Need help reading a schematic.
  • Spork Schivago
    • Mar 2012
    • 4734
    • United States of America
    #101
    Re: Need help reading a schematic.
    Originally posted by budm
    So You are getting 2.116V between the two legs of the 150 Ohms resistor using 15V power supply, then 2.116V/150 Ohms = 14.1mA on each string of the LED, so 8 string = 14.1 x 8 =112.8mA for TOTAL current draw, so your power supply must be able to supply at least that much of current.
    '2.116VDC * 8 = 16.928VDC, ' No, You are still confused about the circuit (sorry I was not clear about calculating the current through the resistor), you forget to calculate the current value after you know the Voltage drops across the 150 Ohms resistor.
    We was cross posting I think. I got different readings now that I had a good power source going to the board. Yeah, I measured the voltage between the resistor's two ends.
    I think I got it figured out. The current should be the same for each row, right? So the current for the resistor, being 14.7 milliamps, should also be the current that is going to the LEDs as well, right? Because the current in a series circuit is everywhere the same. And the current at the bottom of the board layout, the parallel circuit part, the current there would be 14.7 * 8 = 117.6 milliamp, the same number that the whole circuit uses. Do I have this right?
    -- Law of Expanding Memory: Applications Will Also Expand Until RAM Is Full
    • Spork Schivago
      • Mar 2012
      • 4734
      #102
      Hey, you got it now. So the power supply he sold you is on the over rated side as far as the current capacity is concerned. 15V 1/4A power supply will be good enough.
      But I have 11 more boards to hook up. Wouldn't each board require 117.6 milliamp? So 117.6 * 12 = 1,411.2 milliamps or 1.4112 amps?
        That is correct based on 12 boards, and then plus the control circuit and the display, so regulated 15V supply with 2A current capacity should be good.
        • Spork Schivago
          • Mar 2012
          • 4734
          #104
          Oh, that's great! I think I understand this! Here's some pictures of the timer board and the UV LED PCB, what do you guys think? Thanks for all the help! Really appreciate it. This stuff is really fun when I'm understanding it and each day, I seem to understand a bit more!
          I know the resistors I could of done a better job with. They were really really tiny though and it was really hard with no one helping. I was thinking of maybe trying to use my hot air reflow station to add some hot are and try to get the solder to melt a little bit so it looks not so mountainy like. You know, so the solder on each resistor kind of levels out a little bit and looks more uniformed.
          • Spork Schivago
            • Mar 2012
            • 4734
            #105
            Got the second board done as well! Looks a bit nicer with the SMD resistors. I think I'm getting better at soldering those dang little things! Lost one on the carpet and took us like 30 minutes to find!
            I wanted to find flat pieces of metal to solder to the VCC / GND pads there to connect the boards. Anyone has any suggestions for that? Hopefully, once I get this built, I can use it to make two giant LED boards instead of having to use 12 smaller ones.
            • Spork Schivago
              • Mar 2012
              • 4734
              #106
              Hey Budm, one last question here. I think I know the answer though. But each board will be provided 15 VDC, right? Because of that trace that connects the various boards together, the big fat one, is part of a parallel circuit and it's connecting to another parallel circuit, the voltage going to every board shouldn't be affected by how many boards I add, right? The only thing that would change is the amount of current that the boards are using, right? Ie, more boards, more power required, but not higher voltage.
                That is correct, the supply Voltage stays the same feeding the parallel loads, only the amount of current draw will change, you got the idea now.
                • keeney123
                  Lauren
                  • Sep 2014
                  • 2536
                  You can use like a Blunted fiberglass screwdriver to hold down the resister. First tin your iron then hold the resistor down with the instrument and tack one side of the resistor. After that is done you will have two free hands to solder the other side of the resistor. Wait till that side cools and finish up soldering the side you tack down. So, you could go down tacking all the resistors and once finished start at the first one as that should be cool and start soldering the other side.
                  • Spork Schivago
                    • Mar 2012
                    • 4734
                    #109
                    Okay! Thanks guys. What I've been doing is putting solder to one pad, then using tweezers, I've been putting the resistor over the pad that I soldered, then I heat that solder a little bit, move the resistor in place. It's hard because they're so small and even a little movement throws it out of alignment. I will try your suggestion though Keeney123 and see how it works.
                    Any idea how I can figure out what package these SMD resistors are? They're really small. About 2mm long by 1mm wide. Would that make them 0805's? I see 0805's are 2mm by 1.25mm. I see DigiKey have a few different things that have 0805 in them.
                    They have a category called Package / Case which has Wide 0805 (2012 Metric), 0508 then they have 0302 (0805 metric) then 0805 (2012 metric). They also have a section called Supplier Device Package. For that section they have 0805 and then 0805 (2012 metric). I don't know the difference between Package / Case and Supplier Device Package. I'd also like to know what's the difference between the various 0805 stuff so when I go to order SMD components for the count down timer PCB, I can try to get the same package for all of them. Thanks and Happy Thanksgiving everyone!
