Re: CRT TVs
Just joined today. I ran across your post about finding a Sony KV 7010U at a yard sale. Did you get it and most interested in knowing if it was a KV 7010U or a KV 7010UA. They look identical, but of course a big difference inside. I'm a collector of televisions.
CRT TVs
Re: CRT TVs
That coating is usually connected to cold/output side ground.
When cleaning my CRTs, I always wipe the dust on it with a wet towel.
Also, it's not the shock from the tube you should be worried about, but rather what you are holding in your hands and where you have them. That's because when you get shocked, your reflexes typically make you yank your hands back very quickly. And with a sharp tool in hand or with your hand near sharp parts, you can see how that can go wrong. This applies to any electronic device you work on, not just CRTs. As for CRTs, the HV supply is low current (typically 1 to 4 mA MAX) and will not kill you. As long as you have the TV unplugged and you're not messing with the anode, it's reasonably safe to open and work on.
, Singapore, and Mexico only (IIRC). I think only later in the 90's when Samsung and LG became more popular that Korean CRTs like Samsung emerged on the market. The only Chinese manufacturer I know made CRTs is Chunghwa (the same one that now makes cheap LCDs). But from what I understand, they came very late into the CRT game, which is why we don't really see their tubes anywhere. Had CRT technology remained popular today, I'm sure we would have seen a lot more Chinese brands.
In some CRT TVs, some of the small caps can be even more important than the big ones. I'm not a true CRT expert, so I can't tell you if your TV has any such important caps.
I think CRTs don't use low ESR caps simply because they are not necessary.
That said, if you do find that you need a special size/voltage/capacitance, let me know, as I have quite a few pulled caps from TV boards. Even have some SamWha and SamYoung capsthat came out of a Samsung-made TV.
Looks pretty standard for a non-Sony CRT of that era.
Re: CRT TVs
I got rid of two 21" trinitron CRTs when I moved house about 8 or 9 years ago due to them being old and using LCD's.
Really wish I hadn't as they are bloody hard to find now!
Picked up a Samsung Syncmaster 957MB the other day, its a 19" and a fairly late run crt @ 2003.
Its superb for my older retro/gaming systems that I like to build, games look amazing on it.
Has a usb socket on it to control the OSD via the pc too which I hadn't seen before.Last edited by Bungz; 05-06-2016, 04:04 AM.Leave a comment:
Re: CRT TVs
*WARNING*
*WARNING*
When discharging CRT aquadag capacitance, do NOT use "any old ground!"
You must discharge the HV to the ground strap on the CRT. Always return current to its source, the other side of the dag capacitor. If you dump the HV into one of the signal grounds, you'll backfeed the low-level circuits and destroy them, just as if lightning came in the coax and left on the third wire of a grounded power cord (via multiple parallel paths inside the set)- such as on "modern" LCD/plasma sets.
Shithead local cable company does not bond the incoming coax to the electric service per NEC 820.100 and 250.94. They make it worse by driving "ground rods," which when unbonded, bring lightning impulses (step potential) right into the coax!!! It then "equalizes" to the building elec service by going thru TVs and other equipment, such as a cable modem and your motherboard.
Had a nasty storm a few days ago, and plenty of TVs were damaged/destroyed beyond feasible repair. The "evidence" abounded; boxes for "brand x" sets with "brand y" sets (dead) inside.
So discharge that dag HV to the CRT ground strap, and only the ground strap!Last edited by kaboom; 05-04-2016, 10:11 PM.Leave a comment:
Re: CRT TVs
That will do it.
There's actually more danger from the primary bulk cap still being charged. But that really applies to any SMPS.
For just looking at it? - Nope. Zilch. None.
Cleaning? - Hardly any, especially if the TV is unplugged and has been off for an hour or more.
Pulling the boards? - No risk if you discharge the anode and primary bulk cap. The B+ filer cap usually self-discharges by itself too. But B+ is typically 120V DC, which even with sweaty hands won't hurt too much.I can't reach the bulk cap to check for voltage without removing the board. Would rubber gloves be good enough to pull that board out to discharge it?
