Hitachi drill charger UC18YKL
  • arsharpe
    • Jun 2025
    I am fixing the charger (UC18YKL) for a Hitachi battery drill (DV18DCL2) but, as it charges Lithium batteries, I need to know the correct replacement device for the blown (smd) FET2.
    As I have spent many hours trying to find a schematic for this DV18DCL2 charger without any luck, does anyone know where I can get one or a parts list?
    Thanks in advance for any help,
    Rob
    • 31183
    post pictures of the pcb and control chip
    • arsharpe
      • Jun 2025
      Thanks stj for your reply.
      Great news 😊
      I am a new comer to repairing and at first sight the FET didn't look like it has anything printed on it. However, with some bright light and careful placement of the most powerful magnifying glass I have, it was possible to read the component number.
      The number was W2K with 19 positioned vertically at the end and therefore looks like it is a 2N7002K.
      Thanks to everyone that viewed,
      Rob
      • Agent24
        I see dead caps
        • Oct 2007
        • 5035
        • New Zealand
        I swear some of these manufacturers mark their parts with colour-shift paint.
        -David VanHorn
          • 31183
          very fine laser etching - it's only visible at the right angle with a bright light
          • CapLeaker
            Leaking Member
            • Dec 2014
            • 8320
            Most of these tool battery chargers do not have a schematic. Most of the time you don’t need one either in order to fix it. Upload some clear straight shot pics of the board(s). If the FET is shorted, inspect the gate drive circuit.
            • motormayhem
              Lenovo T460 Only Charges on One Charger
              by motormayhem
              Laptop Question
              I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
              A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
              05-12-2023, 01:46 PM
              NVDC charger configuration...
              11-05-2024, 03:28 PM
            • flat-earther
              how to prevent a connected charger from draining battery when not charging?
              by flat-earther
              I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
              So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
              but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
              So the battery is backfeeding the charger and being drained.
              How can I prevent...
              08-07-2025, 01:04 PM
            • flat-earther
              ASUS X54H laptop thinks it's always charging even with charger unplugged
              by flat-earther
              The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
              Windows also shows ''Plugged in'' when charger is not connected.
              This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
              Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
              If I let battery run out and say it has 3% Windows will...
              06-24-2025, 09:32 AM
            • Johndill
              Dell Inspiron 7567 LA-D993P odd charger issue
              by Johndill
              Hi, I have a Dell Inspiron 7567 LA-D993P that I've just got running.
              There was corrosion around PU1503 which shorted PC1518 & blew PL1504. (Reference pictures attached)
              I've replaced PC1518 & PL1504 & the laptop is now running however I now have another issue.
              Here are the tested scenarios:
              1. With the laptop running on battery, I plug in the 150W charger & the charger shuts off (no LED, protection mode) but the laptop remains running on battery.
              2. With the laptop off, plug in charger (LED says on) & the front charging...
              11-16-2022, 10:55 PM
