Zenith Z50PJ240 - White Screen with 'Power Only' displayed
  • cmonkey
    • Apr 2023
    • 58
    • Unitied States
    Turned on my lovely plasma and after about 30 seconds the screen below showed up. None of the inputs are responsive, just the red light flashes when I push it. Remote doesn't work either. To turn it off I need to unplug it and when I plug it in again it turns back on to this screen.
    I only found one reference to this issue with a different model but it didn't look super reliable. Only mentioned a 'main board fault'. The main board for this one is on ebay for $34 so might need to go with that.
    Anyone seen this before?
    Thinking about it some more, it happened right as I pushed the wrong button on the remote I use for this TV. It's not a Zenith remote. I pushed the 'open/close' button on the remote instead of the 'input' button and it immediately displayed this message. Maybe it's a coincidence, but I did find this which talks about universal remotes causing issues for LG tvs. Zenith is owned by LG.
    EDIT - So I fixed this issue by simply pushing the 'Exit' button on the remote I have. It's not a universal remote, but it's also not a Zenith remote. But it worked!! So this post is just for anyone in the future who might encounter this weird situation.
  • Ryan.man
    by Ryan.man
    02-04-2025, 12:23 PM
  • smic717394
    by smic717394
    07-25-2024, 10:16 AM
  • Chrissygizmo
    by Chrissygizmo
    02-10-2025, 12:33 AM
  • ipatch
    ipad pro 9.7" blew a SMD component while replacing the screen 🤦‍♂️
    by ipatch
    i have an ipad pro 9.7" (1st gen) A1674 where i replaced the screen, but never attached the screen to the frame/chassis (glued down) due to the ipad being previously dropped so the new screen would never fit in the frame properly. so i need flex/bend the chassis to eventually fix the new screen in properly. so i temporarily just applied blue tape around the edges of the screen to keep it in place. when watching videos with the ipad the screen started flicker, so i though maybe the new quasi cheap amz screen i purchased was going out. so i disconnected then reconnected with power still on,...
    08-24-2024, 02:36 PM
  • FreakyMex
    Trouble to identify part (Lunii screen) for replacement
    by FreakyMex
    Hello guys. I'm a complete noob in electronics. I'd like to repair my child Lunii's (a "story box"), basically an audio player that allows the childs to choose between several options the places, characters, objects of the story, and then play a story according to the choice of the child. There is a screen that display the selected option before each choice. The Lunii fell and the screen is now broken.
    I'd like to repair it (probably just have to change the part, because the lunii still works perfectly fine) but I can't manage to identify the part/order it online. Do you have any...
    02-17-2025, 01:16 AM