Nope. Shadow mask flat tubes became rather popular in the early 2000's - especially Samsung tubes. Those tubs are actually still slightly curved on the inside, but you can't really tell by looking at the image. The only way you might be able to tell is from the reflection of the screen: if you see two reflections - one from anti-reflective coating and another "curved" one on top of it, you're probably looking at a shadow mask.I will study the front more closely when it isn't lying on its face.
There are a lot of Toshiba parts in here! ICs and most of the FETs I can see. I wasn't expecting to see Samsung or Toshiba parts in such an obscure brand.
You can see all of the Jianghai/JH caps, and a brand I have never seen before. AS?? I was going to make a list of all the caps in this thing. Is it even worth the trouble to replace all these small ones? I do plan on never getting rid of the TV...Most of the caps are 85C. How would such a unit react to replacing all the caps with, say nichicon PW, even the little ones?
Edit: The soldering looks pretty good, actually. Lots of flux though. I took pictures of the logo that is on every part of the unit except the tube. Anyone recognize it? How does the build quality of this thing look?Last edited by Pentium4; 05-04-2016, 04:31 PM.Leave a comment:
Re: CRT TVs
The HP OfficeJet Pro printer line says hello too.
As far as I know, the 2007-2013 models (and possibly current ones too) had this issue where a cheap thin plastic gear on the main paper feed/drive drive axle would break. This would make the printer throw an error and render it completely inoperable. I've seen a lot of those HP printers on eBay / CL described as "make grinding noises when trying to print". The fix is to remove that gear, drill through the metal drive axle, and put a metal insert.... that is, only if you don't mind taking the whole printer apart - down to the smallest detail to get to that part.
My KFC Smile CRT monitor has Jamicon, G-Luxon, and Elite caps in it. The picture does take a long time to "fill" the screen now (a possible indication that some of the caps may be starting to fail). But it still works. For a nearly 18 year-old monitor (made in 1998), I can totally forgive its flaws. I am actually more worried about the (formerly) beige plastic crumbling apart and the tube falling through. It is dark yellow now.
Nope. Shadow mask flat tubes became rather popular in the early 2000's - especially Samsung tubes. Those tubs are actually still slightly curved on the inside, but you can't really tell by looking at the image. The only way you might be able to tell is from the reflection of the screen: if you see two reflections - one from anti-reflective coating and another "curved" one on top of it, you're probably looking at a shadow mask.Leave a comment:
Re: CRT TVs
Just like those "GE" walmart can openers, which are actually made by HKFA (hongkongflyapart), complete with plastic gears. No wonder they only last a month or so. WM bought the rights to the "GE" name for nasty small countertop appliances. If you flip one over and read the dataplate, the "Manuf." field does not indicate "GE," it shows walmart (povertymart). IOW, it's a "walmart" appliance, branded "GE." It's a reversal of what Sears did with the old Kenmore brand. Whirlpool made all the KM washers/dryers for Sears and KM was Sears-exclusive.
The latest/last Funai CRT design was "perfected" from the late 90s-early 2000's; they had plenty of time to practice. The combo units with either/both DVD and that horrible VCR deck (that always jumped gear timings) used the same basic chassis, but main power would drop out when (not if) that VCR locked up.And that was in 2002 when VHS was still "the thing" It's cool to now know why it broke. I wonder if he still has it. I could post about it
But the basic ones, the 14 inchers without that damn VCR, seemed to be solid, refined designs other than caps.
FWIW, it would not surprise me if, during the 90's, there were some major "shake up" at Funai- this whas when they were dumping those $99 "supermarket" VCRs, with odd names like Symphonic and Broksonic. "Emerson" and "Sylvania" were also used (not the 80's Sylvania, which were Panasonic)- there were others, but I don't remember now.
