Transistor Substitutions
  • pentium
    • Mar 2006
    • 2778
    I'm in the process of repairing a Sony DVK-2400. Yes, if you googled that it's a reel-to reel portable video tape recorder from 1967. Aside form +12v the thing showed up on my bench otherwise totally dead.
    Anyways, it heavily uses the 2SC401 transistor. I've found at least one so far that is bad in the power regulation circuit and I cannot find a modern substitute that will work.
    I've been recommended I try a 2N3904 in its place instead but I'm not positive that it's a close enough match. The link above also lists a few substitutes but a lot of those are also no longer in production either, or they're $5-$7 per transistor which is nuts to order considering I probably have more than one that is bad.
    Anyone got and pointers on tracking down a substitute?
    Find Nedry!
    Check the Vending machines!!
    <----Computer says I need more beer.
  • watteau
    • Sep 2013
    Re: Transistor Substitutions
    My equivalent book states a BC546 as a replacement,
    the 2N3904 equivalent is also a BC546,
    (with different pin connections), and available via EBAY
      • 31002
      pull a working one and put it in a component tester if you have one - see what the spec really is.
      otherwise, find a schematic for the equipment
      • rhomanski
        nowhere man
        • 5157
        • U S of A
        Archive shows a KSC945 as a substitute. I've got bunches of them in stock. http://www.datasheetarchive.com/2SC401-datasheet.html .
        sigpicThe Sky Is Falling
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8701
          A 2SC945/KSC945/C945/C460/C1213/... is is probably a good bet especially on audio equipment, it should be a good match. I think the 2N3904/PN2222/etc. have a different pinout and you'd have to do some pin switching (swap pins 2 and 3) to make it work. Test a working one for pinout to be sure, but it's likely ECB wherease 2N3904 is EBC.
          • rhomanski
            nowhere man
            • 5157
            • U S of A
            Mouser has several flavors in stock at .22 cents each. http://www.mouser.com/Search/Refine.aspx?Keyword=ksc945 .HFE of 120 to 400 it looks like.
            • pentium
              • Mar 2006
              • 2778
              Looks like the 3904 did work after all.
              Find Nedry!
              • rhomanski
                nowhere man
                • 5157
                • U S of A
                Good. Glad to hear it.
                • DXseekerMO
                  Transistor TK15A50D substitute?
                  by DXseekerMO
                  Hello all, I checked alltransistors.com for transistor TK15A50D substitute and they say there is none. Just wondering if anyone knows of a substitute?
                  Thanks!
                  06-09-2020, 03:45 PM
                • magneh
                  Behringer Eurolive B205D repair - help identifying transistor
                  by magneh
                  Hello
                  Got this speaker from a friend , defective. Power led comes on and off , in a loop.
                  Disassembled, got the board out, and after a bit of measuring I found a low resistance on a 5v6 line. With a bit of current I found a transistor heating up on that line (labeled T1 and 113 as on pic).
                  After removing this guy, I got a value of 0.7 in diode mode on that 5v6 line, which before had 0.02 or something like that.
                  I tested powering it up without the IC, and the speaker turns on and stays on, and works fine
                  Still, I need to replace this transistor....
                  06-18-2025, 02:34 AM
                • elsomer
                  help to identify transistor msi ms-15ck1
                  by elsomer
                  hi people, i need some help to identify a transistor(q14) that is missing on the board, so the gpu has no voltage i think that q14 activate the phases for gpu, but i dont have schematic or boardview, but i think its the same transistor than q15 and q16, thanks...
                  02-17-2025, 05:30 PM
                • rddube
                  Help with blowing transistor NAD T752 receiver
                  by rddube
                  I guess I need help from the masters to try and find what is frying a 2SC5669 transistor on the left channel of this front center Amp for a NAD T752.
                  Was working perfectly and all of a sudden I heard a pop, and then a glow from the amp. Not only did the 2SC5669 burn a leg, but R520 which is a 220 ohm resistor partially burned - it now measures 110 ohms.
                  I bought this amp second hand fairly cheap as it was not working, it went into protection mode. I finally traced it down to the same transistor Q510, the one that just popped. It was shorted...
                  09-01-2022, 05:19 AM
                • amigo744
                  xbox series x u82 5 pin transistor voltages ?
                  by amigo744
                  hello there,
                  xbox series x hdmi u82 transistor 5 pin,
                  can anybody tell me voltages of this transistor in standby and power on mode ???
                  on which pin of this transistor are the voltages ?
                  regards
                  08-16-2023, 08:05 AM
