Need help reading a schematic.
  • Spork Schivago
    • Mar 2012
    • 4734
    • United States of America
    I'm trying to learn how to build circuit boards. I ordered a kit off the net for a digital timer. Essentially, it's powered by a PIC and it has an LCD screen that gets connected to it. You program an amount of time and then it will provide power to another board that has a bunch of UV LEDs on them. You just use transparencies and photoresist boards with this kit and you get real nice circuit boards I guess.
    Anyway, I've downloaded Eagle and I'm trying to create a schematic for the timer board. The guy who sells the kits provide schematics and board layouts, but they're all in PDF format. Eventually, I'd like to modify the design a bit so the power supply and the timer are all on one board.
    I'm having trouble reading the schematic though. I've attached a copy. They use some different symbols, European ones I think they are. But I have a few questions I was hoping some one could help me out on. On the potentiometer located at A-6 (upper right corner), I see there's a pin that says S CONTRAST. And a bit further down in the schematic (B & C 4 - 5) there's some screw type connectors (to hook wires up to) that say X3-2 and X5-2. They both say S. Does the potentiometer go to both of those S's and to CONTRAST on the 16-pin header for the LCD screen?
    Also, for X3-1 and X5-1, do I just tie them together because they both say O and then send them off to the PIC where it says K1 and K2? And what does the P stand for under K1 and K2? Is that just the power to the relays?
    Any help would be greatly appreciated. Thank you.
    -- Law of Expanding Memory: Applications Will Also Expand Until RAM Is Full
    Re: Need help reading a schematic.
    The wiper of the pot P1 pin S (net label named 'Contrast') is connected to the LCD1 connector pin 3 (net label named 'Contrast'). As you can see there are only two net label with the same name 'Contrast' so those to are electrically connected together. You should learn more about net label to understand what it is and what it is used for in the schematic.
    Do not get confuse between the component pin names with net label.
    For example the pot P1 as shown in the diagram, there are 3 electrical pins: pin 'A', pin 'E', and pin 'S'.
    'Also, for X3-1 and X5-1, do I just tie them together because they both say O and then send them off to the PIC where it says K1 and K2? And what does the P stand for under K1 and K2? Is that just the power to the relays?'
    'do I just tie them together' No.
    Relay has 5 pin names: Pin '1' and Pin '2' are for the relay coil, then there are 3 pins for the relay contacts, Pin 'P' is the Common pin, Pin 'O' is the Normally Closed contact, pin 'S' is the normally OPEN contact. When the relay is energized, the pin 'P' will then make contact with pin S', pin 'O' is then no longer make contact with pin 'P'.
    • Spork Schivago
      • Mar 2012
      • 4734
      I gotcha Budm! I am a little familiar with net names and that's where my confusion came from. I thought there where two separate net names, S and CONTRAST. Like the potentiometer was connected to both signals. Does that mean for the stuff down by K1 and K2, they're just pin labels as well? The O, S and the P? Would they just be the labels for NO, NC and COM? The relay's are JS12N-K 1 pole power relays.
      I'll do a bit more research on the net labels as well. Thank you!!!
      • redwire
        • 3906
        It's a bit of a Euro schematic - and some people like to run wires all over and some like to use Nets.
        I think you are getting mixed up with component pin names and net labels. Also Belgium has three official languages: Dutch, French, and German so abbreviations are tough to figure out. You would have to ask what "S" and "O" mean in that language.
        The contrast pot has pins A,E,S (in English usually CW clockwise, CCW, wiper/slider) and the wiper pin "S" goes to Net CONTRAST which only goes to the LCD header pin 3. So the pin name "S" and Net name "CONTRAST" are connected to each other.
        The relays have pins O,S,P (in English NC, NO, COM) and here the "S" pin goes to connectors X#-2. It has no connection to the "S" pin on the trimpot because they are different components.
        PIC K1 and K2 Net labels (signals) only go to the 1k resistors. Their (Net) name is confusing with components K1 and K2 and not the clearest way to do a schematic.