I wonder if Funai was on the brink of something like a DVD chipset design/partnership, hence their giving all VCRs a bad reputation by dumping their junkboxes.
That's an interesting theory you have. It wouldn't surprise me!
If I ever get a CRT TV again, it would be (preferably) one of those 30+ inch sets. In particular, I really like the older (mid/late 90's) Sony CRTs with the flat vertical but curved horizontal screens - those are their best CRTs IMO... and toughest, too. The only "downside" is that they are SD only. But we all know resolution is NOT the only thing that matters.Eventually you'll come across one and you won't be able to pass it up! HDMI on a CRT? It's one of the most cool things to exist
I even prefer S-video on a CRT than SD on any flatscreen lol. Why was S-video even an option on non CRT TVs? It looks awful! (I'm talking video)
They will still probably last a long time.
You should. Maybe just open it to have a look inside and clean the dust. They are not as dangerous as people make them out to be, especially modern sets. And dis-assembly is easy.
Indeed.
I am curious who made the tube in your Apex TV, though. And what technology it uses (i.e. shadow mask, aperture grille, or Chromaclear).I would LOVE to see how CRT technology would have developed by companies such as Sony. If I become a billionaire, I will hire the best engineers in the world to continue improving CRTs lol.
Re: CRT TVs
aye, make sure they understand that they should never throw away anything thats still working. doing so just generates e-waste unnecessarily. u'd also be playing russian roulette and gambling with your money by buying "modern junk". doesnt make sense throwing away something that can last another decade to buy something that has planned obsolescence built into it and is designed to last only 1-3 years.Leave a comment:
Re: CRT TVs
Wasn't that big of a TV, though. Could move it myself if it had handles on the side (but it didn't).
. I know the Craigslist free section here has daily posts with CRT TVs.
Then again, the old 90's top-loading washer we had (Kenmore? brand) wasn't that much better either *and* it used.. no, wasted a ton of water.
I guess we do need us a washing machine thread, don't we?Leave a comment:
Re: CRT TVs
I was always wondering about that "Brokensonic" name...
I still have one of their CRT TVs. My mom bought it, after telling her NOT to buy it...Leave a comment:
Re: CRT TVs
IIRC, they both are, or were at one point. I think the OEM/brandholder behind Apex "diversified," and at one time spec'ced models for failmart.
But now, those KM washers are LG monstrosities and hardly wash anything in their two cups o' water- that's another thread.
Looking through the back grille, every board has a strange logo on it. It could be Funai. I'm not as worried when it comes to CRTs. Even the cheapest brands seem to last forever! One of my friends had an Emerson (Funai) CRT in his work shop. It only had cable and he literally never turned it off. Vacation/gone, thing was always running...Not sure when he started doing that but it was 15 years old. Years of doing that though. Thing was disgustingly dirty but kept on working! CRTs seem to be built very tough
But the basic ones, the 14 inchers without that damn VCR, seemed to be solid, refined designs other than caps. That Funai DVD drive often lost the red laser after between 1 and three years, killing DVD playback. The easy test was to try an audio CD- guaranteed to play. The IR lasers held up far better. Or they overdrove the red one to improve the SNR into their (questionable?) photodiode array and analog front end when playing DVDs.