                    • Spork Schivago
                      • Mar 2012
                      • 4734
                      #110
                      Would this be one of those fiberglass screw drivers?
                      http://www.hardwarestore.com/fibergl...er-283754.aspx
                      • keeney123
                        Lauren
                        • Sep 2014
                        • 2536
                        No it would be for tuning coils etc. in radios, like this
                        http://www.rf-microwave.com/en/shop/...1-CT-4192.html
                        It can be anything that is small enough to put pressure down on the resistor without getting in your way of tacking down the resistor with the iron. Preferably something a flat surface that contact the resistor with a straight handle. I picked fiberglass because you can put a look of pressure on it without damaging the resistor. I assume you are using flux core solder? If you are not then you will need to put a little flux down before you tack it down and a little flux on the tip before you tin the tip.
                        • keeney123
                          Lauren
                          • Sep 2014
                          • 2536
                          Here is another company that carry the fiberglass TV alignment tools.
                          http://www.minute-man.com/acatalog/T...ent_Tools.html
                          One more company look under soldering tools
                          http://www.gcelectronics.com/order/c...y.asp?CatID=16
                          • Spork Schivago
                            • Mar 2012
                            • 4734
                            #113
                            Thanks. I haven't been using a flux core solder. I've been using a silver bearing solder and I have various types of flux. What seems to work okay is this liquid no-clean flux. I wasn't putting any on the actual tip though. Haven't really had any trouble with the solder sticking. Only problem seems to be getting those little buggers lined up just right.
                              • 31007
                              if you flux them and heat them with hot air they will float and re-align with the pads.
                              • Spork Schivago
                                • Mar 2012
                                • 4734
                                #115
                                OKay. I'm not very good with the hot air. I'm afraid I'm going to fry one of the boards. I usually use the hot air rework station for removing components but perhaps I should give it a shot. Perhaps I'll try throwing some flux and solder paste on the pads and see what happens.
                                  • 31007
                                  practice on something scrap.
                                  btw, you dont use flux with solder-paste.
                                  solder paste is flux already with powdered solder in it.
                                  • Spork Schivago
                                    • Mar 2012
                                    • 4734
                                    #117
                                    You sure about that Stj? Is the flux just for desoldering and I mistakenly thought it was for soldering as well?
                                    One product is ChipQuik Lead-Free SMD291 Tack Flux N/C for rework & reflow. The other product is ChipQuik Lead-Free SMD291SNL10 N/C Paste SAC305 L/F for rework & reflow.
                                    What's usually a good temperature / air flow to get the stuff working? I tried, unsuccessfully, to replace a really small IC. It had a lot of pins, like 48 or something. Really small. I ended up using wwwwayyyy to much paste. But I tried putting just a dab. I found that if the tip of the syringe was a bit warm, the paste would come out really smooth like and I could just use a dab. I couldn't get the paste to melt without using a higher air speed though. It ended up pushing the paste out of the way. I took the temp and increased it, trying not to push the paste. In the end, I burned the board and a trace lifted up and broke. I suck at this hot air stuff, unless it's removing components. I'd love to nail down using it though.
                                    What's the best way to get the paste on? I know it's probably using a stencil or something but I don't got one of those and I have no way to make one. I tried using some stencil cutter thing but it couldn't go small enough (we borrowed it from a friend). I could probably get a custom one built, but I'm sure there's an easier way.
                                      • 31007
                                      why would you need flux to remove something???
                                      say i want to remove a 144pin chip - because i do them by hand.
                                      (yes, i do!)
                                      i heat the chip with the handheld air unit, till it lifts off the board.
                                      no flux used.
                                      then i paint the pads with flux and re-heat them to make the solder flat and smooth
                                      then i paint the pads wih flux again,
                                      and the pins on the new chip
                                      then i place the new chip and re-heat the pads/pins till the solder flows.
                                      then i inspect it and if it's all aligned and o.k. i clean off the flux with ipa and get a beer.
                                      btw, when i refer to "painting" the pads/pins, my flux is water-thin liquid and i'm using a brush.
                                      • Spork Schivago
                                        • Mar 2012
                                        • 4734
                                        #119
                                        It was something that was suggested on a forum. I didn't actually look into the reasoning behind it. This was the post:
                                        Code:
                                        I am working with SMD for a while and I suggest you use leaded solder to treat the oxidized solder joints with flux before you get to the hot air stage. After solder mixture process, preheat the board close to 200C and continue with hot air station. I use analog hot air stations because I don't want to turn around and look at the temperature. I know where I have to set the hand dial without looking and I think that is between 7-8 on Hakko 852 station (around 420C). Preheat the chip from distance and can feel when it is enough to start. I count to 5 and viola pull the chip out without any problem. The hard ones are BGA chips and need precision timing and good BGA preheater. Average ICs are rated to 380C/10Sec I think but I am not sure.