        The common terminal on the relays "P" go to connectors X3-1 and X5-1 only. Not the PIC - you don't want the PIC getting high power going to its pins.
        Resistor R2 sets backlight LED current but has no value.
        • Spork Schivago
          • Mar 2012
          • 4734
          Thanks! So the K1 and K2 on the PIC go to the K1 and K2 net names on the 1K resistors. It is a bit confusing, because the relay's have names called K1 and K2 on the board layout but the schematic is using K1 and K2 as net names and the PIC has a K1 and K2. A bunch of K1 and K2's! Thanks for all the help guys!
          • Spork Schivago
            • Mar 2012
            • 4734
            R2 is a 16 ohm resistor. I don't know why the value isn't listed on the schematic.
              The output of the PIC PIN 2 net label K1 goes to the resistor R3 on the leg the resistor with net label 'K1' to turn on the the Transistor Q1 which drives relay K1 coil.
              Pin 1 net label 'K2' of the PIC goes to R4 to turn on Q2 which drive K2 coil.
              You have component designator, I.E.: K1, R1, C1, etc.
              • Spork Schivago
                • Mar 2012
                • 4734
                Thanks BudM. And then does one of the relays power the voltage regulator IC2 (7805) to provide the 5V that drives the LCD screen? Or am I way off on that?
                  No.
                  • Spork Schivago
                    • Mar 2012
                    • 4734
                    Okay, I think I got it. The relays power the UV LED boards. I don't know what I was thinking thinking that they powered the voltage regulators. I still got a long ways to go with learning this stuff but I figured this would be a good schematic to test my knowledge with. Hopefully, one of these days in the near future I'll be able to not only fully understand it, but also be able to modify it a bit.
                    • Spork Schivago
                      • Mar 2012
                      • 4734
                      I think I understand it a bit more now. Voltage comes in from the house at the X1-1 and X1-2 connector. It goes through the bridge rectifier B1 (B80C800DIP) which converts it from AC to DC using 4 diodes. It then powers the IC1 7812 voltage regulator which in turn powers the IC2 7805 voltage regulator. 7805 produces 5 volts and powers the PIC on pin 14 and also powers the LCD screen on pin 2 and pin 15. Pin 2 on the header is for the LCD's VCC, Pin 15 is for the LCD's backlight. It also provides 5V to the POT, which in turn controls the resistance going to the CONTRAST net on the connector that goes to the LED. Looks like the voltage regulator IC2 (7805) also powers the speaker there.
                      Is this right so far?
                      • keeney123
                        Lauren
                        • Sep 2014
                        • 2536
                        You'll get just hang in there. You have some good teachers. Are you using wire wraps or soldering?
                        • Spork Schivago
                          • Mar 2012
                          • 4734
                          Thanks! What the heck are wire wraps? I have a soldering station and solder components. I soldered all the components on the timer board already using my Weller. When I was younger, I had the hardest time soldering! I never had any teachers or anything. I had to learn it all myself until I found this place. It was insane, I tried adding solder to the iron and then touching the iron to the components (you can do that with SMD type stuff now a days but back then, it didn't work worth a darn!). I tried warming up just one terminal and adding solder. I gave up many times before I realized you had to touch both the pad and the lead at the same time and then apply solder!
                          A lot of great teachers here.
                          • Spork Schivago
                            • Mar 2012
                            • 4734
                            Are you talking about stuff like this?
                            https://upload.wikimedia.org/wikiped...ormat_1977.jpg
                            That's freaking old school! Wow. Do people still do that stuff? I got an old tube amp I'm supposed to fix for my buddy that's wired that way.
                              Do you have the wiring diagram that shows how the board is connected to the rest of the stuff?
                                • 30997
                                lol
                                that's a VERO-pen / RoadRunner.
                                not seen that shit in decades!
