Help Needed Identifying Component
  • RyanRiz
    Asus ROG STRIX G512LW-WS74 needed clearME bios after PCH replacement
    by RyanRiz
    Dear All,
    I need assistance creating clearMe bios. The laptop is shorted PCH, after PCH replacement laptop can ON but cannot boot. Power supply current reading is 2.5-3.0 Amp.
    Model : G512LW-WS74
    SN : LCNRKD009429512
    CN : ANE9
    Attach backup bios.
    Thanks for your help.
    Best Regards....
    01-14-2025, 05:55 PM
  • snipersquad100
    Dewalt DCR020 Power Board – No Power, Need Help Identifying ICs / Possible Replacement
    by snipersquad100
    I’m working on a Dewalt DCR020 jobsite radio that won’t power on.
    So far, I’ve checked the following:
    • The mains is reaching the transformer
    • Transformer outputs ~15-20 V AC
    • Bridge rectifier outputs ~15-20 V DC
    • All fuses test OK
    • The on/off button signal reaches the PCB connector
    Despite this, the unit does not power up at all.
    Inside, I’ve identified some of the ICs:
    • ST7317 (appears to be an LCD driver, not the main MCU)
    • LM2937L (voltage regulator)Not putting out power, 0.5V on the input
    • Markings like FS1235, unknown IC
    • Board number:
    09-01-2025, 10:57 AM
  • trepachka
    Help identifying a chip for Lenovo Slim 7 16IAH7 - schematics needed
    by trepachka
    I have this Lenovo Slim 7 16IAH7 notebook that is not booting properly. All voltages are there: 5v, 3.3v, 1.8v but it's still a no-go.
    I spotted this IC chip with markings "6611c" on it. The coil near this chip measures around 200 Ohms which I think is too low. But without the schematics, it's just a guess.
    I wonder if someone has the schematics for this board or perhaps, can help me identify this particular ship. Thanks....
    08-08-2025, 02:04 AM
  • sofles
    Bowers & Wilkins PX7 S2 Needed help with identifying charging IC
    by sofles
    Hi there,
    Recently I bought broken Bowers & Wilkins PX7 S2, the problem with them is that battery discharges on its own even with headphones turned off. It is a quite common issue with this model and even with model higher PX8.
    With help of thermal camera I found out that there is one IC that is hot even with headphones turned off. To check if I'm correct I bought another PX7 S2 working one and replaced small charging board with this IC and problem solved, battery no more drains on its own. After changing board back to original problem returned so I'm 100% sure problem...
    05-30-2025, 01:11 PM
  • crosswinds
    Assistance with identifying replacement caps on ASUS P5VDZ-MX
    by crosswinds
    So, pulled a motherboard out from storage, was working when put away, wont post when I took it out of storage today.
    Since it was working, and it looks to be essentially time that killed it I figured its a good idea to replace the caps before digging further.
    Looks to be only good quality caps on this board, so might not be the issue. But it is closing in on 20 years now so, wont hurt i guess
    Its a ASUS P5VDZ-MX board.
    I would really appreciate some assistance on what the best replacement caps would be for these:
    Panasonic(M)...
    04-17-2024, 04:25 PM