                                        Also, I remember when I was looking at videos on how to remove the 360 GPU's / CPU's, for some reason, they were squirting a lot of flux under the BGA type components. I just thought it helped the solder flow a little more easier and that it'd help it melt all at once, instead of maybe a little of it melting here, a little still solder there.
                                        Was this incorrect and the flux isn't actually needed for desoldering?
                                        As for soldering with the hot air, I think I remember now. The flux was to help hold the component into place. I watched many videos on how to use the hot air station when I first got it. Some people would use flux to hold it in place and then put the solder paste on top of the pins, not on the pads. Others would put solder paste on the pads and then put the chip on. I wish I could find the video but I can't. Maybe it's my memory just remembering it wrong?
                                        (yes, i do!)
                                        no flux used.
                                        Okay, thanks. My flux is a bit thick. The paste is really thick too unless I warm it up a little (like preheating the board and then touching the tip to the warm board. That seems to make it liquid like).
                                        • keeney123
                                          Lauren
                                          • Sep 2014
                                          • 2536
                                          The flux is to transfer the heat from the iron to the solder joint. It allow a even flow through the joint and helps to get rid of oxygen in the joint. If you have no flux in your solder, flux will be needed to unsolder a joint with a solder iron. With a hot air gun, I do not know. I would think the flux would aid in a uniform heat. You do not need a lot of flux. With Surface Mounted Components they usually use a small flux bottle that has needle is attached and use just enough to wet the pads. This would be a liquid not a paste. I would think paste would be messy and harder to control.
                                          • waigy
                                            Variable resistor potentiometer has different reading when mounted on the board
                                            by waigy
                                            In my fusion FE-402 car amplifier the gain pot is an RK097G.
                                            I think it is anyway, the RK097G is the closest I've found to the original with the same pin number and dimensions.
                                            The differences are my pot is blue and has B203 on it and the shaft is plastic with a small slot at the very end only.
                                            I measured the resistance and found it went from 0 up to 10k so I ordered a 10k pot.
                                            I then took the pot out the board and it now measured 22k.
                                            I tried putting it back in the board and it goes back to 10k.
                                            Is this normal and if so what pot should I order?
                                            On this...
                                            11-12-2024, 04:44 AM
                                          • DeanWy
                                            WD Sentinel DS5100 (NAS) boot issues
                                            by DeanWy
                                            I have a Western Digital Sentinel DS5100 NAS system which has stopped working. It has dual BIOS. I bought the system second hand with an already broken primary BIOS (it rebooted multiple times until second BIOS was used).
                                            It worked until recently. The system was idle in Windows Server 2012 and a BSOD occurred, I think it was 'critical process died'. Thereafter it didn't boot, it just sat there with no video output and fan speed at 100% (there's a proprietary Windows driver by WD which controls the fan, outside of that it always runs at 100%).
                                            There...
                                            07-30-2024, 04:13 AM
                                          • gjgib
                                            Help reading schematic voltages input/output
                                            by gjgib
                                            Hello, this might be embarassing since I consider it a dumb question but keeps me kinda stuck sometimes in my journey.
                                            I want to know if there is any post in this forum which explains my questions. A) When, where and how do I know when X voltage line is input or output. Example:
                                            I'm battling with this IC to understand it's voltages. It's from non-turning-on Lenovo Ideapad 3 15iil05 - NM-D461.
                                            I see some lines like +5VL / +5VALW / V9B+ / +3VALW being okay and some others like 1.8VALW / +0.6VS / +2.5V_DDR. I just know that some of them are bad or missing,...
                                            05-06-2024, 08:11 PM
                                          • TinkerTron
                                            Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
                                            by TinkerTron
                                            Hey everyone,
                                            I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
                                            Instead, here's what's been bugging me so far:
                                            The schematic...
                                            03-06-2025, 02:03 PM
                                          • atunguyd
                                            Acer x163w Monitor PSU schematic
                                            by atunguyd
                                            Ii wonder if anyone can help me. I have a Acer x163w monitor which is not powering up. The PSU main capacitor's one leg had completly come off - I replaced it but the PSU is still not outputting DC. I found the monitor in questions service manual here on manuals lib but the schematic in there is a completely different - the schematic shows no mosfet to drive the transformer while the one I have does use a mosfet - also the schematic shows only one optocoupler but mine has two.
                                            The PSU board is labelled FM-20A02-AAA made by APD as per the image below. I am trying to find a schematic for this...
                                            03-05-2025, 02:08 PM