                                • Spork Schivago
                                  • Mar 2012
                                  • 4734
                                  Like how the timer board hooks up to the power supply and the UV LED PCB? Or do you mean a board layout for the timer board? I just looked on the site for a hookup diagram, that shows how the timer board connects to the UV LED board and to the power supply. I found one. Here's a link to it:
                                  http://www.e-stynus.com/index.php?ma...umentation&p=8
                                  I've also attached a copy of the picture so you don't have to leave this site to see it.
                                  I've also found on the site a picture of the board layout in what appears to be Eagle.
                                  • Spork Schivago
                                    • Mar 2012
                                    • 4734
                                    Originally posted by stj
                                    lol
                                    Wow, if you've seen that stuff before, you must be really old! Or maybe you just have experience working on older stuff. By most people's definition, I believe I'm what they call a youngin'. 34 years old (soon to be 35 in a few more months).
                                    • rhomanski
                                      nowhere man
                                      • 5157
                                      • U S of A
                                      Seen it? I've got the tools and wire to do it. A lot of old Pioneers from the seventies have wiring done that way. I try to keep them like original. I'm afraid sixty is getting real close in my windshield.
                                      sigpicThe Sky Is Falling
                                        So you already bought the kit? It comes with step down power transformer?
                                        • waigy
                                          Variable resistor potentiometer has different reading when mounted on the board
                                          by waigy
                                          In my fusion FE-402 car amplifier the gain pot is an RK097G.
                                          I think it is anyway, the RK097G is the closest I've found to the original with the same pin number and dimensions.
                                          The differences are my pot is blue and has B203 on it and the shaft is plastic with a small slot at the very end only.
                                          I measured the resistance and found it went from 0 up to 10k so I ordered a 10k pot.
                                          I then took the pot out the board and it now measured 22k.
                                          I tried putting it back in the board and it goes back to 10k.
                                          Is this normal and if so what pot should I order?
                                          On this...
                                          11-12-2024, 04:44 AM
                                        • DeanWy
                                          WD Sentinel DS5100 (NAS) boot issues
                                          by DeanWy
                                          I have a Western Digital Sentinel DS5100 NAS system which has stopped working. It has dual BIOS. I bought the system second hand with an already broken primary BIOS (it rebooted multiple times until second BIOS was used).
                                          It worked until recently. The system was idle in Windows Server 2012 and a BSOD occurred, I think it was 'critical process died'. Thereafter it didn't boot, it just sat there with no video output and fan speed at 100% (there's a proprietary Windows driver by WD which controls the fan, outside of that it always runs at 100%).
                                          There...
                                          07-30-2024, 04:13 AM
                                        • gjgib
                                          Help reading schematic voltages input/output
                                          by gjgib
                                          Hello, this might be embarassing since I consider it a dumb question but keeps me kinda stuck sometimes in my journey.
                                          I want to know if there is any post in this forum which explains my questions. A) When, where and how do I know when X voltage line is input or output. Example:
                                          I'm battling with this IC to understand it's voltages. It's from non-turning-on Lenovo Ideapad 3 15iil05 - NM-D461.
                                          I see some lines like +5VL / +5VALW / V9B+ / +3VALW being okay and some others like 1.8VALW / +0.6VS / +2.5V_DDR. I just know that some of them are bad or missing,...
                                          05-06-2024, 08:11 PM
                                        • TinkerTron
                                          Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
                                          by TinkerTron
                                          Hey everyone,
                                          I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
                                          Instead, here's what's been bugging me so far:
                                          The schematic...
                                          03-06-2025, 02:03 PM
                                        • atunguyd
                                          Acer x163w Monitor PSU schematic
                                          by atunguyd
                                          Ii wonder if anyone can help me. I have a Acer x163w monitor which is not powering up. The PSU main capacitor's one leg had completly come off - I replaced it but the PSU is still not outputting DC. I found the monitor in questions service manual here on manuals lib but the schematic in there is a completely different - the schematic shows no mosfet to drive the transformer while the one I have does use a mosfet - also the schematic shows only one optocoupler but mine has two.
                                          The PSU board is labelled FM-20A02-AAA made by APD as per the image below. I am trying to find a schematic for this...
                                          03-05-2025, 02:08 PM