I wonder if Funai was on the brink of something like a DVD chipset design/partnership, hence their giving all VCRs a bad reputation by dumping their junkboxes.Leave a comment:
Re: CRT TVs
Better ventilation. All the CRT sets I have seen have breathin holes in the bottom and on top or left and right side of the chassis. Lcds are crammed and they are getting thinner and thinner...Leave a comment:
Re: CRT TVs
Yeah they do. How?? They use more power than LCDs, maybe because they are more open in the back so they breathe better?Leave a comment:
Re: CRT TVs
I have to agree. And the caps seem to hold better than LCD's power suppliesLeave a comment:
Re: CRT TVs
Does Apex have something to do with Dynex? I thought they were worst buy's house brand. Looking through the back grille, every board has a strange logo on it. It could be Funai. I'm not as worried when it comes to CRTs. Even the cheapest brands seem to last forever! One of my friends had an Emerson (Funai) CRT in his work shop. It only had cable and he literally never turned it off. Vacation/gone, thing was always running...Not sure when he started doing that but it was 15 years old. Years of doing that though. Thing was disgustingly dirty but kept on working! CRTs seem to be built very toughLast edited by Pentium4; 04-29-2016, 02:11 PM.Leave a comment:
Re: CRT TVs
The crappy silkscreen font for the rear jacks is a big give-away of it being a cheap Asian brandLeave a comment:
Re: CRT TVs
Ive never heard this brand name before. Is this the maker of the TV?Leave a comment:
Re: CRT TVs
^ Damn, that thing is a beast! I wish cameras did justice as far as displaying the quality of picture of the TV. They always look funny. I'm sure the picture looked great in real life?
Meanwhile...I have been keeping the CRTs in Washington state circulatingThe Zenith was given to Goodwill, the 27" Sony was given to a friend who had no TV at all, the 30" HD Sony was left with my old roommate to use (In exchange for free haircuts for life, ha!) Btw, she thought the thing was junk until she actually saw it in action.... She fell in love with the picture but mostly the sound, she's used to cheap LCD TV speakers, which are awful. Anyways....I couldn't live with having no tube
so I snagged a 20" Daewoo from 2003, which had an excellent sharp picture, but the Stereo speaker didn't work no matter what, and the previous owner ruined the antenna jack
so I gave that to Goodwill. Which leads me to....
My new toy!! I found this for free on craigslist. I absolutely love the look of this TV! For being made in 2002, it looks pretty sleek. Apex Digital had a very short run as a company, 1997-2010. Maybe a collectors item one day?I like the design on the front speakers and the front panel buttons. I haven't tested it yet, but it was said to work fine. All the caps in it are Jianghai but they look okay...for now. I've never opened or worked on a CRT before, still.
I had to hold it up so it wouldn't tip over on the bed lol.
I plan on keeping this beast forever! It's a pretty darn cool TV and I'm glad I got it for freeI expect the picture to be excellent. Anyone have experience with Apex CRTs?
by cmonkeyTurned on my lovely plasma and after about 30 seconds the screen below showed up. None of the inputs are responsive, just the red light flashes when I push it. Remote doesn't work either. To turn it off I need to unplug it and when I plug it in again it turns back on to this screen.
I only found one reference to this issue with a different model but it didn't look super reliable. Only mentioned a 'main board fault'. The main board for this one is on ebay for $34 so might need to go with that.
Anyone seen this before?
Thinking about it some more, it happened...05-19-2023, 01:01 PM -
by elmontadorHello i hope someone can help me i made a mess, i forgot that the board still hot and i knock some resistors out of place , i can't find any schematics or any info, i am uploading a picture with the components i need to put in place i don't need the full manual just the list for the resistors and their value(8 in total), if someone can help i'll be thankful...
by handsworthJust wanted to share some information that I ran across when attempting to do the tape method on a tv with a shorted panel. I normally use magnifying glasses however while watching a you tube video, the person was using their phone. It seems that the Iphone has a magnifier app and wow, it works great. I have Iphone 11 and the app is built in. Pictures attached are screen shots. Made taping the pins a breeze. Also useful when reading the tiny print on the boards. Hope this helps somebody. ...
by rumi409 Hi,
I'm trying to resurrect a LG OLED C1 TV that has some panel banding. I used the TCON error bypass to get a picture. I was able to update the firmware as well. But when I performed a pixel cleaning to try to get the banding out, it made the image significantly worse. I tried to undo the effects of the pixel cleaning by performing a factory reset and IN_Stop, but that didn't work. Any way to reset pixel cleaning data?...1 Photo -
by Mustafa85Hi guys,
Any one has Emerson industrial PSU schematic, it has 3 electronics cards in one package please have a look at pics - Loading...
