cannon printer powersupply problem.
  • gordesky1
    • Jun 2014
    • 66
    Re: cannon printer powersupply problem.
    Originally posted by stj
    the volts arent from the caps, they are going into the caps.
    btw, those are 1uf 100v
    the H is actually a u with a low tail - it means "micro"
    i'm not sure they are startup caps if they are only 1uf though.
    Yea i was having a hard time trying to figure it out if its a h or u lol
    Just wish i knew what is wrong.. was wondering if it damage the printer boards it self. tho i would think it would've did damage to the psu first.
    would try to get a new psu for it sense the printer is worth fixing for under 50$ and i also got refillable ink carts in it. But don't want to get one and find out it still don't power on and its inside...
      • 31219
      it wont cost more than a $ to replace the caps - just in case.
      something decent like panasonic NHG series.
        Post 10 "Than i tested the big 450v one i ony get 1.100v at that.. " So the dcv between the two legs of the main filter cap only has 1.1Vdc when the board is plugged into the AC outlet?
        It should have 165~170VDC as long as it is plugged into the AC outlet.
        • gordesky1
          • Jun 2014
          • 66
          Yep that's what it showed, what it looks like it seems like the psu is not fully powering on.
          Tho i was looking on my meter and saw 10megohm input dcv above the acv.
          should i be using that instead of acv? Didn't even pay attention to that option..
            You should used DCV mode since you are testing DC Volatage on the main filter cap. same thing when check the DC on the output side of the power supply.
            • gordesky1
              • Jun 2014
              • 66
              Ok just tested with dcv and here's what i get.
              Big cap 450v 176.5v
              The 2 end caps 11.72v and the other is 8.92 one is a 50v cap and the other is 35v
              And the very small caps not sure if they the start up ones or not i got 13.16v and 13.89 on the other they both 100v caps.
              So i was indeed testing them wrong.. lol Does those voltage sound right?
              Im wondering if its in the printer itself...
              • rievax_60
                • May 2012
                • 897
                • australia
                #27
                A friend had the same sort of problem with his Canon MFP after a power outage. He had simply forgotten that It needed to be turned on. It had a well hidden touch switch.
                Not all power outages have surges associated with them.
                • gordesky1
                  • Jun 2014
                  • 66
                  Wish it was just a hidden switch on this one lol The power switch is right on the lid were all the other buttons and lcd..
                  Tired even holding it down which usely resets it which did nothing, it was also left unplugged for a month which should of cleared everything.
                  Now if this was a cheap no good printer i toss it. But its a pretty good one which had alot of life left before one side of the house went out..
                  • rievax_60
                    • May 2012
                    • 897
                    • australia
                    #29
                    Those output voltage do seem a little unusual. Without knowing for certain, they have to be accepted for now.
                    There are methods for being more certain. Checking for ripple with an oscilloscope or just replacing the output capacitors. Also confirming that the regulation loop is working properly by tracing out the circuitry involving the opto and measure the voltage on the TL431 refrence IC.
                    If the power button is a tactile press button switch, they can fail to contact after not being used for a long time.
                      • 31219
                      if it worked while the psu was warm and now it's cold it wont run - think small caps.
                      heat the bastard with a hair dryer and then test it while it's hot!
                      • gordesky1
                        • Jun 2014
                        • 66
                        Will heat it up and see what that does.
                        • gordesky1
                          • Jun 2014
                          • 66
                          Ok i heated it up real hot than tried it and i still get nothing.. Than i tested the voltage at the plug were the printer wire plugs in the white plug. It has 4 blue wires and 1 5 wire . And when i have the probes on the last blue wire and white wire i get around 11.79v than i keep testing each wire when i have the probes on the same white wire and the middle blue wire i get 8.79v,
                          On the back of the cover of the of the psu that was on it, The voltages says 32v 0.75a 24v 0.5a. shouldn't i be getting 32v and 24v somewhere on that plug?
                          heres the pic of the plastic cover its not my pic but the same thing.
                          how to screenshot on windows 7
                          • rievax_60
                            • May 2012
                            • 897
                            • australia
                            #33
                            Maybe the output voltages are supposed to be low while in standby mode. Take a closer look at transistor Q5. Is it tied in with the resistor divider on the input pin on the 431 voltage reference IC? It's between the opto and Q5.
                            This is an example of how the 431 IC is applied. http://i.cmpnet.com/powermanagementd...67-Figure1.jpg
