC, but its really bouncing around on my meter, It fluctuates by.25v up and down.
                              I tried to get some photos of the capacitors and also the ICs on the remote. the other 8 leg IC is labeled MTAK 2951 ACMC. sorry I tried to get as many photos as I could but they did not come out very well. These are all photos of the remote board, when I remove the phone cable, everything goes to 0
                              • scampo77
                                • 233
                                #35
                                Bud, that photo you linked is the main logic board, I will try my best to label all the photos moving forward.
                                • scampo77
                                  • 233
                                  #36
                                  I have no idea what this piece is or what to look for, I just see that there is a "+" and a "-", so I checked for ACV and found some. I have never seen ACV on a circuit board before
                                  • fzabkar
                                    • Mar 2009
                                    • 772
                                    The LP2951ACM (on the remote PCB) is a linear voltage regulator. It comes in adjustable and fixed voltage versions. I suspect that yours has a 5V output.
                                    The 3-terminal component (15H) near the edge of the remote PCB could be a rectifier diode plus a zener clamp (?).
                                      • 31267
                                      see if any of the 4 pins on that are shorted together.
                                      • scampo77
                                        • 233
                                        #39
                                        On the main logic board at the rectifier, I have 5 ohms between the 2 pins on the right hand side, all other combinations have very high resistance.
                                        the picture enclosed is the remote PCB with voltage measurments
                                          • 31267
                                          that 5ohms sounds very wrong,
                                          does it read 5ohms wih the cable disconnected?
                                          • SluggerB
                                            Help with trying to fix phone that is not charging (Pics inside)
                                            by SluggerB
                                            I have two TCL A30 phones.
                                            Old Phone: This phone worked fine for years, then stopped charging If you plugged a charger into it, the phone would make the charging sound, the phone would tell you it is charging, but the battery icon would not have the charging symbol in it and the battery would not charge.I tried new battery, same behavior.
                                            New Phone: Works fine, bought as a donor board to try and repair Old Phone
                                            My interest here is to repair Old Phone, using components parts off New Phone if needed. I am not interested in replacing Old Phone with New Phone....
                                            08-12-2024, 08:11 AM
                                          • keeney123
                                            new OS on a Sonim XP5s phone
                                            by keeney123
                                            To you programmers out there I want to know if it is possible to put a new OS on the Sonim XP5s phone? I only need this phone to make calls, receive calls, have a list of contacts and be able to call voice mail.
                                            I bought this phone new Sep.2021 as an unlock phone from a third-party seller. The phone worked fine until Jan 2022. I then had intermittent problems with the sound setting resetting itself. One of the settings, outdoor, would go to silent all by itself. When in silent mode it does not indicate a call has come in. I missed very important phone calls. All the other setting in sound...
                                            05-13-2022, 07:19 PM
                                          • mikey5791
                                            Help with Samsung Galaxy J7 Prime phone
                                            by mikey5791
                                            Got this smart phone free from a guy who dropped it hard until the lcd display cracked with no seen display.
                                            Opened it and found the display ribbon cable partly damaged. I charged the phone full in 2 hours time, the led red light turns to green indicate full charge.
                                            Then i use a usb cable connect the phone to laptop but it only showed as media player with firmware version. Too bad there is no option to check folder.
                                            Does anyone know any method to check if the phone is working good? Looking forward for any advice and help possible.
                                            If tested the...
                                            09-15-2021, 07:54 PM
                                            Nokia C2-01 RM-721 RM-722 Phone Schematic
                                            The Nokia C2-01 RM-721 RM-722 was a mobile phone produced by Nokia. The Nokia C2-01 supported 3G and had a 3.2 megapixel back camera. It had a single SIM card. The handset was introduced to the markets in 2011. It replaced its predecessor, the Nokia 2700 classic and Nokia 2730 classic and has improved specifications....
                                            11-05-2024, 07:40 AM
                                          • Dannyx
                                            Cisco IP phone F-up
                                            by Dannyx
                                            Good day folks. I had a little f-up over at my new shop today and it made me pretty angry, but at the same time it determined me to try and figure out what could've happened there. This is only going to be a speculative discussion since I don't know the exact layout of our network, hence I don't know what's going on past our room. So:
                                            The repair shop where I sit is situated in a remote building down the street from the main building. There's a Cisco IP phone in this room, a 7911, like the rest of the company uses. There's obviously some sort of networking going on between the two...
                                            11-27-2018, 12:39 PM
