Simple circuit wiring, proper method?
+ More Options
Posts
  • xboxhaxorz
    • Jan 2011
    • 196
    So i have a 220v power supply that is powering several devices
    From the 12v + line i have a wire going to a spade connector, out of that butt connector is another wire that goes to an led that draws .9 amp
    The female spade connector is connected to the fan which has a male spade connector that draws .6 amps
    Is that safe, or will the led pull .9 amps. through the wire which will go to the .6 amp fan and overload it?
    The amperages are used for informational purposes and not the exact amperages FYI
    I also have a 12v switch, which is controlling 2 fans at .3 amps and .8 amps, from the switch output should i have 2 different wires going to each fan or should i just use a single wire which goes to the closest fan and have the other fan connect to the pos and neg points on that fan
    I am trying to get a drawing, but my skills lack in that area and its not coming out the way i want it too
    • 30953
    Re: Simple circuit wiring, proper method?
    spade connectors are rated at many amps - usually 10 or more.
    the weak point is more likely to be your switch
    • xboxhaxorz
      • Jan 2011
      • 196
      Both are rated high enough, im just wondering if the wiring should be done differently
      • xboxhaxorz
        • Jan 2011
        • 196
        Now that i look it over again i realize devices will only pull the amperage they need, i just need to figure out why a fan blew
        • Spork Schivago
          • Mar 2012
          • 4734
          • United States of America
          Current, or amperage, should be the same in the circuit all over, except for parallel circuits. For the parallel circuits, the sum of the branches in the parallel circuit should equal the total current for the circuit.
          Here's a site that I used when I was learning about it. It's fairly good:
          http://www.physicsclassroom.com/clas...allel-Circuits
          That's just for the parallel circuit. For the serial circuits, http://www.physicsclassroom.com/clas...eries-Circuits
          If you could draw a schematic, it would be a lot more helpful. There are programs that can help with this if you don't want to physically draw it by hand with a pen or pencil. Eagle is one such program.
          http://www.cadsoftusa.com/download-eagle/
          You are correct with your statement that it is in the components that determine the amount of current that is needed to drive the circuit. If your circuit requires 200mA of current, you can safely go over that and use 800 Amps if you wanted, it would only use 200mA. The 800 Amp would be over kill though, but it wouldn't hurt the circuit at all.
          -- Law of Expanding Memory: Applications Will Also Expand Until RAM Is Full
          • Spork Schivago
            • Mar 2012
            • 4734
            Do you have 12VDC going directly to the LED? Or do you have a resistor in there somewhere? 12VDC seems real high for an LED. Can you share a datasheet for the LED and the fans?
            And when you say spade connectors, are you talking about something like this?
            http://www.digikey.com/product-detai...21TR-ND/665808
            If you can't do the schematic, maybe you can share a picture of the actual circuit.
            Thanks!
            • harp
              simple win network with optimization issue
              by harp
              simple win network with optimization issue I like to ask some question about configuring simple room win network. So, there is 2 win computer, android4 device and wifi router not connected to internet. The purpose is storage space and manipulation with large files between any device. 1 pc - 192.168.0.2 (winxp sp2) wired to router port#1 2 pc - 192.168.0.5 (win10, enabled smb1.1) wired to router port#2 3 router - 192.168.0.1 with dhcp for wifi (192.168.0.101...) 4 main tablet - 192.168.0.101 (android4) wified to router wifi port I generally work and control transfer with my tablet via ES3 file...
              06-23-2025, 11:01 AM
            • Nevillet
              Simple PIR sensor circuit to drive a small motor
              by Nevillet
              Hi All,
              I'd like some help designing a simple circuit for driving a small DC motor.
              The PIR module is a HC-SR501 which runs on 6V supply and outputs 2.4V when triggered. (Datasheet attached)
              I'm not totally sure which motor I need yet but lets assume it'll be 12V and draw a maximum of 100mA.
              Can somebody design me a simple circuit for me using something like a 2N3904?
              I'm happy to include a relay if that makes sense.
              Many thanks.
              https://www.badcaps.net/forum/attachment.php?attachmentid=3...
              07-09-2023, 10:48 AM
            • handsworth
              Tv taping method made easy
              by handsworth
              Just wanted to share some information that I ran across when attempting to do the tape method on a tv with a shorted panel. I normally use magnifying glasses however while watching a you tube video, the person was using their phone. It seems that the Iphone has a magnifier app and wow, it works great. I have Iphone 11 and the app is built in. Pictures attached are screen shots. Made taping the pins a breeze. Also useful when reading the tiny print on the boards. Hope this helps somebody. ...
              02-11-2025, 09:07 AM
            • gabri2211
              I'm looking for the wiring diagram for led monitor model DHI-LM19-L200
              by gabri2211
              hello everyone, I'm looking for the wiring diagram of this led monitor.
              the model is DHI-LM19-L200, but I think that any other diagram of a DAHUA monitor could be equivalent.
              I really hope that among you someone can help me to repair this monitor, the screen is black, it doesn't seem like a backlight problem.
              I see the presence of 12 volts, 5 volts, but without a diagram the repair is very difficult.
              thanks to those who will answer
              12-10-2024, 04:37 PM
            • PNI E.
              Samsung eu75nu8000 no picture after tape method
              by PNI E.
              Hi guys, I write here for help me. I have a Samsung eu75nu8000. The Tv start to turn off and on, and I understand it was a panel problem, because if I take out a ribbon the Tv stay on. I tried the tape method but I have no picture but the Tv now stay on. My question is I have to give up because it s the panel? I notice that the chip vpm2sm it s really really hot, I can’t stay with my finger on it. Do u think all the problem of my panel is due to this chip, or u think it s a death panel and I can’t do nothing?sorry for my English
              11-10-2024, 03:46 PM
