Help identifying a chip for Lenovo Slim 7 16IAH7 - schematics needed
  • trepachka
    • Oct 2022
    • 457
    I have this Lenovo Slim 7 16IAH7 notebook that is not booting properly. All voltages are there: 5v, 3.3v, 1.8v but it's still a no-go.
    I spotted this IC chip with markings "6611c" on it. The coil near this chip measures around 200 Ohms which I think is too low. But without the schematics, it's just a guess.
    I wonder if someone has the schematics for this board or perhaps, can help me identify this particular ship. Thanks.
    • 22030
    Mother board model number.. NM-E241 ?
    • Gernet
      • May 2021
      • 60
      • Italy
      chip =6611C= is SGM6611CYTQV11G
      schemtics is here https://www.badcaps.net/forum/troubl...29#post3208329
      • trepachka
        • Oct 2022
        • 457
        The motherboard number can't be found anywhere on the board. It has Lenovo FRU: 5821J18076 printed on it.
        SGM6611CYTQV11G is exactly what I was looking for. The coil next to it measures about 150Ohms resistance which I think is too low. By doing voltage injection, only this chip lights up.
          • 22030
          It might be marked on the other side of the board, i think it`s NB6188B-MB-V2 I7-12700H
          • DynaxSC
            ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
            by DynaxSC
            Hi
            I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
            08-04-2025, 12:20 PM
          • Loki_Fido
            Requesting help identifying chip in Macbook Pro A2485
            by Loki_Fido
            Hi ya folks,
            I have this MacBook Pro A2485 (M1 Pro 2021) which came in for repair.
            It had a shorted SSD power supply chip. Therefore it was stuck at 5V.
            I replaced it and the SSD are fine. No more shorts.
            But The mac still pulls 5V and 200mA. If i leave it alone for 5 mins, the mac manages to receive 20V and 40mA. Of course, which doesnt mean the mac starts after power meter reading 20V.
            But while the mac is stuck at 5V, i checked the board with thermal and found this chip was trying to start. Chip picture is attached.
            Chip marking...
            08-07-2025, 10:17 PM
          • skdsp
            Need help identifying resistor values near BIOS chip on ASUS Zephyrus G14 GA402XV
            by skdsp
            I purchased a laptop that the previous user had tried to remove and replace a BIOS chip using a soldering iron not knowing that there is a ground pad under the 25R256JWEQ chip. In that process he damaged the BIOS chip and 3 of the resistors near the IO3, CLK, and IO0 pins. I have programmed a spare 25R256JWEQ chip using a CH341A programmer but not sure what values those resistors should be. If anyone has a boardview of this area and can provide those values that would be very useful for me.
            Attached is the photo.
            Thank you!
            09-27-2025, 09:05 PM
          • Ardent1
            Lenovo IdeaPad 3 15IIL05 81WE New Blank Chip - help needed
            by Ardent1
            Hello everyone, I have never flashed a bios before and currently find myself needing to flash a new Winbond W25Q128JVSQ chip without the original bios file.. I have a CH341A programmer and have been able to connect the chip to neo-programmer, but that's about as far as my knowledge takes me so far. When i read the chip the data appeared to be all FF for every entry.
            I do not know the history of the motherboard, only that the old chip was removed because it was dead apparently. When the on button is pressed, the laptop on battery alone just shows a solid white light on the side and same on...
            12-18-2024, 02:52 PM
          • trepachka
            Help identifying this chip for Yoga 7 16IRL8
            by trepachka
            This chip is shorted thru. Based on what I see, it's either a 3.3V or 5V buck converter, just my guess. The markings on the chip state "S2=AB".
            A photo of the chip is attached.
            Thank you....
            06-22-2025, 11:13 PM
