cordless drill charger-help needed
  • Joe Black
    eager to learn
    • Sep 2015
    • 173
    • southeastern europe
    I got this cordless drill from a buddy, and got a charger with it.
    The thing is, charger has an external adaptor, and he lost it somewhere.
    So, the question is, if the battery is rated 18V, what specs adaptor do i need for charger?
    stay classy
    • 31003
    Re: cordless drill charger-help needed
    it will usually say the input details on the label
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      i just rebuilt the 18v packs for a black&decker "grass hog" trimmer.iirc its wallwart was 24v 500ma.its an smps.
      • Joe Black
        eager to learn
        • Sep 2015
        • 173
        Nope,no label at all.
        Thanks,will go for something around 24 and 500mA
        stay classy
          • 31003
          a label on the drill then?
          if we know the make & model we can id the psu.
          • arsharpe
            Hitachi drill charger UC18YKL
            by arsharpe
            I am fixing the charger (UC18YKL) for a Hitachi battery drill (DV18DCL2) but, as it charges Lithium batteries, I need to know the correct replacement device for the blown (smd) FET2.
            As I have spent many hours trying to find a schematic for this DV18DCL2 charger without any luck, does anyone know where I can get one or a parts list?
            Thanks in advance for any help,
            Rob
            07-12-2025, 11:53 AM
          • flat-earther
            ASUS X54H laptop thinks it's always charging even with charger unplugged
            by flat-earther
            The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
            Windows also shows ''Plugged in'' when charger is not connected.
            This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
            Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
            If I let battery run out and say it has 3% Windows will...
            06-24-2025, 09:32 AM
          • motormayhem
            Lenovo T460 Only Charges on One Charger
            by motormayhem
            Laptop Question
            I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
            A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
            05-12-2023, 01:46 PM
            NVDC charger configuration...
            11-05-2024, 03:28 PM
          • Johndill
            Dell Inspiron 7567 LA-D993P odd charger issue
            by Johndill
            Hi, I have a Dell Inspiron 7567 LA-D993P that I've just got running.
            There was corrosion around PU1503 which shorted PC1518 & blew PL1504. (Reference pictures attached)
            I've replaced PC1518 & PL1504 & the laptop is now running however I now have another issue.
            Here are the tested scenarios:
            1. With the laptop running on battery, I plug in the 150W charger & the charger shuts off (no LED, protection mode) but the laptop remains running on battery.
            2. With the laptop off, plug in charger (LED says on) & the front charging...
            11-16-2022, 10:55 PM
